ConductorProperties Class Reference
The ConductorProperties class This class represents the functional properties of a particular conductor, i.e. properties other than path and terminals. More...
#include <conductorproperties.h>
Collaboration diagram for ConductorProperties:
Public Types
enum  ConductorType { Single , Multi }
 The ConductorType enum Represents the kind of a particular conductor: Single: singleline symbols, no text input Multi: text input, no symbol. More...
 ConductorProperties ()
virtual ~ConductorProperties ()
void toXml (QDomElement &) const
 ConductorProperties::toXml Export conductor properties to the XML element 'e'.
void fromXml (QDomElement &)
 ConductorProperties::fromXml Import conductor properties from the attribute of the xml element 'e'.
void toSettings (QSettings &, const QString &=QString()) const
void fromSettings (QSettings &, const QString &=QString())
void applyForEqualAttributes (QList< ConductorProperties > list)
 ConductorProperties::applyForEqualAttributes Test each attribute of properties in the list separatly. For each attributes, if is equal, the attribute is apply to this.
bool operator== (const ConductorProperties &) const
 ConductorProperties::operator ==.
bool operator!= (const ConductorProperties &) const
static QString typeToString (ConductorType)
static ConductorProperties defaultProperties ()
 ConductorProperties::defaultProperties.
Public Attributes
ConductorType type
QColor color
QColor m_color_2
QColor text_color
QString text
QString m_function
QString m_tension_protocol
QString m_wire_color
QString m_wire_section
QString m_formula
QString m_bus
QString m_cable
int text_size
int m_dash_size = 1
double cond_size
double verti_rotate_text
double horiz_rotate_text
bool m_show_text
bool m_one_text_per_folio
bool m_bicolor = false
Qt::Alignment m_horizontal_alignment = Qt::AlignBottom
Qt::Alignment m_vertical_alignment = Qt::AlignRight
Qt::PenStyle style
SingleLineProperties singleLineProperties
void readStyle (const QString &)
QString writeStyle () const
◆ ConductorType
Enumerator
Single
Multi
◆ ConductorProperties()
ConductorProperties::ConductorProperties ( )
Constructeur : par defaut, les proprietes font un conducteur multifilaire noir dont le texte est "_"
◆ ~ConductorProperties()
ConductorProperties::~ConductorProperties ( )
virtual
Destructeur
◆ applyForEqualAttributes()
void ConductorProperties::applyForEqualAttributes ( QList< ConductorProperties > list)
list
◆ defaultProperties()
ConductorProperties ConductorProperties::defaultProperties ( )
static
the default properties stored in the setting file
◆ fromSettings()
void ConductorProperties::fromSettings ( QSettings & settings,
const QString & prefix = QString() )
settingsParametres a lire
prefixprefixe a ajouter devant les noms des parametres
◆ fromXml()
void ConductorProperties::fromXml ( QDomElement & e)
ethe xml document
◆ operator!=()
bool ConductorProperties::operator!= ( const ConductorProperties & other) const
otherl'autre ensemble de proprietes avec lequel il faut effectuer la comparaison
true si les deux ensembles de proprietes sont differents, false sinon
◆ operator==()
bool ConductorProperties::operator== ( const ConductorProperties & other) const
other
true if other == this
◆ readStyle()
void ConductorProperties::readStyle ( const QString & style_string)
Applique les styles passes en parametre dans cet objet
style_stringChaine decrivant le style du conducteur
◆ toSettings()
void ConductorProperties::toSettings ( QSettings & settings,
const QString & prefix = QString() ) const
settingsParametres a ecrire
◆ toXml()
void ConductorProperties::toXml ( QDomElement & e) const
ethe xml element
◆ typeToString()
QString ConductorProperties::typeToString ( ConductorType t)
static
ttype du conducteur
◆ writeStyle()
QString ConductorProperties::writeStyle ( ) const
Exporte le style du conducteur sous forme d'une chaine de caracteres
une chaine de caracteres decrivant le style du conducteur
◆ color
QColor ConductorProperties::color
◆ cond_size
double ConductorProperties::cond_size
◆ horiz_rotate_text
double ConductorProperties::horiz_rotate_text
◆ m_bicolor
bool ConductorProperties::m_bicolor = false
◆ m_bus
QString ConductorProperties::m_bus
◆ m_cable
QString ConductorProperties::m_cable
◆ m_color_2
QColor ConductorProperties::m_color_2
◆ m_dash_size
int ConductorProperties::m_dash_size = 1
◆ m_formula
QString ConductorProperties::m_formula
◆ m_function
QString ConductorProperties::m_function
◆ m_horizontal_alignment
Qt::Alignment ConductorProperties::m_horizontal_alignment = Qt::AlignBottom
◆ m_one_text_per_folio
bool ConductorProperties::m_one_text_per_folio
◆ m_show_text
bool ConductorProperties::m_show_text
◆ m_tension_protocol
QString ConductorProperties::m_tension_protocol
◆ m_vertical_alignment
Qt::Alignment ConductorProperties::m_vertical_alignment = Qt::AlignRight
◆ m_wire_color
QString ConductorProperties::m_wire_color
◆ m_wire_section
QString ConductorProperties::m_wire_section
◆ singleLineProperties
SingleLineProperties ConductorProperties::singleLineProperties
◆ style
Qt::PenStyle ConductorProperties::style
◆ text
QString ConductorProperties::text
◆ text_color
QColor ConductorProperties::text_color
◆ text_size
int ConductorProperties::text_size
◆ type
ConductorType ConductorProperties::type
◆ verti_rotate_text
double ConductorProperties::verti_rotate_text
