Diagram Class Reference
The Diagram class This class represents an electric diagram. It manages its various child elements, conductors and texts and handles their graphic rendering. More...
#include <diagram.h>
Inherits QGraphicsScene.
Collaboration diagram for Diagram:
struct  Guide
Public Types
enum  BorderOptions { EmptyBorder , TitleBlock , Columns }
 The BorderOptions enum Represents available options when rendering a particular diagram: EmptyBorder: display border only TitleBlock: display title block Columns: display columns. More...
enum  NumerotationType { Conductors }
 Represents available option of Numerotation type. More...
Public Slots
void adjustSceneRect ()
 Diagram::adjustSceneRect Recalcul and adjust the size of the scene.
void titleChanged ()
 Diagram::titleChanged emit(diagramTitleChanged(this, title));.
void titleBlockTemplateChanged (const QString &)
 Diagram::titleBlockTemplateChanged This slot may be used to inform the diagram object that the given title block template has changed. The diagram will thus flush its title block-dedicated rendering cache.
void titleBlockTemplateRemoved (const QString &, const QString &=QString())
 Diagram::titleBlockTemplateRemoved This slot has to be be used to inform this class that the given title block template is about to be removed and is no longer accessible. This class will either use the provided optional TitleBlockTemplate or the default title block provided by QETApp::defaultTitleBlockTemplate().
void setTitleBlockTemplate (const QString &)
 Diagram::setTitleBlockTemplate Set the template to use to render the title block of this diagram.
void loadElmtFolioSeq ()
 Diagram::loadElmtFolioSeq This class loads all folio sequential variables related to the current autonum.
void loadCndFolioSeq ()
 Diagram::loadCndFolioSeq This class loads all conductor folio sequential variables related to the current autonum.
void selectAll ()
 Diagram::selectAll Select all schema objects.
void deselectAll ()
 Diagram::deselectAll Deselects all selected objects.
void invertSelection ()
 Diagram::invertSelection Reverses the selection state of all schema objects Inverse l'etat de selection de tous les objets du schema.
Signals
void showDiagram (Diagram *)
void usedTitleBlockTemplateChanged (const QString &)
void diagramTitleChanged (Diagram *)
void findElementRequired (const ElementsLocation &)
void diagramActivated ()
void diagramInformationChanged ()
void correctTextPos (Element *elmt)
 Diagram::correctTextPos set insertion position to the original insertion position of the element texts before copying.
void restoreText (Element *elmt)
 Diagram::restoreText After correcting the elementtext position during copying the Text has to be restored.
QUuid uuid ()
 Diagram::uuid.
void setEventInterface (DiagramEventInterface *event_interface)
 Diagram::setEventInterface Set event_interface has current interface. Diagram become the ownership of event_interface If there is a previous interface, they will be delete before and call init() to the new interface.
void clearEventInterface ()
 Diagram::clearEventInterface Clear the current event interface.
QString conductorsAutonumName () const
 Diagram::conductorsAutonumName.
void setConductorsAutonumName (const QString &name)
 Diagram::setConductorsAutonumName.
QETProject * project () const
 Diagram::project.
int folioIndex () const
 Diagram::folioIndex.
void showMe ()
bool isReadOnly () const
 Diagram::isReadOnly.
void setConductor (bool)
 Diagram::setConductor Display or hide the conductor setter, i.e. a dashed conductor stub which appears when creating a conductor between two terminals.
void setConductorStart (QPointF)
 Diagram::setConductorStart Set the start point of the conductor setter.
void setConductorStop (QPointF)
 Diagram::setConductorStop Set the end point of the conductor setter.
QList< QSet< Conductor * > > potentials ()
 Diagram::potential.
