18#ifndef TERMINALSTRIPEDITOR_H
19#define TERMINALSTRIPEDITOR_H
53 QPair<TerminalStripModel::Column, QVector<modelRealTerminalData>>
singleColumnData()
const;
69 Ui::TerminalStripEditor *
ui;
Definition qetproject.h:62
The TerminalStripEditor class Main dialog used to edit terminal strip of a project.
Definition terminalstripeditor.h:38
~TerminalStripEditor() override
TerminalStripEditor::~TerminalStripEditor.
Definition terminalstripeditor.cpp:83
void on_m_group_terminals_pb_clicked()
TerminalStripEditor::on_m_group_terminals_pb_clicked.
Definition terminalstripeditor.cpp:447
void on_m_bridge_color_cb_activated(const QColor &col)
Definition terminalstripeditor.cpp:670
TerminalStripModel * m_model
Definition terminalstripeditor.h:72
TerminalStripModel::Column isSingleColumnSelected() const
TerminalStripEditor::isSingleColumnSelected If all current QModelIndex are in the same column return ...
Definition terminalstripeditor.cpp:388
void on_m_type_cb_activated(int index)
Definition terminalstripeditor.cpp:525
void on_m_auto_ordering_pb_clicked()
TerminalStripEditor::on_m_auto_pos_pb_clicked.
Definition terminalstripeditor.cpp:437
void on_m_bridge_terminals_pb_clicked()
TerminalStripEditor::on_m_bridge_terminals_pb_clicked.
Definition terminalstripeditor.cpp:608
void on_m_function_cb_activated(int index)
Definition terminalstripeditor.cpp:558
QSize setUpBridgeCellWidth()
Definition terminalstripeditor.cpp:362
void on_m_led_cb_activated(int index)
Definition terminalstripeditor.cpp:587
void on_m_ungroup_pb_clicked()
TerminalStripEditor::on_m_ungroup_pb_clicked.
Definition terminalstripeditor.cpp:490
Ui::TerminalStripEditor * ui
Definition terminalstripeditor.h:69
void selectionChanged()
TerminalStripEditor::selectionChanged Update the editor according to the current selection.
Definition terminalstripeditor.cpp:259
QPair< TerminalStripModel::Column, QVector< modelRealTerminalData > > singleColumnData() const
TerminalStripEditor::singleColumnData.
Definition terminalstripeditor.cpp:418
void on_m_unbridge_terminals_pb_clicked()
TerminalStripEditor::on_m_unbridge_terminals_pb_clicked.
Definition terminalstripeditor.cpp:641
void reload()
TerminalStripEditor::reload Reload this editor and and reset all unapplied change.
Definition terminalstripeditor.cpp:170
TerminalStrip * m_current_strip
Definition terminalstripeditor.h:71
void on_m_move_to_pb_clicked()
Definition terminalstripeditor.cpp:693
void on_m_level_sb_valueChanged(int arg1)
TerminalStripEditor::on_m_level_sb_valueChanged.
Definition terminalstripeditor.cpp:508
void setCurrentStrip(TerminalStrip *strip_)
TerminalStripEditor::setCurrentStrip Set the current terminal strip edited to strip_.
Definition terminalstripeditor.cpp:92
void apply()
TerminalStripEditor::apply Apply current edited values.
Definition terminalstripeditor.cpp:191
QETProject * m_project
Definition terminalstripeditor.h:70
void spanMultiLevelTerminals()
TerminalStripEditor::spanMultiLevelTerminals Span row of m_table_widget for multi-level terminal.
Definition terminalstripeditor.cpp:237
The TerminalStrip class This class hold all the datas and configurations of a terminal strip (but the...
Definition terminalstrip.h:45
Definition terminalstripmodel.h:47
Column
Definition terminalstripmodel.h:49
Definition autonumberingdockwidget.h:26
