QETApp Class Reference
The QETApp class This class represents the QElectroTech application. More...
#include <qetapp.h>
Inherits QObject.
Collaboration diagram for QETApp:
Public Slots
void systray (QSystemTrayIcon::ActivationReason)
 QETApp::systray Manages QSystemTrayIcon related events.
void reduceEveryEditor ()
 QETApp::reduceEveryEditor Minimizes all application windows in the systray.
void restoreEveryEditor ()
 QETApp::restoreEveryEditor Restores all application windows in the systray.
void reduceDiagramEditors ()
 QETApp::reduceDiagramEditors Minimize all schema editors in the systray.
void restoreDiagramEditors ()
 QETApp::restoreDiagramEditors Restore all schema editors in the systray.
void reduceElementEditors ()
 QETApp::reduceElementEditors Minimize all element editors in systray.
void restoreElementEditors ()
 QETApp::restoreElementEditors Restore all element editors in the systray.
void reduceTitleBlockTemplateEditors ()
 QETApp::reduceTitleBlockTemplateEditors Reduce all known template editors.
void restoreTitleBlockTemplateEditors ()
 QETApp::restoreTitleBlockTemplateEditors Restore all known template editors.
void newDiagramEditor ()
 QETApp::newDiagramEditor launches a new schema editor.
void newElementEditor ()
 QETApp::newElementEditor launches a new element editor.
bool closeEveryEditor ()
 QETApp::closeEveryEditor Close all editors.
void setMainWindowVisible (QMainWindow *, bool)
 QETApp::setMainWindowVisible Show or hide a window (schema editors / element editors).
void invertMainWindowVisibility (QWidget *)
 QETApp::invertMainWindowVisibility Display a window (schema editors / element editors) if this is hidden or hides it if it is displayed.
void useSystemPalette (bool)
 QETApp::useSystemPalette Change the application palette.
void quitQET ()
 QETApp::quitQET Request the closing of all windows; if the user accepts them, the application quits.
void checkRemainingWindows ()
 QETApp::checkRemainingWindows Check if there are any windows (hidden or not) and exit if there are no more.
void openFiles (const QETArguments &)
 QETApp::openFiles Open files passed as arguments.
void openProjectFiles (const QStringList &)
 QETApp::openProjectFiles Opens a list of files. Files are opened in the first visible schematic editor. Otherwise, the first existing schema editor becomes visible and is uses. If there is no schematic editor open, a new one is created and uses.
void openElementFiles (const QStringList &)
 QETApp::openElementFiles Open the elements files passed in parameter. If an element is already open, the window which edits it is activated.
void openElementLocations (const QList< ElementsLocation > &)
 QETApp::openElementLocations Open the elements whose location is passed in parameter. If an element is already open, the window which is edited is active.
void openTitleBlockTemplate (const TitleBlockTemplateLocation &, bool=false)
 QETApp::openTitleBlockTemplate Launch a new title block template editor to edit the given template.
void openTitleBlockTemplate (const QString &)
void openTitleBlockTemplateFiles (const QStringList &)
 QETApp::openTitleBlockTemplateFiles Open provided title block template files. If a title block template is already opened, the adequate window is activated.
void configureQET ()
 QETApp::configureQET Allows the user to configure QET by launching an appropriate dialog.
void aboutQET ()
 QETApp::aboutQET Open the dialog about qet.
void showDiagnosticsReport ()
 QETApp::showDiagnosticsReport Discussion #644, step 5: the manual "Help > Diagnostics > Save report" action. Unlike checkCrashDump(), this is about the current, still-running session, not a previous one.
void receiveMessage (int instanceId, QByteArray message)
 QETApp::receiveMessage openFiles from message.
 QETApp ()
 QETApp::QETApp.