QDomDocument toXml (bool wholeContent=true, bool is_copy_command=false)
 Diagram::toXml Exports all or part of the schema.
bool initFromXml (QDomElement &, QPointF=QPointF(), bool=true, DiagramContent *=nullptr)
 Diagram::initFromXml Imports the described schema in an XML element. This method delegates its work to Diagram :: fromXml If the import is successful, this method also initializes the XML document internal allowing to manage the recording of this diagram in the project to which it belongs.
bool fromXml (QDomDocument &, QPointF=QPointF(), bool=true, DiagramContent *=nullptr)
 Diagram::fromXml Imports the described schema into an XML document. If a position is specified, the imported elements are positioned so that the upper left corner of the smallest rectangle that can surround them all (the bounding rect) is at this position.
bool fromXml (QDomElement &, QPointF=QPointF(), bool=true, DiagramContent *=nullptr)
 Diagram::fromXml Imports the described schema in an XML element. If a position is specified, the imported elements are positioned in such a way that the upper left corner of the smallest rectangle that can surround them all (the bounding rect) either at this position.
void folioSequentialsToXml (QHash< QString, QStringList > *, QDomElement *, const QString &, const QString &, QDomDocument *)
 Diagram::folioSequentialsToXml Add folio sequential to QDomElement.
void folioSequentialsFromXml (const QDomElement &, QHash< QString, QStringList > *, const QString &, const QString &, const QString &, const QString &)
 Diagram::folioSequentialsFromXml Load folio sequential from QDomElement.
void refreshContents ()
 Diagram::refreshContents refresh all content of diagram.
virtual void addItem (QGraphicsItem *item)
 Diagram::addItem Réimplemented from QGraphicsScene::addItem(QGraphicsItem *item) Do some specific operation if item need it (for example an element).
virtual void removeItem (QGraphicsItem *item)
 Diagram::removeItem Reimplemented from QGraphicsScene::removeItem(QGraphicsItem *item) Do some specific operation if item need it (for example an element).
ExportProperties applyProperties (const ExportProperties &)
 Diagram::applyProperties This method allows you to apply new rendering options while accessing the current rendering properties.
void setDisplayGrid (bool)
 Diagram::setDisplayGrid Set whether the diagram grid should be drawn.
bool displayGrid ()
 Diagram::displayGrid.
void setDisplayGuides (bool)
bool displayGuides ()
void updateProjectGuides (const QList< GuideProperties > &guides)
 Diagram::updateProjectGuides Aktualisiert die internen Hilfslinien dieses Schaltplans basierend auf den Projekt-Einstellungen und erzwingt ein Neuzeichnen.
void setUseBorder (bool)
 Diagram::setUseBorder Set whether the diagram border (including rows/columns headers and the title block) should be rendered along with the diagram. When set to false, the size of the smallest rectangle containing all items is considered as the diagram size.
bool useBorder ()
 Diagram::useBorder.
void setBorderOptions (BorderOptions)
 Diagram::setBorderOptions Set the rendering options for the diagram border (including rows/columns headers and the title block).
BorderOptions borderOptions ()
 Diagram::borderOptions.
DiagramPosition convertPosition (const QPointF &)
 Diagram::convertPosition.
bool drawTerminals () const
 Diagram::drawTerminals.
void setDrawTerminals (bool)
 Diagram::setDrawTerminals Defines whether or not to display the terminals.
bool drawTerminalNames () const
 Diagram::drawTerminalNames.
void setDrawTerminalNames (bool)
 Diagram::setDrawTerminalNames Defines whether or not to display the terminal names/labels.
bool drawColoredConductors () const
 Diagram::drawColoredConductors.
void setDrawColoredConductors (bool)
 Diagram::setDrawColoredConductors Defines whether or not to respect the colors of the conductors. If not, the conductors are all drawn in black.
QString title () const
 Diagram::title.
bool toPaintDevice (QPaintDevice &, int=-1, int=-1, Qt::AspectRatioMode=Qt::KeepAspectRatio)
QSize imageSize () const
 Diagram::imageSize Allows you to know the dimensions that the image generated by the toImage() method will have.
bool isEmpty () const
 Diagram::isEmpty An empty schema contains no element, conductor, or text field.
QList< Element * > elements () const
 Diagram::elements.
QList< Conductor * > conductors () const
 Diagram::conductors.
QSet< Conductor * > selectedConductors () const
 Diagram::selectedConductors.
DiagramContent content () const
 Diagram::content.
bool canRotateSelection () const
 Diagram::canRotateSelection.
