TerminalStrip Class Reference
The TerminalStrip class This class hold all the datas and configurations of a terminal strip (but the not the visual aspect). A terminal strip have some informations (name comment etc...) and is composed by one or several PhysicalTerminal. More...
#include <terminalstrip.h>
Inherits QObject.
Collaboration diagram for TerminalStrip:
Signals
void orderChanged ()
void bridgeChanged ()
void bridgeColorChanged (QSharedPointer< TerminalStripBridge > bridge)
 TerminalStrip (QETProject *project)
 TerminalStrip::TerminalStrip.
 TerminalStrip (const QString &installation, const QString &location, const QString &name, QETProject *project)
void setInstallation (const QString &installation)
QString installation () const
void setLocation (const QString &location)
QString location () const
void setName (const QString &name)
QString name () const
void setComment (const QString &comment)
QString comment () const
void setDescription (const QString &description)
QString description () const
QUuid uuid () const
QETProject * project () const
 TerminalStrip::project.
TerminalStripData data () const
 TerminalStrip::data.
void setData (const TerminalStripData &data)
 TerminalStrip::setData Set the internal data of this strip to data. the uuid of the new data is set to the uuid of the previous data to keep the uuid of the terminal strip unchanged.
bool addTerminal (QSharedPointer< RealTerminal > real_t)
void addTerminals (QVector< QSharedPointer< RealTerminal > > real_t_vector)
 TerminalStrip::addTerminals Add terminal in real_t_vector to this terminal.
void addAndGroupTerminals (const QVector< QVector< QSharedPointer< RealTerminal > > > &real_t_vector)
 TerminalStrip::addAndGroupTerminals For each real terminals of second vector, add it to terminal strip and group them together.
bool removeTerminal (QSharedPointer< RealTerminal > real_t)
void removeTerminals (QVector< QSharedPointer< RealTerminal > > real_t_vector)
 TerminalStrip::removeTerminals Remove terminals in real_t_vector from this terminal strip.
bool addTerminal (Element *terminal)
 TerminalStrip::addTerminal Add terminal to this terminal strip.
bool removeTerminal (Element *terminal)
 TerminalStrip::removeTerminal Remove terminal from this terminal strip.
bool addTerminal (QSharedPointer< PhysicalTerminal > phy_t)
 TerminalStrip::addTerminal Add phy_t in this terminal strip.
void addTerminals (QVector< QSharedPointer< PhysicalTerminal > > phy_t_vector)
bool removeTerminal (QSharedPointer< PhysicalTerminal > phy_t)
 TerminalStrip::removeTerminal Remove phy_t from this terminal strip.
void removeTerminals (QVector< QSharedPointer< PhysicalTerminal > > phy_t_vector)
int pos (const QSharedPointer< PhysicalTerminal > &terminal) const
 TerminalStrip::pos.
int physicalTerminalCount () const
 TerminalStrip::physicalTerminalCount.
QSharedPointer< PhysicalTerminal > physicalTerminal (int index) const
 TerminalStrip::physicalTerminalData.
QSharedPointer< PhysicalTerminal > physicalTerminal (const QUuid &uuid) const
 TerminalStrip::physicalTerminal.
QVector< QSharedPointer< PhysicalTerminal > > physicalTerminal () const
QSharedPointer< RealTerminal > realTerminalForUuid (const QUuid &uuid) const
 TerminalStrip::realTerminalForUuid.
QVector< QSharedPointer< RealTerminal > > realTerminals () const
 TerminalStrip::realTerminals.
bool setOrderTo (const QVector< QSharedPointer< PhysicalTerminal > > &sorted_vector)
 TerminalStrip::setSortedTo Sort the physical terminal owned by this strip in the same order as sorted_vector. sorted_vector must contain exactly the same physical terminal as this strip else this function do nothing.
bool groupTerminals (const QSharedPointer< PhysicalTerminal > &receiver_terminal, const QVector< QSharedPointer< RealTerminal > > &added_terminals)
 TerminalStrip::groupTerminal Add added_terminal to receiver_terminal. At the end of this method, if there is physical terminal without any real terminal, they will be removed and receiver_terminal become a multi-level terminal. Emit the signal orderChanged();.
void unGroupTerminals (const QVector< QSharedPointer< RealTerminal > > &terminals_to_ungroup)
 TerminalStrip::unGroupTerminals Ungroup all real terminals of terminals_to_ungroup.