 ~QETApp () override
 QETApp::~QETApp.
void setLanguage (const QString &)
 QETApp::setLanguage Change the language used by the application.
void switchLayout (Qt::LayoutDirection)
static QETApp * instance ()
 QETApp::instance.
static QString langFromSetting ()
 QETApp::langFromSetting.
static void printHelp ()
 QETApp::printHelp Display help and usage on standard output.
static void printVersion ()
 QETApp::printVersion Print version to standard output.
static void printLicense ()
 QETApp::printLicense Display license on standard output.
static ElementsCollectionCache * collectionCache ()
 QETApp::collectionCache.
static TitleBlockTemplatesFilesCollection * commonTitleBlockTemplatesCollection ()
 QETApp::commonTitleBlockTemplatesCollection.
static TitleBlockTemplatesFilesCollection * companyTitleBlockTemplatesCollection ()
 QETApp::companyTitleBlockTemplatesCollection.
static TitleBlockTemplatesFilesCollection * customTitleBlockTemplatesCollection ()
 QETApp::customTitleBlockTemplatesCollection.
static QList< TitleBlockTemplatesCollection * > availableTitleBlockTemplatesCollections ()
 QETApp::availableTitleBlockTemplatesCollections.
static TitleBlockTemplatesCollection * titleBlockTemplatesCollection (const QString &)
 QETApp::titleBlockTemplatesCollection.
static QString commonElementsDir ()
 QETApp::commonElementsDir.
static QString companyElementsDir ()
 QETApp::companyElementsDir.
static QString customElementsDir ()
 QETApp::customElementsDir.
static QString commonElementsDirN ()
 QETApp::commonElementsDirN like QString QETApp::commonElementsDir but without "/" at the end.
static QString companyElementsDirN ()
 QETApp::companyElementsDirN like QString QETApp::companyElementsDir but without "/" at the end.
static QString customElementsDirN ()
 QETApp::customElementsDirN like QString QETApp::customElementsDir but without "/" at the end.
static void resetCollectionsPath ()
 QETApp::resetCollectionsPath Reset the path of the user and common element collection and also the user titleblock path. Use this function when one of these three path change.
static QString commonTitleBlockTemplatesDir ()
 QETApp::commonTitleBlockTemplatesDir.
static QString companyTitleBlockTemplatesDir ()
 QETApp::companyTitleBlockTemplatesDir.
static QString customTitleBlockTemplatesDir ()
 QETApp::customTitleBlockTemplatesDir.
static QString userMacrosDir ()
 QETApp::userMacrosDir.
static bool registerProject (QETProject *)
 QETApp::registerProject.
static bool unregisterProject (QETProject *)
 QETApp::unregisterProject Cancel the recording of the project project.
static QMap< uint, QETProject * > registeredProjects ()
 QETApp::registeredProjects.
static QETProject * project (const uint &)
 QETApp::project.
static int projectId (const QETProject *)
 QETApp::projectId.
static QString configDir ()
 QETApp::configDir Return the QET configuration folder, i.e. the path to the folder in which QET will read configuration and customization information specific to the current user. This file is generally C:/Users/<USER>/AppData/Local/<APPNAME> on Windows and ~/.config/<APPNAME> under UNIX-like systems.
static QString dataDir ()
 QETApp::dataDir Return the QET data folder, i.e. the path to the folder in which QET will save log-files and elements-cache and where to find user-collections and user-titleblocks by default specific to the current user. This directory is generally C:/Users/<USER>/AppData/Roaming/<APPNAME> on Windows and ~/.local/share/<APPNAME> under UNIX-like systems.
static QString documentDir ()
 QETApp::documentDir Return the standard-folder where to save users documents This directory is generally C:/Users/<USER>/Documents on Windows and ~/Documents under UNIX-like systems.
static QString pictureDir ()
 QETApp::pictureDir Returns the standard-folder of users pictures This directory is generally C:/Users/<USER>/Pictures on Windows and ~/Pictures under UNIX-like systems.
static QString languagesPath ()
 QETApp::languagesPath.
static QString realPath (const QString &)
 QETApp::realPath Allows you to know the absolute path of the * .elmt file corresponding to a symbolic path (of the type custom: // tools_pervers / sado_maso / contact_bizarre).
static QString symbolicPath (const QString &)
 QETApp::symbolicPath Build the symbolic path (of the type custom: // tools_pervers / sado_maso / contact_bizarre) corresponding to a file.
static QStringList handledFileExtensions ()
 QETApp::handledFileExtensions.
static QStringList handledFiles (const QList< QUrl > &)
 QETApp::handledFiles.
static RecentFiles * projectsRecentFiles ()
 QETApp::projectsRecentFiles.
static RecentFiles * elementsRecentFiles ()
 QETApp::elementsRecentFiles.