ElementsMover & elementsMover ()
 Diagram::elementsMover.
ElementTextsMover & elementTextsMover ()
 Diagram::elementTextsMover.
bool usesElement (const ElementsLocation &)
 Diagram::usesElement Used to find out if an element is used on a schema.
bool usesTitleBlockTemplate (const QString &)
 Diagram::usesTitleBlockTemplate.
QUndoStack & undoStack ()
QGIManager & qgiManager ()
 Diagram::qgiManager.
void freezeElements (bool freeze)
 Diagram::freezeElements Freeze every existent element label.
void unfreezeElements ()
 Diagram::unfreezeElements Unfreeze every existent element label.
void setFreezeNewElements (bool)
 Diagram::freezeNewElements Set new element label to be frozen.
bool freezeNewElements ()
 Diagram::freezeNewElements.
void freezeConductors (bool freeze)
 Diagram::freezeConductors Freeze every existent conductor label.
void setFreezeNewConductors (bool)
 Diagram::setfreezeNewConductors Set new conductor label to be frozen.
bool freezeNewConductors ()
 Diagram::freezeNewConductors.
void insertFolioSeqHash (QHash< QString, QStringList > *hash, const QString &title, const QString &seq, NumerotationContext *nc)
 Diagram::insertFolioSeqHash This class inserts a stringlist containing all sequential variables related to an autonum in a QHash.
void loadFolioSeqHash (QHash< QString, QStringList > *hash, const QString &title, const QString &seq, NumerotationContext *nc)
 Diagram::loadFolioSeqHash This class loads all folio sequential variables related to the current autonum.
void changeZValue (QET::DepthOption option)
 Diagram::changeZValue Change the Z value of the current selected item, according to option.
static bool clipboardMayContainDiagram ()
 Diagram::clipboardMayContainDiagram.
static QPointF snapToGrid (const QPointF &p)
 Diagram::snapToGrid Return a nearest snap point of p.
Public Attributes
ConductorProperties defaultConductorProperties
 Default properties for new conductors.
BorderTitleBlock border_and_titleblock
 Diagram dimensions and title block.
QHash< QString, QStringList > m_elmt_unitfolio_max
 Hash containing max values for folio sequential autonums in this diagram.
QHash< QString, QStringList > m_elmt_tenfolio_max
QHash< QString, QStringList > m_elmt_hundredfolio_max
QHash< QString, QStringList > m_cnd_unitfolio_max
QHash< QString, QStringList > m_cnd_tenfolio_max
QHash< QString, QStringList > m_cnd_hundredfolio_max
Static Public Attributes
static int xGrid = 10
 abscissa grid step size
static int yGrid = 10
 ordinate grid step size
static int xKeyGrid = 10
 Key grid x step size.
static int yKeyGrid = 10
 Key grid y step size.
static int xKeyGridFine = 1
 Key grid fine x step size.
static int yKeyGridFine = 1
 Key grid fine y step size.
static const qreal margin = 5.0
 margin around the diagram
static QColor background_color = Qt::white
 background color of diagram
Protected Member Functions
void drawBackground (QPainter *, const QRectF &) override
 Diagram::drawBackground Draw the background of the diagram, ie the grid.
 Diagram::mouseDoubleClickEvent This event is managed by diagram event interface if any.
 Diagram::mousePressEvent This event is managed by diagram event interface if any.
 Diagram::mouseMoveEvent This event is managed by diagram event interface if any.
 Diagram::mouseReleaseEvent This event is managed by diagram event interface if any.
void wheelEvent (QGraphicsSceneWheelEvent *event) override
 Diagram::wheelEvent This event is managed by diagram event interface if any.
void keyPressEvent (QKeyEvent *event) override
 Diagram::keyPressEvent This event is managed by diagram event interface if any. Else move selected elements.
void keyReleaseEvent (QKeyEvent *) override
 Diagram::keyReleaseEvent This event is managed by diagram event interface if any. Else move selected element.
 Diagram (QETProject *project)
 Diagram::Diagram Constructor.
 ~Diagram () override
 Diagram::~Diagram Destructor.
