18#ifndef TITLEBLOCK_TEMPLATE_H
19#define TITLEBLOCK_TEMPLATE_H
122 QString
name()
const;
142 bool insertRow(
int,
const QList<TitleBlockCell *> &,
int = -1);
143 QList<TitleBlockCell *>
takeRow(
int);
149 const QList<TitleBlockCell *> &,
int = -1);
156 QHash<TitleBlockCell *, QPair<int, int> >
getAllSpans()
const;
161 const QString & =
"svg",
162 const QString & =
"xml");
166 bool renameLogo(
const QString &,
const QString &);
168 QList<QString>
logos()
const;
169 QString
logoType(
const QString &)
const;
170 QSvgRenderer *
vectorLogo(
const QString &)
const;
183 const QRect &)
const;
195 bool loadLogos(
const QDomElement &,
bool =
false);
202 void saveLogo(
const QString &, QDomElement &)
const;
228 int lengthRange(
int,
int,
const QList<int> &)
const;
239 const QRectF &)
const;
Definition diagramcontext.h:92
Definition titleblockcell.h:26
QString logoType(const QString &) const
TitleBlockTemplate::logoType.
Definition titleblocktemplate.cpp:1534
void exportCellToXml(TitleBlockCell *, QDomElement &) const
TitleBlockTemplate::exportCellToXml.
Definition titleblocktemplate.cpp:186
void applyRowColNums()
TitleBlockTemplate::applyRowColNums Ensure all cells have the right col+row numbers.
Definition titleblocktemplate.cpp:2167
int maximumWidth()
TitleBlockTemplate::maximumWidth.
Definition titleblocktemplate.cpp:1058
QHash< QString, QString > storage_logos_
storage_logos_ : Logos applied storage type (e.g. "xml" or "base64")
Definition titleblocktemplate.h:266
int height() const
TitleBlockTemplate::height.
Definition titleblocktemplate.cpp:1090
QList< TitleBlockCell * > createRow()
TitleBlockTemplate::createRow.
Definition titleblocktemplate.cpp:1172
void applyCellSpan(TitleBlockCell *)
TitleBlockTemplate::applyCellSpan Ensure the spans of the provided cell are applied within the grid s...
Definition titleblocktemplate.cpp:2133
void saveGrid(QDomElement &) const
TitleBlockTemplate::saveGrid Export this template's cells grid as XML.
Definition titleblocktemplate.cpp:574
bool checkCell(const QDomElement &, TitleBlockCell **=nullptr)
TitleBlockTemplate::checkCell Load the essential attributes of a cell: row and column indices and spa...
Definition titleblocktemplate.cpp:658
QList< TitleBlockDimension > columns_width_
columns_width_ : columns widths –
Definition titleblocktemplate.h:286
bool loadFromXmlFile(const QString &)
TitleBlockTemplate::loadFromXmlFile Load a titleblock template from an XML file.
Definition titleblocktemplate.cpp:94
bool saveToXmlElement(QDomElement &) const
TitleBlockTemplate::saveToXmlElement Save the title block template as XML.
Definition titleblocktemplate.cpp:167
void forgetSpanning()
TitleBlockTemplate::forgetSpanning Set the spanner_cell attribute of every cell to 0.
Definition titleblocktemplate.cpp:2016
bool moveRow(int, int)
TitleBlockTemplate::moveRow Move a row within this template.
Definition titleblocktemplate.cpp:1106
void renderTextCell(QPainter &, const QString &, const TitleBlockCell &, const QRectF &) const
TitleBlockTemplate::renderTextCell This method uses a painter to render the text of a cell into the c...
Definition titleblocktemplate.cpp:1871
void applyCellSpans()
TitleBlockTemplate::applyCellSpans Forget any previously applied span, then apply again all spans def...
Definition titleblocktemplate.cpp:2054
bool renameLogo(const QString &, const QString &)
TitleBlockTemplate::renameLogo Rename the logo_name logo to new_name.
Definition titleblocktemplate.cpp:1482
QList< int > rows_heights_
rows heights – simple integers
Definition titleblocktemplate.h:281
bool addLogo(const QString &, QByteArray *, const QString &="svg", const QString &="xml")
TitleBlockTemplate::addLogo.
