ConductorPropertiesWidget Class Reference
#include <conductorpropertieswidget.h>
Inherits QWidget.
Collaboration diagram for ConductorPropertiesWidget:
Public Slots
void updatePreview (bool b=true)
 ConductorPropertiesWidget::updatePreview Update the preview for single lien.
 ConductorPropertiesWidget (QWidget *parent=nullptr)
 ConductorPropertiesWidget::ConductorPropertiesWidget Constructor.
 ConductorPropertiesWidget (const ConductorProperties &properties, QWidget *parent=nullptr)
 ConductorPropertiesWidget::ConductorPropertiesWidget Constructor with properties.
 ~ConductorPropertiesWidget () override
 ConductorPropertiesWidget::~ConductorPropertiesWidget destructor.
void setProperties (const ConductorProperties &properties)
 ConductorPropertiesWidget::setProperties Set the properties.
ConductorProperties properties () const
 ConductorPropertiesWidget::properties.
void setReadOnly (const bool &ro)
 ConductorPropertiesWidget::setReadOnly.
void addAutonumWidget (QWidget *widget)
 ConductorPropertiesWidget::addAutonumWidget.
void setHiddenOneTextPerFolio (const bool &hide)
 ConductorPropertiesWidget::setHiddenOneTextPerFolio.
void setDisabledShowText (const bool &disable=true)
 ConductorPropertiesWidget::setDisabledShowText.
void setHiddenAvailableAutonum (const bool &hide)
 ConductorPropertiesWidget::setHiddenAvailableAutonum Hide the label, combo box and push button of available autonum.
QComboBox * autonumComboBox () const
QPushButton * editAutonumPushButton () const
Protected Member Functions
bool event (QEvent *event) override
 ConductorPropertiesWidget::event.
Private Slots
void on_m_earth_cb_toggled (bool checked)
 ConductorPropertiesWidget::on_m_earth_cb_toggled Update the widget when toggled.
void on_m_neutral_cb_toggled (bool checked)
 ConductorPropertiesWidget::on_m_neutral_cb_toggled Update the widget when toggled.
void on_m_update_preview_pb_clicked ()
 ConductorPropertiesWidget::on_m_update_preview_pb_clicked Update the preview of single line. m_update_preview_pb is a no used button and hidden, his role is only to centralize signal from various widget to edit single ligne properties, for update the preview.
void initWidget ()
 ConductorPropertiesWidget::initWidget.
void setConductorType (ConductorProperties::ConductorType type)
 ConductorPropertiesWidget::setConductorType Update this widget to the new conductor type.
Ui::ConductorPropertiesWidget * ui
ConductorProperties m_properties
QTextOrientationSpinBoxWidget * m_verti_select
QTextOrientationSpinBoxWidget * m_horiz_select
◆ ConductorPropertiesWidget() [1/2]
ConductorPropertiesWidget::ConductorPropertiesWidget ( QWidget * parent = nullptr)
explicit
parent: paretn widget
◆ ConductorPropertiesWidget() [2/2]
ConductorPropertiesWidget::ConductorPropertiesWidget ( const ConductorProperties & properties,
QWidget * parent = nullptr )
explicit
properties: properties to edit
parent: parent widget
◆ ~ConductorPropertiesWidget()
ConductorPropertiesWidget::~ConductorPropertiesWidget ( )
◆ addAutonumWidget()
void ConductorPropertiesWidget::addAutonumWidget ( QWidget * widget)
◆ autonumComboBox()
QComboBox * ConductorPropertiesWidget::autonumComboBox ( ) const
◆ editAutonumPushButton()
QPushButton * ConductorPropertiesWidget::editAutonumPushButton ( ) const
◆ event()
bool ConductorPropertiesWidget::event ( QEvent * event)
overrideprotected
event
◆ initWidget()
void ConductorPropertiesWidget::initWidget ( )
◆ on_m_earth_cb_toggled
void ConductorPropertiesWidget::on_m_earth_cb_toggled ( bool checked)
privateslot
checked
◆ on_m_neutral_cb_toggled
void ConductorPropertiesWidget::on_m_neutral_cb_toggled ( bool checked)
privateslot
checked
◆ on_m_update_preview_pb_clicked
void ConductorPropertiesWidget::on_m_update_preview_pb_clicked ( )
privateslot
◆ properties()
ConductorProperties ConductorPropertiesWidget::properties ( ) const
the edited properties
◆ setConductorType()
void ConductorPropertiesWidget::setConductorType ( ConductorProperties::ConductorType type)
type
◆ setDisabledShowText()
void ConductorPropertiesWidget::setDisabledShowText ( const bool & disable = true)
◆ setHiddenAvailableAutonum()
void ConductorPropertiesWidget::setHiddenAvailableAutonum ( const bool & hide)
hide
◆ setHiddenOneTextPerFolio()
void ConductorPropertiesWidget::setHiddenOneTextPerFolio ( const bool & hide)
◆ setProperties()
void ConductorPropertiesWidget::setProperties ( const ConductorProperties & properties)
properties
◆ setReadOnly()
void ConductorPropertiesWidget::setReadOnly ( const bool & ro)
roif true this widget is disabled
◆ updatePreview
void ConductorPropertiesWidget::updatePreview ( bool b = true)
slot
btrue: update from the value displayed by this widget false: update from the properties given at the constructor of this widget
◆ m_horiz_select
QTextOrientationSpinBoxWidget * ConductorPropertiesWidget::m_horiz_select
◆ m_properties
ConductorProperties ConductorPropertiesWidget::m_properties
◆ m_verti_select
QTextOrientationSpinBoxWidget* ConductorPropertiesWidget::m_verti_select
◆ ui
Ui::ConductorPropertiesWidget* ConductorPropertiesWidget::ui
