ScalePartsCommand Class Reference
#include <editorcommands.h>
Inheritance diagram for ScalePartsCommand:
Collaboration diagram for ScalePartsCommand:
 ScalePartsCommand (ElementScene *=nullptr, QUndoCommand *=nullptr)
 ~ScalePartsCommand () override
void undo () override
void redo () override
ElementScene * elementScene () const
void setScaledPrimitives (const QList< CustomElementPart * > &)
QList< CustomElementPart * > scaledPrimitives () const
void setTransformation (const QRectF &, const QRectF &)
 ScalePartsCommand::setTransformation Define the transformation applied by this command.
QPair< QRectF, QRectF > transformation ()
Public Member Functions inherited from ElementEditionCommand
 ElementEditionCommand (ElementScene *=nullptr, ElementView *=nullptr, QUndoCommand *=nullptr)
 ElementEditionCommand::ElementEditionCommand Constructs an ElementEditionCommand, thus embedding the provided scene and view.
 ElementEditionCommand (const QString &, ElementScene *=nullptr, ElementView *=nullptr, QUndoCommand *=nullptr)
 ~ElementEditionCommand () override
void setElementScene (ElementScene *)
ElementView * elementView () const
void setElementView (ElementView *)
Protected Member Functions
void scale (const QRectF &before, const QRectF &after)
void adjustText ()
 ScalePartsCommand (const ScalePartsCommand &)
QList< CustomElementPart * > scaled_primitives_
 List of moved primitives.
QRectF original_rect_
 original rect items fit in
QRectF new_rect_
 new rect items should fit in
bool first_redo
 Prevent the first call to redo().
Additional Inherited Members
Protected Attributes inherited from ElementEditionCommand
ElementScene * m_scene
 Element editor/view/scene the command should take place on.
ElementView * m_view
This command scales primitives when editing an electrical element.
◆ ScalePartsCommand() [1/2]
ScalePartsCommand::ScalePartsCommand ( ElementScene * scene = nullptr,
Constructor
sceneModified ElementScene
parentParent QUndoCommand
◆ ~ScalePartsCommand()
ScalePartsCommand::~ScalePartsCommand ( )
Destructor
◆ ScalePartsCommand() [2/2]
ScalePartsCommand::ScalePartsCommand ( const ScalePartsCommand & )
◆ adjustText()
void ScalePartsCommand::adjustText ( )
protected
Generate the text describing what this command does exactly.
◆ elementScene()
ElementScene * ScalePartsCommand::elementScene ( ) const
the element editor/scene the command should take place on
◆ redo()
void ScalePartsCommand::redo ( )
Redo the scaling operation
◆ scale()
void ScalePartsCommand::scale ( const QRectF & before,
const QRectF & after )
protected
Apply the scaling operation from before to after.
◆ scaledPrimitives()
QList< CustomElementPart * > ScalePartsCommand::scaledPrimitives ( ) const
the list of primitives to be scaled by this command
◆ setScaledPrimitives()
void ScalePartsCommand::setScaledPrimitives ( const QList< CustomElementPart * > & primitives)
Set primitives as the list of primitives to be scaled by this command
◆ setTransformation()
void ScalePartsCommand::setTransformation ( const QRectF & original_rect,
const QRectF & new_rect )
original_rect: Bounding rectangle for all scaled primitives before the operation
new_rect: Bounding rectangle for all scaled primitives after the operation
◆ transformation()
QPair< QRectF, QRectF > ScalePartsCommand::transformation ( )
the transformation applied by this command. The returned rectangles are the bounding rectangles for all scaled primitives respectively before and after the operation.
◆ undo()
void ScalePartsCommand::undo ( )
Undo the scaling operation
◆ first_redo
bool ScalePartsCommand::first_redo
◆ new_rect_
QRectF ScalePartsCommand::new_rect_
◆ original_rect_
QRectF ScalePartsCommand::original_rect_
◆ scaled_primitives_
QList<CustomElementPart *> ScalePartsCommand::scaled_primitives_
