TitleBlockTemplateRenderer Class Reference
The TitleBlockTemplateRenderer class. More...
#include <titleblocktemplaterenderer.h>
Inherits QObject.
Collaboration diagram for TitleBlockTemplateRenderer:
 TitleBlockTemplateRenderer (QObject *=nullptr)
 TitleBlockTemplateRenderer::TitleBlockTemplateRenderer Constructor.
 ~TitleBlockTemplateRenderer () override
 TitleBlockTemplateRenderer::~TitleBlockTemplateRenderer Destructor.
const TitleBlockTemplate * titleBlockTemplate () const
 TitleBlockTemplateRenderer::titleBlockTemplate.
void setTitleBlockTemplate (const TitleBlockTemplate *)
 TitleBlockTemplateRenderer::setTitleBlockTemplate.
void setContext (const DiagramContext &context)
 TitleBlockTemplateRenderer::setContext.
DiagramContext context () const
 TitleBlockTemplateRenderer::context.
int height () const
 TitleBlockTemplateRenderer::height.
void render (QPainter *, int)
 TitleBlockTemplateRenderer::render Render the titleblock.
void renderDxf (QRectF &, int, QString &, int)
 TitleBlockTemplateRenderer::renderDxf.
void invalidateRenderedTemplate ()
 TitleBlockTemplateRenderer::invalidateRenderedTemplate Invalidates the previous rendering of the template by resetting the internal QPicture.
void setUseCache (bool)
 TitleBlockTemplateRenderer::setUseCache.
bool useCache () const
 TitleBlockTemplateRenderer::useCache.
void renderToQPicture (int)
 TitleBlockTemplateRenderer::renderToQPicture Renders the titleblock to the internal QPicture.
const TitleBlockTemplate * m_titleblock_template
bool m_use_cache
QPicture m_rendered_template
DiagramContext m_context
int m_last_known_titleblock_width
◆ TitleBlockTemplateRenderer()
TitleBlockTemplateRenderer::TitleBlockTemplateRenderer ( QObject * parent = nullptr)
parent: Parent QObject of this renderer
◆ ~TitleBlockTemplateRenderer()
TitleBlockTemplateRenderer::~TitleBlockTemplateRenderer ( )
◆ context()
DiagramContext TitleBlockTemplateRenderer::context ( ) const
the current diagram context use when render the titleblock
◆ height()
int TitleBlockTemplateRenderer::height ( ) const
the height of the rendered template, or -1 if no template has been set for this renderer.
See also
TitleBlockTemplate::height()
◆ invalidateRenderedTemplate()
void TitleBlockTemplateRenderer::invalidateRenderedTemplate ( )
◆ render()
void TitleBlockTemplateRenderer::render ( QPainter * provided_painter,
int titleblock_width )
provided_painter: QPainter to use to render the titleblock.
titleblock_width: The total width of the titleblock to render
◆ renderDxf()
void TitleBlockTemplateRenderer::renderDxf ( QRectF & title_block_rect,
int titleblock_width,
QString & file_path,
int color )
title_block_rect
titleblock_width
file_path
color
◆ renderToQPicture()
void TitleBlockTemplateRenderer::renderToQPicture ( int titleblock_width)
titleblock_width: Width of the titleblock to render
◆ setContext()
void TitleBlockTemplateRenderer::setContext ( const DiagramContext & context)
context: Context to use when rendering the titleblock
◆ setTitleBlockTemplate()
void TitleBlockTemplateRenderer::setTitleBlockTemplate ( const TitleBlockTemplate * titleblock_template)
titleblock_template: TitleBlock template to render.
◆ setUseCache()
void TitleBlockTemplateRenderer::setUseCache ( bool use_cache)
use_cache: true for this renderer to use its QPicture-based cache, false otherwise.
◆ titleBlockTemplate()
const TitleBlockTemplate * TitleBlockTemplateRenderer::titleBlockTemplate ( ) const
the titleblock template used for the rendering
◆ useCache()
bool TitleBlockTemplateRenderer::useCache ( ) const
true if this renderer uses its QPicture-based cache, false otherwise.
◆ m_context
DiagramContext TitleBlockTemplateRenderer::m_context
◆ m_last_known_titleblock_width
int TitleBlockTemplateRenderer::m_last_known_titleblock_width
◆ m_rendered_template
QPicture TitleBlockTemplateRenderer::m_rendered_template
◆ m_titleblock_template
const TitleBlockTemplate* TitleBlockTemplateRenderer::m_titleblock_template
◆ m_use_cache
bool TitleBlockTemplateRenderer::m_use_cache