static void overrideLangDir (const QString &)
 QETApp::overrideLangDir Redefines the path of the folder containing the language files.
static QFont diagramTextsFont (qreal=-1.0)
 QETApp::diagramTextsFont The font to use By default the font is "Liberation Sans" and size 9.
static QFont diagramTextsItemFont (qreal=-1.0)
 QETApp::diagramTextsItemFont the font to use in independent text items.
static QFont dynamicTextsItemFont (qreal=-1.0)
 QETApp::dynamicTextsFont the default font of dynamic element text item.
static QFont indiTextsItemFont (qreal=-1.0)
 QETApp::indiTextsItemFont The default font to use for independent text item.
static QETDiagramEditor * diagramEditorForFile (const QString &)
 QETApp::diagramEditorForFile.
static QETDiagramEditor * diagramEditorAncestorOf (const QWidget *child)
 QETApp::diagramEditorAncestorOf.
static QList< QETDiagramEditor * > diagramEditors ()
 QETApp::diagramEditors.
static QETDiagramEditor * diagramEditor (QETProject *project)
 QETApp::diagramEditor.
static QList< QETElementEditor * > elementEditors ()
 QETApp::elementEditors.
static QList< QETElementEditor * > elementEditors (QETProject *)
static QList< QETTitleBlockTemplateEditor * > titleBlockTemplateEditors ()
 QETApp::titleBlockTemplateEditors.
static QList< QETTitleBlockTemplateEditor * > titleBlockTemplateEditors (QETProject *)
static QTextOrientationSpinBoxWidget * createTextOrientationSpinBoxWidget ()
 QETApp::createTextOrientationSpinBoxWidget Instantiates a QTextOrientationSpinBoxWidget and configures:
static TitleBlockTemplate * defaultTitleBlockTemplate ()
 QETApp::defaultTitleBlockTemplate.
Static Public Attributes
static QString lang_dir = QString()
 lang_dir Directory containing localization files.
 QETApp (const QETApp &)
template<class T>
QList< T * > detectWindows () const
template<class T>
void setMainWindowsVisible (bool)
QList< QWidget * > floatingToolbarsAndDocksForMainWindow (QMainWindow *) const
 QETApp::floatingToolbarsAndDocksForMainWindow.
void parseArguments ()
 QETApp::parseArguments Parse the following arguments:
void initSplashScreen ()
 QETApp::initSplashScreen Initializes the splash screen if and only if the execution is interactive. Otherwise, the splash_screen_ attribute is 0.
void setSplashScreenStep (const QString &=QString())
 QETApp::setSplashScreenStep Changes the text of the splash screen and takes events into account. If the application is running non-interactively, this method does nothing.
void initLanguage ()
 QETApp::initLanguage Determine and apply the language to use for the application.
void initFonts ()
 QETApp::initFonts Setup the fonts to use in the application.
void initStyle ()
 QETApp::initStyle Setup the gui style.
void initConfiguration ()
 QETApp::initConfiguration Reads and takes into account the configuration of the application. This method will create, if necessary:
void initSystemTray ()
 QETApp::initSystemTray Build the icon in the systray and its menu.
void buildSystemTrayMenu ()
 QETApp::buildSystemTrayMenu builds the icon menu in the systray.
void checkBackupFiles ()
 QETApp::checkBackupFiles Check for backup files. If backup was found, open a dialog and ask user what to do.
void checkCrashDump ()
 QETApp::checkCrashDump Discussion #644, step 5: if the crash handler (step 4) left an unretrieved dump from a previous run, offer it to the user. Only called from checkBackupFiles() when there was no stale project file to recover this run, so the two prompts never both show at once.
void fetchWindowStats (const QList< QETDiagramEditor * > &, const QList< QETElementEditor * > &, const QList< QETTitleBlockTemplateEditor * > &)
 QETApp::fetchWindowStats Updates the booleans concerning the state of the windows.
template<class T>
void addWindowsListToMenu (QMenu *, const QList< T * > &)
static int projectIdFromString (const QString &)
 QETApp::projectIdFromString.
static QETProject * projectFromString (const QString &)
 QETApp::projectFromString.