bool setLevel (const QSharedPointer< RealTerminal > &real_terminal, int level)
 TerminalStrip::setLevel.
bool isBridgeable (const QVector< QSharedPointer< RealTerminal > > &real_terminals) const
 TerminalStrip::isBridgeable Check if all realTerminal in real_terminals are bridgeable together. To be bridgeable, each real terminal must belong to this terminal strip be at the same level, be consecutive and not belong to the same physicalTerminal and at least one terminal must be not bridged.
bool isBridgeable (QSharedPointer< TerminalStripBridge > bridge, const QVector< QSharedPointer< RealTerminal > > &real_terminals) const
 TerminalStrip::isBridgeable Check if all RealTerminal of real_terminals can be bridged to the bridge bridge.
bool setBridge (const QVector< QSharedPointer< RealTerminal > > &real_terminals)
 TerminalStrip::setBridge Set a bridge between all real terminal of real_terminals.
bool setBridge (const QSharedPointer< TerminalStripBridge > &bridge, const QVector< QSharedPointer< RealTerminal > > &real_terminals)
 TerminalStrip::setBridge Bridge the RealTerminal of real_terminals_data to bridge.
void unBridge (const QVector< QSharedPointer< RealTerminal > > &real_terminals)
 TerminalStrip::unBridge Unbridge all real terminals of real_terminals.
bool canUnBridge (const QVector< QSharedPointer< RealTerminal > > &real_terminals) const
 TerminalStrip::canUnBridge.
QSharedPointer< TerminalStripBridge > isBridged (const QSharedPointer< RealTerminal > real_terminal) const
 TerminalStrip::isBridged Check if real_terminal is bridged.
QSharedPointer< TerminalStripBridge > bridgeFor (const QVector< QSharedPointer< RealTerminal > > &terminal_vector) const
 TerminalStrip::bridgeFor Return the bridge where at least one terminal of terminal_vector belong. If several terminals are bridged but not to the same bridge return a TerminalStripBridge with 0 real_terminals_uuid_vector.
QSharedPointer< RealTerminal > previousTerminalInLevel (const QSharedPointer< RealTerminal > &real_terminal) const
 TerminalStrip::previousTerminalInLevel.
QSharedPointer< RealTerminal > nextTerminalInLevel (const QSharedPointer< RealTerminal > &real_terminal) const
 TerminalStrip::nextTerminalInLevel.
QSharedPointer< RealTerminal > previousRealTerminal (const QSharedPointer< RealTerminal > &real_terminal) const
QSharedPointer< RealTerminal > nextRealTerminal (const QSharedPointer< RealTerminal > &real_terminal) const
QDomElement toXml (QDomDocument &parent_document)
 TerminalStrip::toXml.
bool fromXml (QDomElement &xml_element)
 TerminalStrip::fromXml.
static QString xmlTagName ()
TerminalStripData m_data
QPointer< QETProject > m_project
QVector< QSharedPointer< PhysicalTerminal > > m_physical_terminals
QVector< QSharedPointer< TerminalStripBridge > > m_bridge
Friends
class TerminalStripModel
class RealTerminalData
◆ TerminalStrip() [1/2]
TerminalStrip::TerminalStrip ( QETProject * project)
project
◆ TerminalStrip() [2/2]
TerminalStrip::TerminalStrip ( const QString & installation,
const QString & location,
const QString & name,
QETProject * project )
installation
location
name
project
◆ addAndGroupTerminals()
void TerminalStrip::addAndGroupTerminals ( const QVector< QVector< QSharedPointer< RealTerminal > > > & real_t_vector)
real_t_vector
◆ addTerminal() [1/3]
bool TerminalStrip::addTerminal ( Element * terminal)
terminal
true if the terminal was successfully added. Return false, if terminal already exist. Return false, if terminal is not a terminal element.
◆ addTerminal() [2/3]
bool TerminalStrip::addTerminal ( QSharedPointer< PhysicalTerminal > phy_t)
phy_t
true if successfully added. A terminal can't be added is already belong to another terminal strip.
