QElectroTech 0.100.0-dev
The XRefPropertiesWidget class This class provide a widget to edit the XRefProperties. More...
#include <xrefpropertieswidget.h>
Inherits QWidget.
Public Member Functions | |
| XRefPropertiesWidget (QHash< QString, XRefProperties > properties=QHash< QString, XRefProperties >(), QWidget *parent=nullptr) | |
| XRefPropertiesWidget::XRefPropertiesWidget Default constructor. | |
| ~XRefPropertiesWidget () override | |
| XRefPropertiesWidget::~XRefPropertiesWidget Default destructor. | |
| void | setProperties (const QHash< QString, XRefProperties > &properties) |
| XRefPropertiesWidget::setProperties set new properties for this widget. | |
| QHash< QString, XRefProperties > | properties () |
| XRefPropertiesWidget::properties. | |
| void | setReadOnly (bool=true) |
| XRefPropertiesWidget::setReadOnly Set all of this widget disable if true. | |
Private Slots | |
| void | updateDisplay () |
| XRefPropertiesWidget::updateDisplay Update display with the current displayed type. | |
| void | typeChanged () |
| XRefPropertiesWidget::typeChanged manage the save of the current properties, when the combo box of type change. | |
| void | enableOffsetSB (int i) |
| XRefPropertiesWidget::enableOffsetSB Enable Offset SB only if Snap to Footer is selected. | |
Private Member Functions | |
| void | buildUi () |
| XRefPropertiesWidget::buildUi Build some widget of this ui. | |
| void | saveProperties (int index) |
| XRefPropertiesWidget::saveProperties Save the properties of the type define at index of the combo box m_type_cb. | |
Private Attributes | |
| Ui::XRefPropertiesWidget * | ui |
| QHash< QString, XRefProperties > | m_properties |
| int | m_previous_type_index |
| XRefPropertiesWidget::XRefPropertiesWidget | ( | QHash< QString, XRefProperties > | properties = QHash <QString, XRefProperties>(), |
| QWidget * | parent = nullptr |
| properties | properties to use |
| parent | parent widget |
override |
private |
privateslot |
| QHash< QString, XRefProperties > XRefPropertiesWidget::properties | ( | ) |
private |
| index |
| void XRefPropertiesWidget::setProperties | ( | const QHash< QString, XRefProperties > & | properties | ) |
| properties |
| void XRefPropertiesWidget::setReadOnly | ( | bool | ro = true | ) |
| ro |
privateslot |
privateslot |
private |
private |
private |
