QElectroTech 0.100.0-dev
The ElementQueryWidget class A widget use to edit a sql query for get element information This widget only work to get information from ProjectDataBase. More...
#include <elementquerywidget.h>
Inherits QWidget.
Public Member Functions | |
| ElementQueryWidget (QWidget *parent=nullptr) | |
| ElementQueryWidget::ElementQueryWidget. | |
| ~ElementQueryWidget () | |
| ElementQueryWidget::~ElementQueryWidget. | |
| void | setQuery (const QString &query) |
| ElementQueryWidget::setQuery. | |
| QString | queryStr () const |
| ElementQueryWidget::queryStr. | |
| void | setGroupBy (QString text, bool set=true) |
| ElementQueryWidget::setGroupBy Add the query instruction GROUP BY. | |
| void | setCount (QString text, bool set=true) |
| ElementQueryWidget::setCount Add the query instruction COUNT. Unlike setGroupBy, you have to write the entire sentence. ex : text = "COUNT(*) AS designation_qty". the query will contain what you write. | |
Static Public Member Functions | |
| static QString | modelIdentifier () |
Private Attributes | |
| Ui::ElementQueryWidget * | ui |
| QHash< QString, QString > | m_export_info |
| QButtonGroup | m_button_group |
| QList< QListWidgetItem * > | m_items_list |
| QString | m_custom_query |
| QString | m_group_by |
| QString | m_count |
| QHash< QString, QPair< int, QString > > | m_filter |
explicit |
| ElementQueryWidget::~ElementQueryWidget | ( | ) |
privateslot |
ElementQueryWidget::fillSavedQuery Fill the combobox of saved queries.
privateslot |
ElementQueryWidget::FilterFor.
| key |
inlinestatic |
privateslot |
ElementQueryWidget::on_m_add_pb_clicked.
privateslot |
privateslot |
privateslot |
privateslot |
privateslot |
ElementQueryWidget::on_m_filter_le_textEdited.
| arg1 |
privateslot |
ElementQueryWidget::on_m_filter_type_cb_activated.
| index |
privateslot |
ElementQueryWidget::on_m_load_pb_clicked Load a query from nomenclature.json file.
privateslot |
ElementQueryWidget::on_m_remove_pb_clicked.
privateslot |
ElementQueryWidget::on_m_save_current_conf_pb_clicked Save the actual query to nomenclature.json file.
privateslot |
privateslot |
privateslot |
| QString ElementQueryWidget::queryStr | ( | ) | const |
privateslot |
ElementQueryWidget::reset Clear this widget aka set to initial state.
privateslot |
ElementQueryWidget::selectedKeys.
| void ElementQueryWidget::setCount | ( | QString | text, |
| bool | set = true |
| text | : the count instruction |
| set | : true by default -> count will be used. false -> count will be not used. |
| void ElementQueryWidget::setGroupBy | ( | QString | text, |
| bool | set = true |
| text | : the text of the GROUP BY instruction: ex : if text = designation, the query will contain "GROUP BY designation" |
| set | : true by default -> GROUP BY will be used. false -> GROUP BY will be not used |
| void ElementQueryWidget::setQuery | ( | const QString & | query | ) |
| query | Set the current query to query. If it's possible, rebuild the state of the widget from the query |
privateslot |
privateslot |
ElementQueryWidget::updateQueryLine.
private |
private |
private |
private |
private |
private |
private |
private |