Definition titleblocktemplate.cpp:1352
TitleBlockCell * cell(int, int) const
TitleBlockTemplate::cell.
Definition titleblocktemplate.cpp:1253
void renderTextCellDxf(QString &, const QString &, const TitleBlockCell &, qreal, qreal, qreal, qreal, int) const
TitleBlockTemplate::renderTextCellDxf.
Definition titleblocktemplate.cpp:1926
QString name_
name_ : name identifying the Title Block Template within its parent collection
Definition titleblocktemplate.h:256
bool moveColumn(int, int)
TitleBlockTemplate::moveColumn Move the column at index "from" to index "to".
Definition titleblocktemplate.cpp:1184
bool loadLogos(const QDomElement &, bool=false)
TitleBlockTemplate::loadLogos Import the logos from a given XML titleblock template.
Definition titleblocktemplate.cpp:282
QList< TitleBlockCell * > registered_cells_
registered_cells_ : Cells objects created rattached to this template, but not mandatorily used
Definition titleblocktemplate.h:291
int minimumWidth()
TitleBlockTemplate::minimumWidth.
Definition titleblocktemplate.cpp:1026
void initCells()
TitleBlockTemplate::initCells Initialize the internal cells grid with the row and column counts....
Definition titleblocktemplate.cpp:719
QHash< TitleBlockCell *, QPair< int, int > > getAllSpans() const
TitleBlockTemplate::getAllSpans Export the span parameters of all cell in the current grid.
Definition titleblocktemplate.cpp:1311
void setAllSpans(const QHash< TitleBlockCell *, QPair< int, int > > &)
TitleBlockTemplate::setAllSpans Restore a set of span parameters.
Definition titleblocktemplate.cpp:1334
QHash< QString, QByteArray > data_logos_
data_logos_ : Logos raw data
Definition titleblocktemplate.h:261
QString finalTextForCell(const TitleBlockCell &, const DiagramContext &) const
TitleBlockTemplate::finalTextForCell.
Definition titleblocktemplate.cpp:1783
QList< int > rowsHeights() const
TitleBlockTemplate::rowsHeights.
Definition titleblocktemplate.cpp:909
std::optional< WidthConstraintCase > classifyWidthConstraint(int &abs_total, qreal &remaining_width_fraction)
TitleBlockTemplate::classifyWidthConstraint Classifies this template's absolute-width (ABS) and relat...
Definition titleblocktemplate.cpp:984
QStringList listOfVariables()
TitleBlockTemplate::listOfVariables Get list of variables.
Definition titleblocktemplate.cpp:1830
bool checkCellSpan(TitleBlockCell *)
TitleBlockTemplate::checkCellSpan Check whether a given cell can be spanned according to its row_span...
Definition titleblocktemplate.cpp:2077
void loadInformation(const QDomElement &)
TitleBlockTemplate::loadInformation Import text informations from a given XML title block template.
Definition titleblocktemplate.cpp:264
void parseColumns(const QString &)
TitleBlockTemplate::parseColumns Parse the columns widths.
Definition titleblocktemplate.cpp:422
void parseRows(const QString &)
TitleBlockTemplate::parseRows Parse the rows heights.
Definition titleblocktemplate.cpp:391
bool loadGrid(const QDomElement &)
Definition titleblocktemplate.cpp:359
void loadCell(const QDomElement &)
TitleBlockTemplate::loadCell Load a cell into this template.
Definition titleblocktemplate.cpp:495
QHash< QString, QSvgRenderer * > vector_logos_
vector_logos_ : Rendered objects for vector logos
Definition titleblocktemplate.h:275
bool insertColumn(const TitleBlockDimension &, const QList< TitleBlockCell * > &, int=-1)
TitleBlockTemplate::insertColumn.
Definition titleblocktemplate.cpp:1211
static QFont fontForCell(const TitleBlockCell &)
TitleBlockTemplate::fontForCell.
Definition titleblocktemplate.cpp:84
TitleBlockTemplate(const TitleBlockTemplate &)
int rowDimension(int)
TitleBlockTemplate::rowDimension.
