ProjectDBModel Class Reference
The ProjectDBModel class This model is intended to be use with the class projectDataBase and is designed to be displayed by the class QetGraphicsTableItem (but can be use by other view class since it inherit from QAbstractTableModel). This class should be sufficient to display the content of the project data base from a query set by the method void ProjectDBModel::setQuery(const QString &query). The indentifier method is used by widget editor to retrieve the good widget for edit the query. By default identifer returns the string 'unknow'. You should use setIdentfier method to set your custom identifier. At the time this sentence is written, there is two identifier : nomenclature summary. More...
#include <projectdbmodel.h>
Inherits QAbstractTableModel.
Collaboration diagram for ProjectDBModel:
 ProjectDBModel (QETProject *project, QObject *parent=nullptr)
 ProjectDBModel::ProjectDBModel.
 ProjectDBModel (const ProjectDBModel &other_model)
int rowCount (const QModelIndex &parent=QModelIndex()) const override
 ProjectDBModel::rowCount Reimplemented for QAbstractTableModel.
int columnCount (const QModelIndex &parent=QModelIndex()) const override
 ProjectDBModel::columnCount Reimplemented for QAbstractTableModel.
bool setHeaderData (int section, Qt::Orientation orientation, const QVariant &value, int role=Qt::EditRole) override
 ProjectDBModel::setHeaderData Reimplemented from QAbstractTableModel. Only horizontal orientation is accepted.
QVariant headerData (int section, Qt::Orientation orientation, int role=Qt::DisplayRole) const override
 ProjectDBModel::headerData Reimplemented from QAbstractTableModel.
bool setData (const QModelIndex &index, const QVariant &value, int role=Qt::EditRole) override
 ProjectDBModel::setData Only store the data for the index 0.0.
QVariant data (const QModelIndex &index, int role=Qt::DisplayRole) const override
 ProjectDBModel::data Reimplemented for QAbstractTableModel.
void setQuery (const QString &setQuery)
 ProjectDBModel::setQuery Query the internal bd with query.
QString queryString () const
 ProjectDBModel::queryString.
QETProject * project () const
QDomElement toXml (QDomDocument &document) const
 ProjectDBModel::toXml Save the model to xml,since model can have unlimited data we only save few data (only these used by qelectrotech). The query, all header data. and some data of index::(0,0). All other data are not saved.
void fromXml (const QDomElement &element)
 ProjectDBModel::fromXml Restore the model from xml.
void setIdentifier (const QString &identifier)
 ProjectDBModel::setIdentifier Set the identifier of this model to identifier.
QString identifier () const
static QString xmlTagName ()
void dataBaseUpdated ()
 ProjectDBModel::dataBaseUpdated slot called when the project database is updated.
void setHeaderString ()
void fillValue ()
QPointer< QETProject > m_project
QString m_query
QVector< QStringList > m_record
QHash< int, QHash< int, QVariant > > m_header_data
QHash< int, QVariant > m_index_0_0_data
QString m_identifier = "unknow"
◆ ProjectDBModel() [1/2]
ProjectDBModel::ProjectDBModel ( QETProject * project,
QObject * parent = nullptr )
explicit
project:project of this nomenclature
parent: parent QObject
◆ ProjectDBModel() [2/2]
ProjectDBModel::ProjectDBModel ( const ProjectDBModel & other_model)
explicit
other_model
◆ columnCount()
int ProjectDBModel::columnCount ( const QModelIndex & parent = QModelIndex()) const
parent
◆ data()
QVariant ProjectDBModel::data ( const QModelIndex & index,
int role = Qt::DisplayRole ) const
index
role
◆ dataBaseUpdated()
void ProjectDBModel::dataBaseUpdated ( )
◆ fillValue()
void ProjectDBModel::fillValue ( )
◆ fromXml()
void ProjectDBModel::fromXml ( const QDomElement & element)
element
◆ headerData()
QVariant ProjectDBModel::headerData ( int section,
section
orientation
role
◆ identifier()
QString ProjectDBModel::identifier ( ) const
inline
◆ project()
QETProject * ProjectDBModel::project ( ) const
◆ queryString()
QString ProjectDBModel::queryString ( ) const
the current query used by this model
◆ rowCount()
int ProjectDBModel::rowCount ( const QModelIndex & parent = QModelIndex()) const
parent
◆ setData()
bool ProjectDBModel::setData ( const QModelIndex & index,
const QVariant & value,
int role = Qt::EditRole )
index
value
role
◆ setHeaderData()
bool ProjectDBModel::setHeaderData ( int section,
section
orientation
value
role
◆ setHeaderString()
void ProjectDBModel::setHeaderString ( )
◆ setIdentifier()
void ProjectDBModel::setIdentifier ( const QString & identifier)
identifier
◆ setQuery()
void ProjectDBModel::setQuery ( const QString & query)
query
◆ toXml()
QDomElement ProjectDBModel::toXml ( QDomDocument & document) const
document
◆ xmlTagName()
QString ProjectDBModel::xmlTagName ( )
inlinestatic
◆ m_header_data
QHash<int, QHash<int, QVariant> > ProjectDBModel::m_header_data
◆ m_identifier
QString ProjectDBModel::m_identifier = "unknow"
◆ m_index_0_0_data
QHash<int, QVariant> ProjectDBModel::m_index_0_0_data
◆ m_project
QPointer<QETProject> ProjectDBModel::m_project
◆ m_query
QString ProjectDBModel::m_query
◆ m_record
QVector<QStringList> ProjectDBModel::m_record