QTranslator qtTranslator
QTranslator qetTranslator
QSystemTrayIcon * m_qsti
QSplashScreen * m_splash_screen
QMenu * menu_systray
QAction * quitter_qet
QAction * reduce_appli
QAction * restore_appli
QAction * reduce_diagrams
QAction * restore_diagrams
QAction * reduce_elements
QAction * restore_elements
QAction * reduce_templates
QAction * restore_templates
QAction * new_diagram
QAction * new_element
QHash< QMainWindow *, QByteArray > window_geometries
QHash< QMainWindow *, QByteArray > window_states
bool every_editor_reduced
bool every_diagram_reduced
bool every_diagram_visible
bool every_element_reduced
bool every_element_visible
bool every_template_reduced
bool every_template_visible
QSignalMapper signal_map
QETArguments qet_arguments_
 Command-line arguments parser.
bool non_interactive_execution_
 non_interactive_execution_ Whether the application will end without any user interaction
QPalette initial_palette_
 System color palette.
Static Private Attributes
static QETApp * m_qetapp = nullptr
static TitleBlockTemplatesFilesCollection * m_common_tbt_collection
static TitleBlockTemplatesFilesCollection * m_company_tbt_collection
static TitleBlockTemplatesFilesCollection * m_custom_tbt_collection
static ElementsCollectionCache * collections_cache_ = nullptr
static QMap< uint, QETProject * > registered_projects_ = QMap<uint, QETProject *>()
static uint next_project_id = 0
static RecentFiles * m_projects_recent_files = nullptr
static RecentFiles * m_elements_recent_files = nullptr
static TitleBlockTemplate * default_titleblock_template_ = nullptr
static QString m_common_element_dir = QString()
static bool m_common_element_dir_is_set = false
static QString m_company_element_dir = QString()
static bool m_company_element_dir_is_set = false
static QString m_custom_element_dir = QString()
static bool m_custom_element_dir_is_set = false
static QString m_user_company_tbt_dir = QString()
static QString m_user_custom_tbt_dir = QString()
static QString m_user_macros_dir = QString()
◆ QETApp() [1/2]
QETApp::QETApp ( )
QETApp::QETApp.
◆ ~QETApp()
QETApp::~QETApp ( )
QETApp::~QETApp.
◆ QETApp() [2/2]
QETApp::QETApp ( const QETApp & )
◆ aboutQET
void QETApp::aboutQET ( )
slot
◆ addWindowsListToMenu()
template<class T>
void QETApp::addWindowsListToMenu ( QMenu * menu,
const QList< T * > & windows )
Add a list of windows to menu. This template function assumes it will be given a QList of pointers to objects inheriting the QMainWindow class. T the class inheriting QMainWindow
menuthe menu windows will be added to
windowsA list of top-level windows.
◆ availableTitleBlockTemplatesCollections()
QList< TitleBlockTemplatesCollection * > QETApp::availableTitleBlockTemplatesCollections ( )
static
the list of all available title block templates collections, beginning with the common and custom ones, plus the projects-embedded ones.
◆ buildSystemTrayMenu()
void QETApp::buildSystemTrayMenu ( )
◆ checkBackupFiles()
void QETApp::checkBackupFiles ( )
◆ checkCrashDump()
void QETApp::checkCrashDump ( )
◆ checkRemainingWindows
void QETApp::checkRemainingWindows ( )
slot
◆ closeEveryEditor
bool QETApp::closeEveryEditor ( )
slot
true if the user has accepted all closures, false otherwise
◆ collectionCache()
ElementsCollectionCache * QETApp::collectionCache ( )
static
the collection cache provided by the application itself.
◆ commonElementsDir()
QString QETApp::commonElementsDir ( )
static
the dir path of the common elements collection.
◆ commonElementsDirN()
QString QETApp::commonElementsDirN ( )
static
QString path
◆ commonTitleBlockTemplatesCollection()
TitleBlockTemplatesFilesCollection * QETApp::commonTitleBlockTemplatesCollection ( )
static
the common title block templates collection, i.e. the one provided by QElecrotTech
◆ commonTitleBlockTemplatesDir()
QString QETApp::commonTitleBlockTemplatesDir ( )
static
the path of the directory containing the common title block templates collection.