◆ addTerminal() [3/3]
bool TerminalStrip::addTerminal ( QSharedPointer< RealTerminal > real_t)
◆ addTerminals() [1/2]
void TerminalStrip::addTerminals ( QVector< QSharedPointer< PhysicalTerminal > > phy_t_vector)
◆ addTerminals() [2/2]
void TerminalStrip::addTerminals ( QVector< QSharedPointer< RealTerminal > > real_t_vector)
real_t_vector
◆ bridgeChanged
void TerminalStrip::bridgeChanged ( )
signal
◆ bridgeColorChanged
void TerminalStrip::bridgeColorChanged ( QSharedPointer< TerminalStripBridge > bridge)
signal
◆ bridgeFor()
QSharedPointer< TerminalStripBridge > TerminalStrip::bridgeFor ( const QVector< QSharedPointer< RealTerminal > > & terminal_vector) const
See also
TerminalStripBridge
terminal_vector
◆ canUnBridge()
bool TerminalStrip::canUnBridge ( const QVector< QSharedPointer< RealTerminal > > & real_terminals) const
m_real_terminals
True if all terminals of real_terminals can be unbridged. For this method return True, all terminals must be bridged together, be consecutive and in one or the both extremities of the bridge.
◆ comment()
QString TerminalStrip::comment ( ) const
inline
◆ data()
TerminalStripData TerminalStrip::data ( ) const
The internal data of this strip
◆ description()
QString TerminalStrip::description ( ) const
inline
◆ fromXml()
bool TerminalStrip::fromXml ( QDomElement & xml_element)
xml_element
Set up this terminal strip from the xml description xml_element
◆ groupTerminals()
bool TerminalStrip::groupTerminals ( const QSharedPointer< PhysicalTerminal > & receiver_terminal,
const QVector< QSharedPointer< RealTerminal > > & added_terminals )
added_terminal
receiver_terminal
true if success
◆ installation()
QString TerminalStrip::installation ( ) const
inline
◆ isBridgeable() [1/2]
bool TerminalStrip::isBridgeable ( const QVector< QSharedPointer< RealTerminal > > & real_terminals) const
real_terminals: a vector of realterminal
◆ isBridgeable() [2/2]
bool TerminalStrip::isBridgeable ( QSharedPointer< TerminalStripBridge > bridge,
const QVector< QSharedPointer< RealTerminal > > & real_terminals ) const
real_terminals
true if can be bridged.
◆ isBridged()
QSharedPointer< TerminalStripBridge > TerminalStrip::isBridged ( const QSharedPointer< RealTerminal > real_terminal) const
real_terminal
a pointer of TerminalStripBridge if bridget or a null QSharedPointer.
◆ location()
QString TerminalStrip::location ( ) const
inline
◆ name()
QString TerminalStrip::name ( ) const
inline
◆ nextRealTerminal()
QSharedPointer< RealTerminal > TerminalStrip::nextRealTerminal ( const QSharedPointer< RealTerminal > & real_terminal) const
◆ nextTerminalInLevel()
QSharedPointer< RealTerminal > TerminalStrip::nextTerminalInLevel ( const QSharedPointer< RealTerminal > & real_terminal) const
real_terminal
The next real terminal at the same level of real_t or a null RealTerminalData if there not a next real terminal
◆ orderChanged
void TerminalStrip::orderChanged ( )
signal
◆ physicalTerminal() [1/3]
QVector< QSharedPointer< PhysicalTerminal > > TerminalStrip::physicalTerminal ( ) const
A vector of all physical terminal owned by this terminal strip. The order of the vector is the same as the order of the terminal in the strip
◆ physicalTerminal() [2/3]
QSharedPointer< PhysicalTerminal > TerminalStrip::physicalTerminal ( const QUuid & uuid) const
uuid
the the physicalTerminal with the uuid uuid or a empty QSharedPointer if empty.
