The ElementsPanelWidget class This class embeds an elements panel under a toolbar providing various actions to manage elements.
More...
#include <elementspanelwidget.h>
Inherits QWidget.
- See also
- ElementsPanel
◆ ElementsPanelWidget() [1/2]
| ElementsPanelWidget::ElementsPanelWidget |
QWidget * | parent = nullptr | ) |
Constructeur
- Parameters
| parent | Le QWidget parent de ce widget |
◆ ~ElementsPanelWidget()
| ElementsPanelWidget::~ElementsPanelWidget |
override |
◆ ElementsPanelWidget() [2/2]
◆ activateProject
| void ElementsPanelWidget::activateProject |
slot |
Emit the requestForProject signal with the selected project
◆ addTitleBlockTemplate
| void ElementsPanelWidget::addTitleBlockTemplate |
slot |
Opens a template editor to create a new title block template.
◆ closeProject
| void ElementsPanelWidget::closeProject |
slot |
Emet le signal requestForProjectClosing avec le projet selectionne
◆ copyPathForSelectedItem
| void ElementsPanelWidget::copyPathForSelectedItem |
slot |
Copy the full path to the file represented by the selected item to the clipboard.
◆ deleteDiagram
| void ElementsPanelWidget::deleteDiagram |
slot |
Emet le signal requestForDiagramsDeletion avec les schemas selectionnes
◆ duplicateDiagram
| void ElementsPanelWidget::duplicateDiagram |
slot |
Duplicates the selected folios (pages) along with their content and properties, and cleanly resolves cross-references.
◆ editDiagramProperties
| void ElementsPanelWidget::editDiagramProperties |
slot |
Emet le signal requestForDiagramPropertiesEdition avec le schema selectionne
◆ editProjectProperties
| void ElementsPanelWidget::editProjectProperties |
slot |
Emet le signal requestForProjectPropertiesEdition avec le projet selectionne
◆ editTitleBlockTemplate
| void ElementsPanelWidget::editTitleBlockTemplate |
slot |
Opens an editor to edit the currently selected title block template, if any.
◆ elementsPanel()
◆ filterEdited
| void ElementsPanelWidget::filterEdited |
const QString & | next_text | ) |
slot |
◆ handleContextMenu
| void ElementsPanelWidget::handleContextMenu |
const QPoint & | pos | ) |
slot |
Gere le menu contextuel du panel d'elements
- Parameters
| pos | Position ou le menu contextuel a ete demande |
◆ insertDiagramAbove
| void ElementsPanelWidget::insertDiagramAbove |
slot |
◆ insertDiagramBelow
| void ElementsPanelWidget::insertDiagramBelow |
slot |
◆ keyPressEvent()
| void ElementsPanelWidget::keyPressEvent |
QKeyEvent * | e | ) |
overrideprotected |
Treat key press event inside elements panel widget Treat key press event inside elements panel widget. Respects the enabled/disabled state of the corresponding QActions.
◆ moveDiagramDown
| void ElementsPanelWidget::moveDiagramDown |
slot |
Emits the requestForDiagramMoveDown signal with all selected diagrams.
◆ moveDiagramDownx10
| void ElementsPanelWidget::moveDiagramDownx10 |
slot |
Emits the requestForDiagramMoveDownx10 signal with all selected diagrams.
◆ moveDiagramDownx100
| void ElementsPanelWidget::moveDiagramDownx100 |
slot |
Emits the requestForDiagramMoveDownx100 signal with all selected diagrams.
◆ moveDiagramUp
| void ElementsPanelWidget::moveDiagramUp |
slot |
Emits the requestForDiagramMoveUp signal with all selected diagrams.
◆ moveDiagramUpTop
| void ElementsPanelWidget::moveDiagramUpTop |
slot |
Emits the requestForDiagramMoveUpTop signal with all selected diagrams.
◆ moveDiagramUpx10
| void ElementsPanelWidget::moveDiagramUpx10 |
slot |
Emits the requestForDiagramMoveUpx10 signal with all selected diagrams.
◆ moveDiagramUpx100
| void ElementsPanelWidget::moveDiagramUpx100 |
slot |
Emits the requestForDiagramMoveUpx100 signal with all selected diagrams.
◆ newDiagram
| void ElementsPanelWidget::newDiagram |
slot |
Emet le signal requestForNewDiagram avec le projet selectionne
◆ openDirectoryForSelectedItem
| void ElementsPanelWidget::openDirectoryForSelectedItem |
slot |
Require the desktop environment to open the directory containing the file represented by the selected item, if any.
◆ reloadAndFilter
| void ElementsPanelWidget::reloadAndFilter |
slot |
Recharge le panel d'elements
◆ removeTitleBlockTemplate
| void ElementsPanelWidget::removeTitleBlockTemplate |
slot |
Delete the currently selected title block template, if any.
