QElectroTech 0.200.1-dev
#include <templateview.h>
Inherits QGraphicsView.
Public Slots | |
| void | setTitleBlockTemplate (TitleBlockTemplate *) |
| void | selectionChanged () |
| void | zoomIn () |
| void | zoomOut () |
| void | zoomFit () |
| void | zoomReset () |
| QList< TitleBlockCell * > | cut () |
| QList< TitleBlockCell * > | copy () |
| bool | mayPaste () |
| QList< TitleBlockCell > | pastedCells () |
| void | paste () |
| void | addColumnAtEnd () |
| void | addRowAtEnd () |
| void | addColumnBefore () |
| void | addRowBefore () |
| void | addColumnAfter () |
| void | addRowAfter () |
| void | editColumn (HelperCell *=nullptr) |
| void | editRow (HelperCell *=nullptr) |
| void | deleteColumn () |
| void | deleteRow () |
| void | mergeSelectedCells () |
| void | splitSelectedCell () |
| void | refresh () |
| void | changePreviewWidth () |
| void | setPreviewWidth (int) |
| void | updateLayout () |
| void | rowsDimensionsChanged () |
| void | columnsDimensionsChanged () |
| void | updateDisplayedMinMaxWidth () |
| void | setReadOnly (bool) |
Signals | |
| void | selectedCellsChanged (QList< TitleBlockCell * >) |
| void | gridModificationRequested (TitleBlockTemplateCommand *) |
| void | previewWidthChanged (int, int) |
Public Member Functions | |
| TitleBlockTemplateView (QWidget *=nullptr) | |
| TitleBlockTemplateView (QGraphicsScene *, QWidget *=nullptr) | |
| TitleBlockTemplateView::TitleBlockTemplateView. | |
| ~TitleBlockTemplateView () override | |
| TitleBlockTemplate * | titleBlockTemplate () const |
| virtual QList< TitleBlockCell * > | selectedCells () const |
| virtual TitleBlockTemplateCellsSet | selectedCellsSet () const |
| virtual TitleBlockTemplateCellsSet | cells (const QRectF &) const |
| virtual void | analyzeSelectedCells (bool *, bool *, int *) |
| TitleBlockTemplateView::analyzeSelectedCells. | |
| virtual QSizeF | templateSize () const |
| virtual qreal | templateWidth () const |
| virtual qreal | templateHeight () const |
Protected Slots | |
| virtual void | applyColumnsWidths (bool=true) |
| virtual void | applyRowsHeights (bool=true) |
| virtual void | updateRowsHelperCells () |
| virtual void | updateColumnsHelperCells () |
Protected Member Functions | |
| void | drawBackground (QPainter *, const QRectF &) override |
| virtual void | addCells () |
| virtual void | loadTemplate (TitleBlockTemplate *) |
| virtual void | init () |
| void | wheelEvent (QWheelEvent *) override |
| virtual qreal | zoomFactor () const |
| virtual void | fillWithEmptyCells () |
| bool | event (QEvent *) override |
| virtual void | normalizeCells (QList< TitleBlockCell > &, int x=0, int y=0) const |
| TitleBlockTemplateView::normalizeCells Given a cells list, change their position so the top left one is at row x and column y. | |
Private Slots | |
| void | updateLastContextMenuCell (HelperCell *) |
| void | adjustSceneRect () |
Private Member Functions | |
| TitleBlockTemplateView (const TitleBlockTemplateView &) | |
| QList< QAction * > | rowsActions () const |
| QList< QAction * > | columnsActions () const |
| void | updateTotalWidthLabel () |
| void | requestGridModification (TitleBlockTemplateCommand *) |
| int | lastContextMenuCellIndex () const |
| int | indexOf (QGraphicsLayoutItem *) |
| void | removeItem (QGraphicsLayoutItem *) |
| TitleBlockTemplateCellsSet | makeCellsSetFromGraphicsItems (const QList< QGraphicsItem * > &) const |
| TitleBlockTemplateView::makeCellsSetFromGraphicsItems. | |
| QString | makePrettyToolTip (const QString &) |
| TitleBlockTemplateView::makePrettyToolTip. | |
Private Attributes | |
| TitleBlockTemplate * | tbtemplate_ |
| QGraphicsGridLayout * | tbgrid_ |
| QGraphicsWidget * | form_ |
| int | preview_width_ |
| SplittedHelperCell * | total_width_helper_cell_ |
| HelperCell * | extra_cells_width_helper_cell_ |
| QAction * | add_column_before_ |
| QAction * | add_row_before_ |
| QAction * | add_column_after_ |
| QAction * | add_row_after_ |
| QAction * | edit_column_dim_ |
| QAction * | edit_row_dim_ |
| QAction * | delete_column_ |
| QAction * | delete_row_ |
| QAction * | change_preview_width_ |
| HelperCell * | last_context_menu_cell_ |
| int | apply_columns_widths_count_ |
| int | apply_rows_heights_count_ |
| bool | first_activation_ |
| Boolean used to detect the first display of this widget. | |
| bool | read_only_ |
| Boolean stating whether this view allows template edition. | |
This QGraphicsView subclass is used in the title block template editor to offer a graphical preview of the template being edited, but also to handle cell selection and various actions.