 Diagram (const Diagram &diagram)
friend DiagramFolioList
friend QETProject
QGraphicsLineItem * conductor_setter_
ElementsMover m_elements_mover
ElementTextsMover m_element_texts_mover
QGIManager * qgi_manager_
QETProject * m_project
QDomDocument xml_document_
qreal diagram_qet_version_
bool draw_grid_
bool use_border_
bool draw_guides_
QList< Diagram::Guide > m_guides_list
bool draw_terminals_
bool draw_terminal_names_
bool draw_colored_conductors_
QString m_conductors_autonum_name
DiagramEventInterface * m_event_interface
bool m_freeze_new_elements
bool m_freeze_new_conductors_
QUuid m_uuid = QUuid::createUuid()
◆ BorderOptions
Enumerator
EmptyBorder
TitleBlock
Columns
◆ NumerotationType
Enumerator
Conductors
◆ Diagram() [1/2]
Diagram::Diagram ( QETProject * project)
project: The project of this diagram and also parent QObject
◆ Diagram() [2/2]
Diagram::Diagram ( const Diagram & diagram)
◆ addItem()
void Diagram::addItem ( QGraphicsItem * item)
virtual
item
◆ adjustSceneRect
void Diagram::adjustSceneRect ( )
slot
◆ applyProperties()
ExportProperties Diagram::applyProperties ( const ExportProperties & new_properties)
new_properties: New rendering options to apply
rendering options before applying new_properties
◆ borderOptions()
Diagram::BorderOptions Diagram::borderOptions ( )
inline
The rendering options for the diagram border
See also
setBorderOptions
◆ canRotateSelection()
bool Diagram::canRotateSelection ( ) const
True if a least one of selected items can be rotated
◆ changeZValue()
void Diagram::changeZValue ( QET::DepthOption option)
option
◆ clearEventInterface()
void Diagram::clearEventInterface ( )
◆ clipboardMayContainDiagram()
bool Diagram::clipboardMayContainDiagram ( )
static
true if the clipboard appears to contain a schema
◆ conductors()
QList< Conductor * > Diagram::conductors ( ) const
the list containing all conductors
◆ conductorsAutonumName()
QString Diagram::conductorsAutonumName ( ) const
the name of autonum to use.
◆ content()
DiagramContent Diagram::content ( ) const
Diagram::content.
The content of the diagram. The conductors are all seated in conductorsToMove.
◆ convertPosition()
DiagramPosition Diagram::convertPosition ( const QPointF & pos)
pos: Cartesian position (ex: 10.3, 45.2) to transform into position in the grid (ex: B2)
a position in the grid corresponding to pos
◆ correctTextPos()
void Diagram::correctTextPos ( Element * elmt)
Element
◆ deselectAll
void Diagram::deselectAll ( )
slot
◆ diagramActivated
void Diagram::diagramActivated ( )
signal
◆ diagramInformationChanged
void Diagram::diagramInformationChanged ( )
signal
◆ diagramTitleChanged
void Diagram::diagramTitleChanged ( Diagram * )
signal
◆ displayGrid()
bool Diagram::displayGrid ( )
inline
draw_grid_ true if the grid is drawn, false otherwise.
◆ displayGuides()
bool Diagram::displayGuides ( )
inline
◆ drawBackground()
void Diagram::drawBackground ( QPainter * p,
const QRectF & r )
overrideprotected
p: The QPainter to use for drawing
r: The rectangle of the area to be drawn
◆ drawColoredConductors()
bool Diagram::drawColoredConductors ( ) const
inline
true if conductors colors are rendered, false otherwise.
