QElectroTech 0.100.0-dev
Public Slots | Signals | Public Member Functions | Protected Member Functions | Private Member Functions | Private Attributes | List of all members
TitleBlockTemplateCellWidget Class Reference
The TitleBlockTemplateCellWidget class This class implements an edition widget for cells that compose a title block template. More...
#include <templatecellwidget.h>
Inherits QWidget.
Collaboration diagram for TitleBlockTemplateCellWidget:
Public Slots
void updateFormType (int)
void edit (TitleBlockCell *)
void editType ()
void editName ()
void editLabelDisplayed ()
void editLabel ()
void editValue ()
void editAlignment ()
void editFontSize ()
void editAdjust ()
void editLogo ()
void updateLogosComboBox (const TitleBlockTemplate *)
void setReadOnly (bool)
Signals
void logoEditionRequested ()
void cellModified (ModifyTitleBlockCellCommand *) const
 TitleBlockTemplateCellWidget (TitleBlockTemplate *=nullptr, QWidget *=nullptr)
 TitleBlockTemplateCellWidget::TitleBlockTemplateCellWidget Constructor.
 ~TitleBlockTemplateCellWidget () override
int horizontalAlignment () const
int verticalAlignment () const
int alignment () const
bool isReadOnly () const
void editTranslatableValue (NamesList &, const QString &, const QString &) const
void emitModification (const QString &, const QVariant &) const
QString defaultVariablesString () const
QString labelValueInformationString () const
 TitleBlockTemplateCellWidget (const TitleBlockTemplateCellWidget &)
void initWidgets ()
bool read_only_
 is the template read-only?
QLabel * cell_type_label_
QComboBox * cell_type_input_
QLabel * empty_label_
QLabel * logo_label_
QComboBox * logo_input_
QPushButton * add_logo_input_
QLabel * name_label_
QLineEdit * name_input_
QCheckBox * label_checkbox_
QLineEdit * label_input_
QPushButton * label_edit_
QLabel * value_label_
QLineEdit * value_input_
QPushButton * value_edit_
QLabel * align_label_
QLabel * horiz_align_label_
QComboBox * horiz_align_input_
QHash< int, int > horiz_align_indexes_
QLabel * vert_align_label_
QComboBox * vert_align_input_
QHash< int, int > vert_align_indexes_
QLabel * font_size_label_
QSpinBox * font_size_input_
QCheckBox * font_adjust_input_
QVBoxLayout * cell_editor_layout_
QHBoxLayout * cell_editor_type_and_name_layout_
QGridLayout * cell_editor_text_layout_
QHBoxLayout * cell_editor_image_layout_
TitleBlockCelledited_cell_
◆ TitleBlockTemplateCellWidget() [1/2]
TitleBlockTemplateCellWidget::TitleBlockTemplateCellWidget ( TitleBlockTemplate parent_template = nullptr,
QWidget *  parent = nullptr
parent_template: TitleBlockTemplate
parent: QWidget
◆ ~TitleBlockTemplateCellWidget()
TitleBlockTemplateCellWidget::~TitleBlockTemplateCellWidget ( )
Destructor
◆ TitleBlockTemplateCellWidget() [2/2]
TitleBlockTemplateCellWidget::TitleBlockTemplateCellWidget ( const TitleBlockTemplateCellWidget )
◆ alignment()
int TitleBlockTemplateCellWidget::alignment ( ) const
the currently selected alignment.
◆ cellModified
void TitleBlockTemplateCellWidget::cellModified ( ModifyTitleBlockCellCommand ) const
signal
◆ defaultVariablesString()
QString TitleBlockTemplateCellWidget::defaultVariablesString ( ) const
protected
a string describing the various variables provided by default by the application.
◆ edit
void TitleBlockTemplateCellWidget::edit ( TitleBlockCell cell)
slot
Set the title block cell to be edited. The cell pointer is stored by this class; however, modifications made by the user are packaged as ModifyTitleBlockCellCommand objects and emitted through the cellModified() signal.
cellTitle block cell to be edited
◆ editAdjust
void TitleBlockTemplateCellWidget::editAdjust ( )
slot
Emit a modification command stating whether the text should be adjusted if needed.
See also
◆ editAlignment
void TitleBlockTemplateCellWidget::editAlignment ( )
slot
Emit an alignment modification command.
See also
◆ editFontSize
void TitleBlockTemplateCellWidget::editFontSize ( )
slot
Emit a font size modification command.
See also
◆ editLabel
void TitleBlockTemplateCellWidget::editLabel ( )
slot
Emit a label modification command.
See also
◆ editLabelDisplayed
void TitleBlockTemplateCellWidget::editLabelDisplayed ( )
slot
Emit a modification command stating whether the label should be displayed or not.
See also
◆ editLogo
void TitleBlockTemplateCellWidget::editLogo ( )
slot
Emit a logo modification command.
See also
◆ editName
void TitleBlockTemplateCellWidget::editName ( )
slot
Emit a name modification command.