Definition titleblocktemplate.cpp:765
int width(int)
TitleBlockTemplate::width.
Definition titleblocktemplate.cpp:1078
QString name() const
TitleBlockTemplate::name.
Definition titleblocktemplate.cpp:738
void render(QPainter &, const DiagramContext &, int) const
TitleBlockTemplate::render Render the titleblock.
Definition titleblocktemplate.cpp:1582
void rowColsChanged()
TitleBlockTemplate::rowColsChanged Take care of consistency and span-related problematics when adding...
Definition titleblocktemplate.cpp:2182
void saveCell(TitleBlockCell *, QDomElement &, bool=false) const
TitleBlockTemplate::saveCell Export a specific cell as XML.
Definition titleblocktemplate.cpp:620
~TitleBlockTemplate() override
TitleBlockTemplate::~TitleBlockTemplate Destructor.
Definition titleblocktemplate.cpp:43
QString interpreteVariables(const QString &, const DiagramContext &) const
TitleBlockTemplate::interpreteVariables.
Definition titleblocktemplate.cpp:1810
int columnTypeTotal(QET::TitleBlockColumnLength)
TitleBlockTemplate::columnTypeTotal.
Definition titleblocktemplate.cpp:934
QString information_
Definition titleblocktemplate.h:257
void setColumnDimension(int, const TitleBlockDimension &)
TitleBlockTemplate::setColumnDimension Set the width of a column.
Definition titleblocktemplate.cpp:806
TitleBlockCell * createCell(const TitleBlockCell *=nullptr)
TitleBlockTemplate::createCell Create a new cell and associate it with this template,...
Definition titleblocktemplate.cpp:56
TitleBlockTemplate(QObject *=nullptr)
TitleBlockTemplate::TitleBlockTemplate Constructor.
Definition titleblocktemplate.cpp:34
int rowsCount() const
TitleBlockTemplate::rowsCount.
Definition titleblocktemplate.cpp:828
void saveInformation(QDomElement &) const
TitleBlockTemplate::saveInformation Export this template's extra information.
Definition titleblocktemplate.cpp:507
QList< TitleBlockCell * > createCellsList(int)
TitleBlockTemplate::createCellsList.
Definition titleblocktemplate.cpp:72
QSet< TitleBlockCell * > spannedCells(const TitleBlockCell *, bool=false) const
TitleBlockTemplate::spannedCells.
Definition titleblocktemplate.cpp:1272
int columnsCount() const
TitleBlockTemplate::columnsCount.
Definition titleblocktemplate.cpp:819
void setRowDimension(int, const TitleBlockDimension &)
TitleBlockTemplate::setRowDimension Set the height of a row.
Definition titleblocktemplate.cpp:779
TitleBlockTemplate * clone() const
TitleBlockTemplate::clone.
Definition titleblocktemplate.cpp:198
QList< int > columnsWidth(int) const
TitleBlockTemplate::columnsWidth.
Definition titleblocktemplate.cpp:838
QList< QString > logos() const
TitleBlockTemplate::logos.
Definition titleblocktemplate.cpp:1522
bool removeLogo(const QString &)
TitleBlockTemplate::removeLogo.
Definition titleblocktemplate.cpp:1456
void setLogoStorage(const QString &, const QString &)
TitleBlockTemplate::setLogoStorage Set the kind of storage for the logo_name logo.
Definition titleblocktemplate.cpp:1511
QHash< QString, QPixmap > bitmap_logos_
bitmap_logos_ : Pixmaps for bitmap logos
Definition titleblocktemplate.h:279
void saveLogo(const QString &, QDomElement &) const
TitleBlockTemplate::saveLogo Export a specific logo as XML.
Definition titleblocktemplate.cpp:543
int columnTypeCount(QET::TitleBlockColumnLength)
TitleBlockTemplate::columnTypeCount.
Definition titleblocktemplate.cpp:919
TitleBlockDimension columnDimension(int)
TitleBlockTemplate::columnDimension.