◆ drawTerminalNames()
bool Diagram::drawTerminalNames ( ) const
inline
true if terminal names are rendered, false otherwise
◆ drawTerminals()
bool Diagram::drawTerminals ( ) const
inline
true if terminals are rendered, false otherwise
◆ elements()
QList< Element * > Diagram::elements ( ) const
Diagram::elements.
the list containing all elements
◆ elementsMover()
ElementsMover & Diagram::elementsMover ( )
◆ elementTextsMover()
ElementTextsMover & Diagram::elementTextsMover ( )
◆ findElementRequired
void Diagram::findElementRequired ( const ElementsLocation & )
signal
Signal emitted when users wish to locate an element from the diagram within elements collection
◆ folioIndex()
int Diagram::folioIndex ( ) const
the folio number of this diagram within its parent project, or -1 if it is has no parent project
◆ folioSequentialsFromXml()
void Diagram::folioSequentialsFromXml ( const QDomElement & root,
QHash< QString, QStringList > * hash,
const QString & folioSeq,
const QString & seq,
const QString & type,
const QString & autonumFolioSeqType )
rootcontaining all folio sequentials
hash: to be loaded with content
folioSeqtype
seqtype
typeof sequential
autonumFolioSeqType
◆ folioSequentialsToXml()
void Diagram::folioSequentialsToXml ( QHash< QString, QStringList > * hash,
QDomElement * domElement,
const QString & seq_type,
QDomDocument * doc )
hashto retrieve content with content
domElementto add attributes
seq_typetype
type
doc
◆ freezeConductors()
void Diagram::freezeConductors ( bool freeze)
◆ freezeElements()
void Diagram::freezeElements ( bool freeze)
◆ freezeNewConductors()
bool Diagram::freezeNewConductors ( )
current freeze new conductor status .
◆ freezeNewElements()
bool Diagram::freezeNewElements ( )
current freeze new element status .
◆ fromXml() [1/2]
bool Diagram::fromXml ( QDomDocument & document,
QPointF position = QPointF(),
bool consider_informations = true,
DiagramContent * content_ptr = nullptr )
document: The XML document to analyze
position: The position of the diagram matters
consider_informations: If true, additional information (author, title, ...) will be taken into account
content_ptr: if this pointer to a DiagramContent is different from 0, it will be filled with the content added to the schema by the fromXml
true if the import was successful, false otherwise
◆ fromXml() [2/2]
bool Diagram::fromXml ( QDomElement & document,
◆ imageSize()
QSize Diagram::imageSize ( ) const
The size of the image generated by toImage()
◆ initFromXml()
bool Diagram::initFromXml ( QDomElement & document,
See also
Diagram::fromXml
◆ insertFolioSeqHash()
void Diagram::insertFolioSeqHash ( QHash< QString, QStringList > * hash,
const QString & title,
NumerotationContext * nc )
hash: to be accessed
title: autonum title
type: to be treated
nc: Context to be manipulated
◆ invertSelection
void Diagram::invertSelection ( )
slot
◆ isEmpty()
bool Diagram::isEmpty ( ) const
true if the schema is considered empty, false otherwise.
◆ isReadOnly()
bool Diagram::isReadOnly ( ) const
true if this diagram is read only. This method is same has call Diagram::project() -> isReadOnly()
◆ keyPressEvent()
void Diagram::keyPressEvent ( QKeyEvent * event)
overrideprotected
event
◆ keyReleaseEvent()
void Diagram::keyReleaseEvent ( QKeyEvent * e)
overrideprotected
e
◆ loadCndFolioSeq
void Diagram::loadCndFolioSeq ( )
slot
◆ loadElmtFolioSeq
void Diagram::loadElmtFolioSeq ( )
slot
◆ loadFolioSeqHash()
void Diagram::loadFolioSeqHash ( QHash< QString, QStringList > * hash,
type: to be treated
◆ mouseDoubleClickEvent()
void Diagram::mouseDoubleClickEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event:
◆ mouseMoveEvent()
void Diagram::mouseMoveEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mousePressEvent()
void Diagram::mousePressEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ mouseReleaseEvent()
void Diagram::mouseReleaseEvent ( QGraphicsSceneMouseEvent * event)
overrideprotected
event
◆ potentials()
QList< QSet< Conductor * > > Diagram::potentials ( )
Diagram::potential.
all potential in the diagram each potential are in the QList and each conductors of one potential are in the QSet
◆ project()
QETProject * Diagram::project ( ) const
Diagram::project.
the project to which this schema belongs or 0 if it is an independent schema.
◆ qgiManager()
QGIManager & Diagram::qgiManager ( )
inline
the diagram graphics item manager
◆ refreshContents()
void Diagram::refreshContents ( )
  • refresh conductor text.