◆ requestForDiagramDeletion
| void ElementsPanelWidget::requestForDiagramDeletion |
Diagram * | | ) |
signal |
◆ requestForDiagramMoveDown
| void ElementsPanelWidget::requestForDiagramMoveDown |
const QList< Diagram * > & | diagrams | ) |
signal |
◆ requestForDiagramMoveDownx10
| void ElementsPanelWidget::requestForDiagramMoveDownx10 |
signal |
◆ requestForDiagramMoveDownx100
| void ElementsPanelWidget::requestForDiagramMoveDownx100 |
signal |
◆ requestForDiagramMoveUp
| void ElementsPanelWidget::requestForDiagramMoveUp |
signal |
◆ requestForDiagramMoveUpTop
| void ElementsPanelWidget::requestForDiagramMoveUpTop |
signal |
◆ requestForDiagramMoveUpx10
| void ElementsPanelWidget::requestForDiagramMoveUpx10 |
signal |
◆ requestForDiagramMoveUpx100
| void ElementsPanelWidget::requestForDiagramMoveUpx100 |
signal |
◆ requestForDiagramPropertiesEdition
| void ElementsPanelWidget::requestForDiagramPropertiesEdition |
Diagram * | | ) |
signal |
◆ requestForDiagramsDeletion
| void ElementsPanelWidget::requestForDiagramsDeletion |
signal |
◆ requestForNewDiagram
| void ElementsPanelWidget::requestForNewDiagram |
QETProject * | | ) |
signal |
◆ requestForNewDiagramAt
| void ElementsPanelWidget::requestForNewDiagramAt |
QETProject * | , |
int | ) |
signal |
◆ requestForProject
| void ElementsPanelWidget::requestForProject |
signal |
◆ requestForProjectClosing
| void ElementsPanelWidget::requestForProjectClosing |
signal |
◆ requestForProjectPropertiesEdition
| void ElementsPanelWidget::requestForProjectPropertiesEdition |
signal |
◆ updateButtons
| void ElementsPanelWidget::updateButtons |
slot |
Met a jour les boutons afin d'assurer la coherence de l'interface
◆ context_menu
| QMenu* ElementsPanelWidget::context_menu |
private |
◆ copy_path
| QAction * ElementsPanelWidget::copy_path |
private |
◆ elements_panel
◆ filter_textfield
| QLineEdit* ElementsPanelWidget::filter_textfield |
private |
◆ open_directory
| QAction* ElementsPanelWidget::open_directory |
private |
◆ previous_filter_
| QString ElementsPanelWidget::previous_filter_ |
private |
◆ prj_activate
| QAction* ElementsPanelWidget::prj_activate |
private |
◆ prj_add_diagram
| QAction * ElementsPanelWidget::prj_add_diagram |
private |
◆ prj_close
| QAction * ElementsPanelWidget::prj_close |
private |
◆ prj_del_diagram
| QAction * ElementsPanelWidget::prj_del_diagram |
private |
◆ prj_duplicate_diagram
| QAction * ElementsPanelWidget::prj_duplicate_diagram |
private |
◆ prj_edit_prop
| QAction * ElementsPanelWidget::prj_edit_prop |
private |
◆ prj_insert_diagram_above
| QAction * ElementsPanelWidget::prj_insert_diagram_above |
private |
◆ prj_insert_diagram_below
| QAction * ElementsPanelWidget::prj_insert_diagram_below |
private |
◆ prj_move_diagram_down
| QAction * ElementsPanelWidget::prj_move_diagram_down |
private |
◆ prj_move_diagram_downx10
| QAction * ElementsPanelWidget::prj_move_diagram_downx10 |
private |
◆ prj_move_diagram_downx100
| QAction * ElementsPanelWidget::prj_move_diagram_downx100 |
private |
◆ prj_move_diagram_top
| QAction * ElementsPanelWidget::prj_move_diagram_top |
private |
◆ prj_move_diagram_up
| QAction * ElementsPanelWidget::prj_move_diagram_up |
private |
◆ prj_move_diagram_upx10
| QAction * ElementsPanelWidget::prj_move_diagram_upx10 |
private |
◆ prj_move_diagram_upx100
| QAction * ElementsPanelWidget::prj_move_diagram_upx100 |
private |
◆ prj_prop_diagram
| QAction * ElementsPanelWidget::prj_prop_diagram |
private |
◆ tbt_add
| QAction* ElementsPanelWidget::tbt_add |
private |
◆ tbt_edit
| QAction * ElementsPanelWidget::tbt_edit |
private |
◆ tbt_remove
| QAction * ElementsPanelWidget::tbt_remove |
private |