Definition titleblocktemplate.cpp:792
QHash< QString, QString > type_logos_
type_logos_ : Logos types (e.g. "png", "jpeg", "svg")
Definition titleblocktemplate.h:271
QSvgRenderer * vectorLogo(const QString &) const
TitleBlockTemplate::vectorLogo.
Definition titleblocktemplate.cpp:1549
QList< QList< TitleBlockCell * > > cells_
Cells grid.
Definition titleblocktemplate.h:292
QString information() const
TitleBlockTemplate::information.
Definition titleblocktemplate.cpp:747
void renderDxf(QRectF &, const DiagramContext &, int, QString &, int) const
TitleBlockTemplate::renderDxf Render the titleblock in DXF.
Definition titleblocktemplate.cpp:1644
bool loadLogo(const QDomElement &)
TitleBlockTemplate::loadLogo Import the logo from a given XML logo description.
Definition titleblocktemplate.cpp:321
bool loadCells(const QDomElement &)
TitleBlockTemplate::loadCells Analyze an XML element, looking for grid cells. The grid cells are chec...
Definition titleblocktemplate.cpp:473
void addRow(int=-1)
TitleBlockTemplate::addRow Add a new 25px-wide row at the provided index.
Definition titleblocktemplate.cpp:1123
void saveLogos(QDomElement &) const
TitleBlockTemplate::saveLogos Export this template's logos as XML.
Definition titleblocktemplate.cpp:524
QPixmap bitmapLogo(const QString &) const
TitleBlockTemplate::bitmapLogo.
Definition titleblocktemplate.cpp:1564
void addColumn(int=-1)
TitleBlockTemplate::addColumn Add a new 50px-wide column at the provided index.
Definition titleblocktemplate.cpp:1199
QList< TitleBlockCell * > takeColumn(int)
TitleBlockTemplate::takeColumn Removes the column at index i.
Definition titleblocktemplate.cpp:1227
bool loadFromXmlElement(const QDomElement &)
TitleBlockTemplate::loadFromXmlElement.
Definition titleblocktemplate.cpp:123
int lengthRange(int, int, const QList< int > &) const
TitleBlockTemplate::lengthRange.
Definition titleblocktemplate.cpp:2197
QList< TitleBlockCell * > createColumn()
TitleBlockTemplate::createColumn.
Definition titleblocktemplate.cpp:1242
bool saveToXmlFile(const QString &)
TitleBlockTemplate::saveToXmlFile Save the title block template into an XML file.
Definition titleblocktemplate.cpp:147
WidthConstraintCase
The TitleBlockTemplate::WidthConstraintCase enum Distinguishes the possible outcomes of minimumWidth(...
Definition titleblocktemplate.h:67
@ Unconstrained
Definition titleblocktemplate.h:82
@ RelativeWidthExceeds100Percent
Definition titleblocktemplate.h:92
@ AbsoluteColumnsExceedRemainingWidth
Definition titleblocktemplate.h:103
void saveCells(QDomElement &) const
TitleBlockTemplate::saveCells Export this template's cells as XML (without the grid-related informati...
Definition titleblocktemplate.cpp:599
void renderCell(QPainter &, const TitleBlockCell &, const DiagramContext &, const QRect &) const
TitleBlockTemplate::renderCell Render a titleblock cell.
Definition titleblocktemplate.cpp:1731
QList< TitleBlockCell * > takeRow(int)
TitleBlockTemplate::takeRow Removes the row at index i.
Definition titleblocktemplate.cpp:1156
bool saveLogoToFile(const QString &, const QString &)
TitleBlockTemplate::saveLogoToFile.
Definition titleblocktemplate.cpp:1435
bool insertRow(int, const QList< TitleBlockCell * > &, int=-1)
TitleBlockTemplate::insertRow.
Definition titleblocktemplate.cpp:1137
void setInformation(const QString &)
TitleBlockTemplate::setInformation.
Definition titleblocktemplate.cpp:756
bool addLogoFromFile(const QString &, const QString &=QString())
TitleBlockTemplate::addLogoFromFile.
Definition titleblocktemplate.cpp:1406
enum used to specify the type of a length
Definition qet.h:142
Definition dimension.h:26