  • linking the elements waiting to be linked
  • Refresh the connection of the dynamic element text item (use for text with source of text label)
◆ removeItem()
void Diagram::removeItem ( QGraphicsItem * item)
virtual
item
◆ restoreText()
void Diagram::restoreText ( Element * elmt)
Element
◆ selectAll
void Diagram::selectAll ( )
slot
◆ selectedConductors()
QSet< Conductor * > Diagram::selectedConductors ( ) const
the list of conductors selected on the diagram
◆ setBorderOptions()
void Diagram::setBorderOptions ( Diagram::BorderOptions bo)
inline
boEnabled options ORed together
See also
BorderOptions
◆ setConductor()
void Diagram::setConductor ( bool adding)
inline
addingtrue add conductor ,false remove conductor
◆ setConductorsAutonumName()
void Diagram::setConductorsAutonumName ( const QString & name)
name: name of autonum to use.
◆ setConductorStart()
void Diagram::setConductorStart ( QPointF start)
inline
startthe point (in scene coordinates) which the newly created conductor should start from.
◆ setConductorStop()
void Diagram::setConductorStop ( QPointF end)
inline
endthe point (in scene coordinates) upon to which the newly created conductor should be drawn.
◆ setDisplayGrid()
void Diagram::setDisplayGrid ( bool dg)
inline
dgtrue to render the grid, false otherwise.
◆ setDisplayGuides()
void Diagram::setDisplayGuides ( bool dg)
inline
◆ setDrawColoredConductors()
void Diagram::setDrawColoredConductors ( bool dcc)
dcctrue to respect the colors, false otherwise
◆ setDrawTerminalNames()
void Diagram::setDrawTerminalNames ( bool dt)
dt: true to display the terminal names, false otherwise
◆ setDrawTerminals()
void Diagram::setDrawTerminals ( bool dt)
dt: true to display the bounds, false otherwise
◆ setEventInterface()
void Diagram::setEventInterface ( DiagramEventInterface * event_interface)
event_interface
◆ setFreezeNewConductors()
void Diagram::setFreezeNewConductors ( bool b)
◆ setFreezeNewElements()
void Diagram::setFreezeNewElements ( bool b)
◆ setTitleBlockTemplate
void Diagram::setTitleBlockTemplate ( const QString & template_name)
slot
template_nameName of the title block template.
◆ setUseBorder()
void Diagram::setUseBorder ( bool ub)
inline
ubtrue to take the border into account, false otherwise
◆ showDiagram
void Diagram::showDiagram ( Diagram * )
signal
◆ showMe()
void Diagram::showMe ( )
inline
◆ snapToGrid()
QPointF Diagram::snapToGrid ( const QPointF & p)
static
ppoint to find the nearest snapped point
◆ title()
QString Diagram::title ( ) const
Diagram::title.
title of the titleblock
◆ titleBlockTemplateChanged
void Diagram::titleBlockTemplateChanged ( const QString & template_name)
slot
template_nameName of the title block template that has changed
◆ titleBlockTemplateRemoved
void Diagram::titleBlockTemplateRemoved ( const QString & template_name,
const QString & new_template = QString() )
slot
new_template(Optional) Name of the title block template to use instead
◆ titleChanged
void Diagram::titleChanged ( )
slot
title
◆ toPaintDevice()
bool Diagram::toPaintDevice ( QPaintDevice & pix,
int width = -1,
int height = -1,
Qt::AspectRatioMode aspectRatioMode = Qt::KeepAspectRatio )
Exporte le schema vers une image
Une QImage representant le schema
◆ toXml()
QDomDocument Diagram::toXml ( bool whole_content = true,
bool is_copy_command = false )
whole_content: Boolean (to true by default) indicating if the generated XML must represent the entire schema or only the selected content
is_copy_commandBoolean (false by default) indicating if function is called by an copy command
An XML Document (QDomDocument)
◆ undoStack()
QUndoStack & Diagram::undoStack ( )
◆ unfreezeElements()
void Diagram::unfreezeElements ( )
◆ updateProjectGuides()
void Diagram::updateProjectGuides ( const QList< GuideProperties > & guides)
◆ useBorder()
bool Diagram::useBorder ( )
inline
Diagram::useBorder.
use_border_ true if the border is rendered and take into account, false otherwise.