See also
◆ editTranslatableValue()
void TitleBlockTemplateCellWidget::editTranslatableValue ( NamesList names,
const QString &  attribute,
const QString &  title
) const
protected
Allow the user to edit a translatable string (e.g. value or label). If the user modified the string, this method emits a ModifyTitleBlockCellCommand object through the cellModified() signal.
namesTranslatable string to be edited
attributeName of the edited cell attribute
titleTitle of the dialog window
◆ editType
void TitleBlockTemplateCellWidget::editType ( )
slot
Emit a type modification command.
See also
◆ editValue
void TitleBlockTemplateCellWidget::editValue ( )
slot
Emit a value modification command.
See also
◆ emitModification()
void TitleBlockTemplateCellWidget::emitModification ( const QString &  attribute,
const QVariant &  new_value
) const
protected
Create a ModifyTitleBlockCellCommand object to change attribute to new_value. This object is then emitted through the cellModified() signal.
See also
attributeModified cell attribute
new_valueNew value for the modified cell attribute
◆ horizontalAlignment()
int TitleBlockTemplateCellWidget::horizontalAlignment ( ) const
Emit a horizontal alignment modification command.
See also
◆ initWidgets()
void TitleBlockTemplateCellWidget::initWidgets ( )
Initialize layout and widgets.
◆ isReadOnly()
bool TitleBlockTemplateCellWidget::isReadOnly ( ) const
whether this edition widget is read only
◆ labelValueInformationString()
QString TitleBlockTemplateCellWidget::labelValueInformationString ( ) const
protected
a string describing what the user may enter as cell label / value.
◆ logoEditionRequested
void TitleBlockTemplateCellWidget::logoEditionRequested ( )
signal
◆ setReadOnly
void TitleBlockTemplateCellWidget::setReadOnly ( bool  read_only)
slot
read_onlywhether this edition widget should be read only
◆ updateFormType
void TitleBlockTemplateCellWidget::updateFormType ( int  cell_type)
slot
Shows or hides various widgets depending on the selected cell type
◆ updateLogosComboBox
void TitleBlockTemplateCellWidget::updateLogosComboBox ( const TitleBlockTemplate parent_template)
slot
Updates the list of available logos
parent_templateThe title block template which contains the currently edited cell
◆ verticalAlignment()
int TitleBlockTemplateCellWidget::verticalAlignment ( ) const
Emit a vertical alignment modification command.
See also
◆ add_logo_input_
QPushButton* TitleBlockTemplateCellWidget::add_logo_input_
◆ align_label_
QLabel* TitleBlockTemplateCellWidget::align_label_
◆ cell_editor_image_layout_
QHBoxLayout* TitleBlockTemplateCellWidget::cell_editor_image_layout_
◆ cell_editor_layout_
QVBoxLayout* TitleBlockTemplateCellWidget::cell_editor_layout_
◆ cell_editor_text_layout_
QGridLayout* TitleBlockTemplateCellWidget::cell_editor_text_layout_
◆ cell_editor_type_and_name_layout_
QHBoxLayout* TitleBlockTemplateCellWidget::cell_editor_type_and_name_layout_
◆ cell_type_input_
QComboBox* TitleBlockTemplateCellWidget::cell_type_input_
◆ cell_type_label_
QLabel* TitleBlockTemplateCellWidget::cell_type_label_
◆ edited_cell_
TitleBlockCell* TitleBlockTemplateCellWidget::edited_cell_
◆ empty_label_
QLabel* TitleBlockTemplateCellWidget::empty_label_
◆ font_adjust_input_
QCheckBox* TitleBlockTemplateCellWidget::font_adjust_input_
◆ font_size_input_
QSpinBox* TitleBlockTemplateCellWidget::font_size_input_
◆ font_size_label_
QLabel* TitleBlockTemplateCellWidget::font_size_label_
◆ horiz_align_indexes_
QHash<int, int> TitleBlockTemplateCellWidget::horiz_align_indexes_
◆ horiz_align_input_
QComboBox* TitleBlockTemplateCellWidget::horiz_align_input_
◆ horiz_align_label_
QLabel* TitleBlockTemplateCellWidget::horiz_align_label_
◆ label_checkbox_
QCheckBox* TitleBlockTemplateCellWidget::label_checkbox_
◆ label_edit_
QPushButton* TitleBlockTemplateCellWidget::label_edit_
◆ label_input_
QLineEdit* TitleBlockTemplateCellWidget::label_input_
◆ logo_input_
QComboBox* TitleBlockTemplateCellWidget::logo_input_
◆ logo_label_
QLabel* TitleBlockTemplateCellWidget::logo_label_
◆ name_input_
QLineEdit* TitleBlockTemplateCellWidget::name_input_
◆ name_label_
QLabel* TitleBlockTemplateCellWidget::name_label_
◆ read_only_
bool TitleBlockTemplateCellWidget::read_only_
◆ value_edit_
QPushButton* TitleBlockTemplateCellWidget::value_edit_
◆ value_input_
QLineEdit* TitleBlockTemplateCellWidget::value_input_
◆ value_label_
QLabel* TitleBlockTemplateCellWidget::value_label_
◆ vert_align_indexes_
QHash<int, int> TitleBlockTemplateCellWidget::vert_align_indexes_
◆ vert_align_input_
QComboBox* TitleBlockTemplateCellWidget::vert_align_input_
◆ vert_align_label_
QLabel* TitleBlockTemplateCellWidget::vert_align_label_