◆ physicalTerminal() [3/3]
QSharedPointer< PhysicalTerminal > TerminalStrip::physicalTerminal ( int index) const
index
The data of the physical terminal at index index returned QSharedPointer can be null
◆ physicalTerminalCount()
int TerminalStrip::physicalTerminalCount ( ) const
the number of physical terminal. A physical terminal is the representation of a real electrical terminal. Notice that a physical terminal can have level (like in real life)
◆ pos()
int TerminalStrip::pos ( const QSharedPointer< PhysicalTerminal > & terminal) const
TerminalStrip::pos.
terminal
the position of the physical terminal or -1 if not found
◆ previousRealTerminal()
QSharedPointer< RealTerminal > TerminalStrip::previousRealTerminal ( const QSharedPointer< RealTerminal > & real_terminal) const
◆ previousTerminalInLevel()
QSharedPointer< RealTerminal > TerminalStrip::previousTerminalInLevel ( const QSharedPointer< RealTerminal > & real_terminal) const
real_terminal
The previous real terminal at the samne level of real_t or a null RealTerminalData if there not a previous real terminal
◆ project()
QETProject * TerminalStrip::project ( ) const
the project of this terminal strip or nullptr
◆ realTerminalForUuid()
QSharedPointer< RealTerminal > TerminalStrip::realTerminalForUuid ( const QUuid & uuid) const
uuid
the real terminal with uuid uuid or a null QSharedPointer if not found
◆ realTerminals()
QVector< QSharedPointer< RealTerminal > > TerminalStrip::realTerminals ( ) const
All real terminal owned by this strip
◆ removeTerminal() [1/3]
bool TerminalStrip::removeTerminal ( Element * terminal)
terminal
true if terminal was successfully removed
◆ removeTerminal() [2/3]
bool TerminalStrip::removeTerminal ( QSharedPointer< PhysicalTerminal > phy_t)
phy_t
true if successfully removed. Return false if can't be removed because not owned by this strip
◆ removeTerminal() [3/3]
bool TerminalStrip::removeTerminal ( QSharedPointer< RealTerminal > real_t)
◆ removeTerminals() [1/2]
void TerminalStrip::removeTerminals ( QVector< QSharedPointer< PhysicalTerminal > > phy_t_vector)
◆ removeTerminals() [2/2]
void TerminalStrip::removeTerminals ( QVector< QSharedPointer< RealTerminal > > real_t_vector)
real_t_vector
◆ setBridge() [1/2]
bool TerminalStrip::setBridge ( const QSharedPointer< TerminalStripBridge > & bridge,
bridge
real_terminals_data
true if all RealTerminal was successfully bridged
◆ setBridge() [2/2]
bool TerminalStrip::setBridge ( const QVector< QSharedPointer< RealTerminal > > & real_terminals)
See also
true if bridge was successfully created
◆ setComment()
void TerminalStrip::setComment ( const QString & comment)
◆ setData()
void TerminalStrip::setData ( const TerminalStripData & data)
data
◆ setDescription()
void TerminalStrip::setDescription ( const QString & description)
◆ setInstallation()
void TerminalStrip::setInstallation ( const QString & installation)
◆ setLevel()
bool TerminalStrip::setLevel ( const QSharedPointer< RealTerminal > & real_terminal,
int level )
real_terminal_data
level
◆ setLocation()
void TerminalStrip::setLocation ( const QString & location)
◆ setName()
void TerminalStrip::setName ( const QString & name)
◆ setOrderTo()
bool TerminalStrip::setOrderTo ( const QVector< QSharedPointer< PhysicalTerminal > > & sorted_vector)
To avoid any mistake, you should call TerminalStrip::physicalTerminal() sort the returned vector and call this function with sorted vector, then you are sure the vector contain the same values, no more no less.
sorted_vector
true is successfully sorted.
◆ toXml()
QDomElement TerminalStrip::toXml ( QDomDocument & parent_document)
parent_document
◆ unBridge()
void TerminalStrip::unBridge ( const QVector< QSharedPointer< RealTerminal > > & real_terminals)
See also
real_terminals
◆ unGroupTerminals()
void TerminalStrip::unGroupTerminals ( const QVector< QSharedPointer< RealTerminal > > & terminals_to_ungroup)
◆ uuid()
QUuid TerminalStrip::uuid ( ) const
inline
◆ xmlTagName()
QString TerminalStrip::xmlTagName ( )
inlinestatic
◆ RealTerminalData
friend class RealTerminalData
friend
◆ TerminalStripModel
friend class TerminalStripModel
friend
◆ m_bridge
QVector<QSharedPointer<TerminalStripBridge> > TerminalStrip::m_bridge
◆ m_data
TerminalStripData TerminalStrip::m_data
◆ m_physical_terminals
QVector<QSharedPointer<PhysicalTerminal> > TerminalStrip::m_physical_terminals
◆ m_project
QPointer<QETProject> TerminalStrip::m_project