| TitleBlockTemplateView::TitleBlockTemplateView | ( | QWidget * | parent = nullptr | ) |
Constructor
| parent | Parent QWidget. |
| TitleBlockTemplateView::TitleBlockTemplateView | ( | QGraphicsScene * | scene, |
| QWidget * | parent = nullptr ) |
| scene | |
override |
Destructor
private |
protectedvirtual |
Add the cells (both helper cells and regular visual cells) to the scene to get a visual representation of the edited title block template.
slot |
Add a column right after the last index selected when calling the context menu.
slot |
Add a column right after the last one.
slot |
Add a column right before the last index selected when calling the context menu.
slot |
Add a row right after the last index selected when calling the context menu.
slot |
Add a row right after the last one.
slot |
Add a row right before the last index selected when calling the context menu.
privateslot |
Adjusts the bounding rect of the scene.
virtual |
| can_merge | : If non-zero, will be changed to reflect whether selected cells may be merged |
| can_split | : If non-zero, will be changed to reflect whether selected cells may be splitted |
| count | : If non-zero, will be changed to reflect the number of selected cells |
protectedvirtualslot |
Apply the columns widths currently specified by the edited title block template.
| animate | true to animate the change, false otherwise. |
Apply the rows heights currently specified by the edited title block template.
virtual |
| rect | Rectangle in the coordinates of the QGraphicsWidget representing the title block template. |
slot |
Ask the user a new width for the preview
private |
slot |
Update the displayed layout. Call this function when the dimensions of columns changed.
slot |
Export currently selected cells to the clipboard.
slot |
Export currently selected cells to the clipboard before setting them as empty.
slot |
Remove the column at the last index selected when calling the context menu.
slot |
Remove the row at the last index selected when calling the context menu.
overrideprotected |
Reimplement the way the background is drawn to render the title block template.
slot |
Edit the width of a column.
| cell | (optional) HelperCell of the column to be modified. If 0, this method uses the last index selected when calling the context menu. |
slot |
Edit the height of a row.
| cell | (optional) HelperCell of the row to be modified. If 0, this method uses the last index selected when calling the context menu. |
overrideprotected |
| event | Object describing the received event |
protectedvirtual |
Fill the layout with empty cells where needed.
signal |
private |
| item | an item supposed to be contained in the grid layout. |
protectedvirtual |
Initialize this view (actions, signals/slots connections, etc.)
private |
protectedvirtual |
Load the tbt title block template. If a different template was previously loaded, it is deleted.
private |
| items | : a list of QGraphicsItem |
private |
| string | : a text string |
slot |
slot |
Merge the selected cells.
protectedvirtual |
| cells | Cells list |
| x | : row |
| y | : column |
slot |
Import the cells described in the clipboard.
slot |
signal |
slot |
Refresh the regular cells.
private |
Removes an item from the grid layout
private |
Emit the gridModificationRequested() signal with command after having set its view component.
| command | A command object modifying the rendered title block template. |
private |
slot |
Update the displayed layout. Call this function when the dimensions of rows changed.
virtual |
signal |
virtual |
slot |
Emits the selectedCellsChanged() signal with the currently selected cells.
slot |
Set the new preview width to width
| width | new preview width |
slot |
| read_only | whether this view should be read only. |
slot |
| tbtemplate | Title block template to be rendered by this view. If set to zero, the View will render nothing. |
slot |
Split the selected cell.
virtual |
virtual |
virtual |
| TitleBlockTemplate * TitleBlockTemplateView::titleBlockTemplate | ( | ) | const |
Update the content (type and value) of columns helper cells.
slot |
Update the tooltip that displays the minimum and/or maximum width of the template.
privateslot |
Stores last_context_menu_cell as being the last helper cell the context menu was triggered on.
slot |
Update the displayed layout. Call this function to refresh the display after the rendered title block template has been "deeply" modified, e.g. rows/columns have been added/modified or cells were merged/splitted.
Update the content (type and value) of rows helper cells.
private |
Update the label of the helper cell that indicates the preview width.
overrideprotected |
Handles mouse wheel-related actions
| e | QWheelEvent describing the wheel event |
protectedvirtual |
slot |
Fit the rendered title block template in this view.
slot |
Zoom in by zoomFactor().
slot |
Zoom out by zoomFactor().
slot |
Reset the zoom level.
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
private |
