GraphicsTablePropertiesEditor Class Reference
The GraphicsTablePropertiesEditor class This widget is used to edit the property of both QetGraphicsTableItem and QetGraphicsHeaderItem. More...
#include <graphicstablepropertieseditor.h>
Inheritance diagram for GraphicsTablePropertiesEditor:
Collaboration diagram for GraphicsTablePropertiesEditor:
 GraphicsTablePropertiesEditor (QetGraphicsTableItem *table=nullptr, QWidget *parent=nullptr)
 GraphicsTablePropertiesEditor::GraphicsTablePropertiesEditor.
 ~GraphicsTablePropertiesEditor () override
 GraphicsTablePropertiesEditor::~GraphicsTablePropertiesEditor.
void setTable (QetGraphicsTableItem *table)
 GraphicsTablePropertiesEditor::setTable Set the table to be edited.
virtual void apply () override
 GraphicsTablePropertiesEditor::apply Apply the current edition.
QUndoCommand * associatedUndo () const override
 GraphicsTablePropertiesEditor::associatedUndo.
virtual bool setLiveEdit (bool live_edit) override
 PropertiesEditorWidget::setLiveEdit Set the editor in live edit mode. When an editor is in live edit mode, every change is applied immediately (no need to call apply). If live edit can be enabled, return true, or else false. By default this method does nothing and returns false (live edit is disabled). Inherited class of PropertiesEditorWidget must reimplement this method to manage the live edit mode.
Public Member Functions inherited from PropertiesEditorWidget
 PropertiesEditorWidget (QWidget *parent=nullptr)
 PropertiesEditorWidget::PropertiesEditorWidget Constructor.
virtual void reset ()
virtual QString title () const
virtual void updateUi ()
bool isLiveEdit () const
 PropertiesEditorWidget::isLiveEdit.
Private Slots
void on_m_header_font_pb_clicked ()
 GraphicsTablePropertiesEditor::on_m_header_font_pb_clicked.
void on_m_table_font_pb_clicked ()
 GraphicsTablePropertiesEditor::on_m_table_font_pb_clicked.
virtual void updateUi () override
 GraphicsTablePropertiesEditor::updateUi.
void updatePosWidget ()
void updateInfoLabel ()
void on_m_table_name_le_textEdited (const QString &arg1)
void on_m_previous_table_cb_activated (int index)
void on_m_previous_pb_clicked ()
void on_m_next_pb_clicked ()
void on_m_auto_geometry_pb_clicked ()
 GraphicsTablePropertiesEditor::on_m_auto_geometry_pb_clicked.
void on_m_apply_geometry_to_linked_table_pb_clicked ()
 GraphicsTablePropertiesEditor::on_m_apply_geometry_to_linked_table_pb_clicked.
void setUpEditConnection ()
 GraphicsTablePropertiesEditor::setUpEditConnection.
Ui::GraphicsTablePropertiesEditor * ui
QPointer< QetGraphicsTableItem > m_table_item
QList< QMetaObject::Connection > m_connect_list
QList< QMetaObject::Connection > m_edit_connection
QButtonGroup * m_header_button_group = nullptr
QButtonGroup * m_table_button_group = nullptr
QWidget * m_current_model_editor = nullptr
QVector< QetGraphicsTableItem * > m_other_table_vector
Additional Inherited Members
Protected Member Functions inherited from PropertiesEditorWidget
virtual void enableLiveEdit ()
virtual void disableLiveEdit ()
Protected Attributes inherited from PropertiesEditorWidget
bool m_live_edit
◆ GraphicsTablePropertiesEditor()
GraphicsTablePropertiesEditor::GraphicsTablePropertiesEditor ( QetGraphicsTableItem * table = nullptr,
QWidget * parent = nullptr )
explicit
table
parent
◆ ~GraphicsTablePropertiesEditor()
GraphicsTablePropertiesEditor::~GraphicsTablePropertiesEditor ( )
◆ apply()
void GraphicsTablePropertiesEditor::apply ( )
overridevirtual
◆ associatedUndo()
QUndoCommand * GraphicsTablePropertiesEditor::associatedUndo ( ) const
overridevirtual
the undo command associated to the edition
◆ on_m_apply_geometry_to_linked_table_pb_clicked
void GraphicsTablePropertiesEditor::on_m_apply_geometry_to_linked_table_pb_clicked ( )
privateslot
◆ on_m_auto_geometry_pb_clicked
void GraphicsTablePropertiesEditor::on_m_auto_geometry_pb_clicked ( )
privateslot
◆ on_m_header_font_pb_clicked
void GraphicsTablePropertiesEditor::on_m_header_font_pb_clicked ( )
privateslot
◆ on_m_next_pb_clicked
void GraphicsTablePropertiesEditor::on_m_next_pb_clicked ( )
privateslot
◆ on_m_previous_pb_clicked
void GraphicsTablePropertiesEditor::on_m_previous_pb_clicked ( )
privateslot
◆ on_m_previous_table_cb_activated
void GraphicsTablePropertiesEditor::on_m_previous_table_cb_activated ( int index)
privateslot
◆ on_m_table_font_pb_clicked
void GraphicsTablePropertiesEditor::on_m_table_font_pb_clicked ( )
privateslot
◆ on_m_table_name_le_textEdited
void GraphicsTablePropertiesEditor::on_m_table_name_le_textEdited ( const QString & arg1)
privateslot
◆ setLiveEdit()
bool GraphicsTablePropertiesEditor::setLiveEdit ( bool live_edit)
overridevirtual
live_edittrue to enable live edit
true if live edit is enabled, else false.
◆ setTable()
void GraphicsTablePropertiesEditor::setTable ( QetGraphicsTableItem * table)
table
◆ setUpEditConnection()
void GraphicsTablePropertiesEditor::setUpEditConnection ( )
◆ updateInfoLabel
void GraphicsTablePropertiesEditor::updateInfoLabel ( )
privateslot
◆ updatePosWidget
void GraphicsTablePropertiesEditor::updatePosWidget ( )
privateslot
◆ updateUi
void GraphicsTablePropertiesEditor::updateUi ( )
overrideprivatevirtualslot
◆ m_connect_list
QList<QMetaObject::Connection> GraphicsTablePropertiesEditor::m_connect_list
◆ m_current_model_editor
QWidget* GraphicsTablePropertiesEditor::m_current_model_editor = nullptr
◆ m_edit_connection
QList<QMetaObject::Connection> GraphicsTablePropertiesEditor::m_edit_connection
◆ m_header_button_group
QButtonGroup* GraphicsTablePropertiesEditor::m_header_button_group = nullptr
◆ m_other_table_vector
QVector<QetGraphicsTableItem *> GraphicsTablePropertiesEditor::m_other_table_vector
◆ m_table_button_group
QButtonGroup * GraphicsTablePropertiesEditor::m_table_button_group = nullptr
◆ m_table_item
QPointer<QetGraphicsTableItem> GraphicsTablePropertiesEditor::m_table_item
◆ ui
Ui::GraphicsTablePropertiesEditor* GraphicsTablePropertiesEditor::ui
