18#ifndef XMLELEMENTCOLLECTION_H
   19#define XMLELEMENTCOLLECTION_H
   41                QDomElement
root()
const;
   43                QDomNodeList
childs(
const QDomElement &parent_element)
const;
   44                QDomElement
child(
const QDomElement &parent_element,
   45                                  const QString &child_name)
const;
   46                QDomElement
child(
const QString &path)
const;
   48                                const QDomElement &parent_element)
const;
   50                                const QDomElement &parent_element)
const;
   52                                const QDomElement &parent_element)
const;
   54                                const QDomElement &parent_element)
const;
   55                QDomElement
element(
const;
   56                QDomElement
directory(
const;
   59                                           const QString &elmt_name,
   60                                           const QDomElement &xml_definition);
   64                                       const QString& rename = QString(),
   65                                       bool deep_copy =
true);
   66                bool exist (
const;
   73                                QDomElement dom_element = QDomElement(),
   84                                const QString& rename = QString(),
   85                                bool deep_copy =
true);
   88                                             const QString& rename = QString());
The ElementsLocation class This class represents the location, the location of an element or of a cat...
Definition elementslocation.h:47
Definition nameslist.h:31
Definition qetproject.h:62
The XmlElementCollection class This class represent a collection of elements stored to xml.
Definition xmlelementcollection.h:34
QList< QDomElement > directories(const QDomElement &parent_element) const
XmlElementCollection::directories.
Definition xmlelementcollection.cpp:285
QDomElement directory(const QString &path) const
XmlElementCollection::directory.
Definition xmlelementcollection.cpp:391
bool removeDir(const QString &path)
XmlElementCollection::removeDir Remove the directory at path path.
Definition xmlelementcollection.cpp:703
ElementsLocation copyElement(ElementsLocation &source, ElementsLocation &destination, const QString &rename=QString())
XmlElementCollection::copyElement Copy the element represented by source to destination (must be a di...
Definition xmlelementcollection.cpp:933
QString addElement(ElementsLocation &location)
XmlElementCollection::addElement Add the element at location to this collection. The element is copie...
Definition xmlelementcollection.cpp:415
bool removeElement(const QString &path)
XmlElementCollection::removeElement Remove the element at path path.
Definition xmlelementcollection.cpp:598
void cleanUnusedDirectory()
XmlElementCollection::cleanUnusedDirectory Remove the empty directories of this collection.
Definition xmlelementcollection.cpp:803
QDomElement child(const QDomElement &parent_element, const QString &child_name) const
XmlElementCollection::child If parent_element have child element with an attribute name = child_name,...
Definition xmlelementcollection.cpp:230
QList< QDomElement > elements(const QDomElement &parent_element) const
XmlElementCollection::elements.
Definition xmlelementcollection.cpp:329
ElementsLocation copy(ElementsLocation &source, ElementsLocation &destination, const QString &rename=QString(), bool deep_copy=true)
XmlElementCollection::copy Copy the content represented by source (an element or a directory) to dest...
Definition xmlelementcollection.cpp:627
QStringList directoriesNames(const QDomElement &parent_element) const
XmlElementCollection::directoriesNames.
Definition xmlelementcollection.cpp:308
void elementRemoved(QString collection_path)
elementRemoved This signal is emitted when an element is removed from this collection
bool exist(const QString &path) const
XmlElementCollection::exist Return true if the path path exist in this collection.
Definition xmlelementcollection.cpp:651
QDomDocument m_dom_document
Definition xmlelementcollection.h:123
ElementsLocation copyDirectory(ElementsLocation &source, ElementsLocation &destination, const QString &rename=QString(), bool deep_copy=true)
XmlElementCollection::copyDirectory Copy the directory represented by source to destination....
Definition xmlelementcollection.cpp:831
bool createDir(const QString &path, const QString &name, const NamesList &name_list)
XmlElementCollection::createDir Create a child directory at path path with the name name....
Definition xmlelementcollection.cpp:669
ElementsLocation domToLocation(QDomElement dom_element) const
XmlElementCollection::domToLocation Return the element location who represent the xml element : dom_e...
Definition xmlelementcollection.cpp:769
void cleanUnusedElement()
XmlElementCollection::cleanUnusedElement Remove elements in this collection which is not used in the ...
Definition xmlelementcollection.cpp:793
QList< ElementsLocation > elementsLocation(QDomElement dom_element=QDomElement(), bool childs=true) const
XmlElementCollection::elementsLocation Return all locations stored in dom_element (element and direct...
Definition xmlelementcollection.cpp:724
QDomNodeList childs(const QDomElement &parent_element) const
XmlElementCollection::childs.
Definition xmlelementcollection.cpp:210
void elementChanged(QString collection_path)
elementChanged This signal is emitted when the definition of the element at path was changed
void directoryRemoved(QString collection_path)
directoryRemoved This signal is emitted when a directory is removed from this collection
QDomElement element(const QString &path) const
XmlElementCollection::element.
Definition xmlelementcollection.cpp:373
bool addElementDefinition(const QString &dir_path, const QString &elmt_name, const QDomElement &xml_definition)
XmlElementCollection::addElementDefinition Add the element definition xml_definition in the directory...
Definition xmlelementcollection.cpp:559
void directorieAdded(QString collection_path)
directorieAdded This signal is emitted when a directory is added to this collection
QETProject * m_project
Definition xmlelementcollection.h:124
QDomElement root() const
XmlElementCollection::root The root is the first DOM-Element the xml collection, the tag name of the ...
Definition xmlelementcollection.cpp:190
QStringList elementsNames(const QDomElement &parent_element) const
XmlElementCollection::elementsNames.
Definition xmlelementcollection.cpp:351
void elementAdded(QString collection_path)
elementAdded This signal is emitted when a element is added to this collection
QDomElement importCategory() const
XmlElementCollection::importCategory.
Definition xmlelementcollection.cpp:200