◆ usedTitleBlockTemplateChanged
void Diagram::usedTitleBlockTemplateChanged ( const QString & )
signal
◆ usesElement()
bool Diagram::usesElement ( const ElementsLocation & location)
true if the location element is used on this schema, false otherwise
◆ usesTitleBlockTemplate()
bool Diagram::usesTitleBlockTemplate ( const QString & name)
name: a title block template name
true if the provided template is used by this diagram, false otherwise.
◆ uuid()
QUuid Diagram::uuid ( )
Diagram::uuid.
the uuid of this diagram
◆ wheelEvent()
void Diagram::wheelEvent ( QGraphicsSceneWheelEvent * event)
overrideprotected
event
◆ ~Diagram()
Diagram::~Diagram ( )
overrideprivate
◆ background_color
QColor Diagram::background_color = Qt::white
static
Diagram::background_color static variable to keep track of present background color of the diagram.
◆ border_and_titleblock
BorderTitleBlock Diagram::border_and_titleblock
◆ conductor_setter_
QGraphicsLineItem* Diagram::conductor_setter_
◆ defaultConductorProperties
ConductorProperties Diagram::defaultConductorProperties
◆ diagram_qet_version_
qreal Diagram::diagram_qet_version_
◆ DiagramFolioList
friend Diagram::DiagramFolioList
◆ draw_colored_conductors_
bool Diagram::draw_colored_conductors_
◆ draw_grid_
bool Diagram::draw_grid_
◆ draw_guides_
bool Diagram::draw_guides_
◆ draw_terminal_names_
bool Diagram::draw_terminal_names_
◆ draw_terminals_
bool Diagram::draw_terminals_
◆ m_cnd_hundredfolio_max
QHash<QString, QStringList> Diagram::m_cnd_hundredfolio_max
◆ m_cnd_tenfolio_max
QHash<QString, QStringList> Diagram::m_cnd_tenfolio_max
◆ m_cnd_unitfolio_max
QHash<QString, QStringList> Diagram::m_cnd_unitfolio_max
◆ m_conductors_autonum_name
QString Diagram::m_conductors_autonum_name
◆ m_element_texts_mover
ElementTextsMover Diagram::m_element_texts_mover
◆ m_elements_mover
ElementsMover Diagram::m_elements_mover
◆ m_elmt_hundredfolio_max
QHash<QString, QStringList> Diagram::m_elmt_hundredfolio_max
◆ m_elmt_tenfolio_max
QHash<QString, QStringList> Diagram::m_elmt_tenfolio_max
◆ m_elmt_unitfolio_max
QHash<QString, QStringList> Diagram::m_elmt_unitfolio_max
◆ m_event_interface
DiagramEventInterface* Diagram::m_event_interface
◆ m_freeze_new_conductors_
bool Diagram::m_freeze_new_conductors_
◆ m_freeze_new_elements
bool Diagram::m_freeze_new_elements
◆ m_guides_list
QList<Diagram::Guide> Diagram::m_guides_list
◆ m_project
QETProject* Diagram::m_project
◆ m_uuid
QUuid Diagram::m_uuid = QUuid::createUuid()
◆ margin
const qreal Diagram::margin = 5.0
static
◆ QETProject
friend Diagram::QETProject
◆ qgi_manager_
QGIManager* Diagram::qgi_manager_
◆ use_border_
bool Diagram::use_border_
◆ xGrid
int Diagram::xGrid = 10
static
◆ xKeyGrid
int Diagram::xKeyGrid = 10
static
◆ xKeyGridFine
int Diagram::xKeyGridFine = 1
static
◆ xml_document_
QDomDocument Diagram::xml_document_
◆ yGrid
int Diagram::yGrid = 10
static
◆ yKeyGrid
int Diagram::yKeyGrid = 10
static
◆ yKeyGridFine
int Diagram::yKeyGridFine = 1
static
