terminaldata.h
1/*
14
17*/
18#ifndef TERMINALDATA_H
19#define TERMINALDATA_H
20
21#include "../qet.h"
22#include "propertiesinterface.h"
23
24#include <QColor>
25#include <QFont>
26#include <QPointF>
27#include <QUuid>
28
29class QGraphicsObject;
30
39{
40 Q_GADGET
41
42 public:
51 Q_ENUM(Type)
52
54 TerminalData(QGraphicsObject* parent);
55 ~TerminalData() override;
56
57 void init();
58
59 void setParent(QGraphicsObject* parent);
60 void toSettings(QSettings &settings,
61 const QString prefix = QString()) const override;
62 void fromSettings(const QSettings &settings,
63 const QString prefix = QString()) override;
64 QDomElement toXml(QDomDocument &xml_element) const override;
65 bool fromXml(const QDomElement &xml_element) override;
66
67 static QString typeToString(TerminalData::Type type);
68 static TerminalData::Type typeFromString(const QString &string);
69
70 // must be public, because this class is a private member
71 // of PartTerminal/Terminal and they must access this data
72 public:
98 QUuid m_uuid;
104 QString m_name;
105
116 QPointF m_pos;
117
119
121 bool m_show_name = false;
123 QPointF m_label_pos{0.0, 0.0};
127 qreal m_label_rotation = 0.0;
129 Qt::Alignment m_label_halignment = Qt::AlignHCenter;
131 Qt::Alignment m_label_valignment = Qt::AlignVCenter;
133 bool m_label_frame = false;
135 QColor m_label_color = Qt::black;
136
138 bool m_use_master_label = false;
141
142 private:
143 QGraphicsObject* q{nullptr};
144};
145
146#endif // TERMINALDATA_H
PropertiesInterface()
PropertiesInterface::PropertiesInterface.
Definition propertiesinterface.cpp:23
Orientation
Orientation (used for electrical elements and their terminals).
Definition qet.h:211
void init()
Definition terminaldata.cpp:40
bool m_show_name
Whether to display the terminal name as a text label.
Definition terminaldata.h:121
void setParent(QGraphicsObject *parent)
TerminalData::setParent.
Definition terminaldata.cpp:54
Horizontal alignment of the text label.
Definition terminaldata.h:129
QGraphicsObject * q
Definition terminaldata.h:143
TerminalData::Type m_type
Definition terminaldata.h:118
TerminalData::toXml Save properties to xml element write the name, number, position and orientation o...
Definition terminaldata.cpp:100
TerminalData()
Definition terminaldata.cpp:27
Whether this terminal uses a label from the master's contact group.
Definition terminaldata.h:138
TerminalData::typeFromString.
Definition terminaldata.cpp:247
Rotation of the text label in degrees.
Definition terminaldata.h:127
Vertical alignment of the text label.
Definition terminaldata.h:131
Definition terminaldata.cpp:45
void toSettings(QSettings &settings, const QString prefix=QString()) const override
TerminalData::toSettings Save properties to settings file.
Definition terminaldata.cpp:67
TerminalData::fromXml load properties to xml element.
Definition terminaldata.cpp:150
QPointF m_label_pos
Position of the text label relative to the terminal.
Definition terminaldata.h:123
QUuid m_uuid
m_uuid Uuid of the terminal.
Definition terminaldata.h:98
Type
Definition terminaldata.h:43
@ Nc
Normally Closed terminal (for SW contacts).
Definition terminaldata.h:48
@ Generic
Definition terminaldata.h:44
@ Inner
Definition terminaldata.h:45
@ Outer
Definition terminaldata.h:46
@ No
Normally Open terminal (for SW contacts).
Definition terminaldata.h:47
@ Common
Common terminal (for SW contacts).
Definition terminaldata.h:49
QFont m_label_font
Font used for the text label.
Definition terminaldata.h:125
QPointF m_second_point
second_point Position of the second point of the terminal in scene coordinates
Definition terminaldata.h:83
int m_master_label_index
Index into the master's contact group labels (T1=0, T2=1, ..., T20=19).
Definition terminaldata.h:140
TerminalData::typeToString.
Definition terminaldata.cpp:222
bool m_label_frame
Whether to draw a frame around the text label.
Definition terminaldata.h:133
QPointF m_pos
m_pos Position of the terminal. The second point is calculated from this position and the orientation
Definition terminaldata.h:116
Qet::Orientation m_orientation
m_orientation Orientation of the terminal
Definition terminaldata.h:77
Color of the text label.
Definition terminaldata.h:135
void fromSettings(const QSettings &settings, const QString prefix=QString()) override
TerminalData::fromSettings load properties to settings file.
Definition terminaldata.cpp:82
QString m_name
m_name Name of the element. It can be used to create wiring harness tables
Definition terminaldata.h:104