◆ companyElementsDir()
QString QETApp::companyElementsDir ( )
static
the dir path of company elements collection appended with a "/" separator
◆ companyElementsDirN()
QString QETApp::companyElementsDirN ( )
static
QString path
◆ companyTitleBlockTemplatesCollection()
TitleBlockTemplatesFilesCollection * QETApp::companyTitleBlockTemplatesCollection ( )
static
the company's title block templates collection, i.e. the one managed by the admin
◆ companyTitleBlockTemplatesDir()
QString QETApp::companyTitleBlockTemplatesDir ( )
static
the path of the directory containing the company title block templates collection.
◆ configDir()
QString QETApp::configDir ( )
static
The path of the QElectroTech configuration folder
◆ configureQET
void QETApp::configureQET ( )
slot
See also
ConfigDialog
◆ createTextOrientationSpinBoxWidget()
QTextOrientationSpinBoxWidget * QETApp::createTextOrientationSpinBoxWidget ( )
static
  • his font
  • his strings
    Note
    that the deletion of the widget thus allocated is the responsibility of the caller.
    See also
◆ customElementsDir()
QString QETApp::customElementsDir ( )
static
the dir path of user elements collection appended with a "/" separator
◆ customElementsDirN()
QString QETApp::customElementsDirN ( )
static
QString path
◆ customTitleBlockTemplatesCollection()
TitleBlockTemplatesFilesCollection * QETApp::customTitleBlockTemplatesCollection ( )
static
the custom title block templates collection, i.e. the one managed by the end user
◆ customTitleBlockTemplatesDir()
QString QETApp::customTitleBlockTemplatesDir ( )
static
the path of the directory containing the custom title block templates collection.
◆ dataDir()
QString QETApp::dataDir ( )
static
The path of the QElectroTech data-folder
◆ defaultTitleBlockTemplate()
TitleBlockTemplate * QETApp::defaultTitleBlockTemplate ( )
static
the default titleblock template for diagrams
◆ detectWindows()
template<class T>
QList< T * > QETApp::detectWindows ( ) const
Ta class inheriting QMainWindow
the list of windows of type T
◆ diagramEditor()
QETDiagramEditor * QETApp::diagramEditor ( QETProject * project)
static
project
The diagram editor of project or nullptr.
◆ diagramEditorAncestorOf()
QETDiagramEditor * QETApp::diagramEditorAncestorOf ( const QWidget * child)
static
child
the parent QETDiagramEditor (or grandparent and so on to any level) of the given child. If not return nullptr;
◆ diagramEditorForFile()
QETDiagramEditor * QETApp::diagramEditorForFile ( const QString & filepath)
static
filepath: A file path
Note
if filepath is an empty string, this method returns 0.
the QETDiagramEditor editing the filepath file, or 0 if this file is not edited by the application.
◆ diagramEditors()
QList< QETDiagramEditor * > QETApp::diagramEditors ( )
static
schema editors
◆ diagramTextsFont()
QFont QETApp::diagramTextsFont ( qreal size = -1.0)
static
size: the size of font
the font to use
◆ diagramTextsItemFont()
QFont QETApp::diagramTextsItemFont ( qreal size = -1.0)
static
sizeof font
◆ documentDir()
QString QETApp::documentDir ( )
static
The path of users document-folder
◆ dynamicTextsItemFont()
QFont QETApp::dynamicTextsItemFont ( qreal size = -1.0)
static
size
dynamic text font with PointSizeF(size)
◆ elementEditors() [1/2]
QList< QETElementEditor * > QETApp::elementEditors ( )
static
element editors
◆ elementEditors() [2/2]
QList< QETElementEditor * > QETApp::elementEditors ( QETProject * project)
static
project: a project
element editors editing an element belonging to the QETProject project
◆ elementsRecentFiles()
RecentFiles * QETApp::elementsRecentFiles ( )
static
The list of recent files for the elements
◆ fetchWindowStats()
void QETApp::fetchWindowStats ( const QList< QETDiagramEditor * > & diagrams,
const QList< QETElementEditor * > & elements,
const QList< QETTitleBlockTemplateEditor * > & tbtemplates )
diagrams: QList<QETDiagramEditor *>
elements: QList<QETElementEditor *>
tbtemplates: QList<QETTitleBlockTemplateEditor *>
◆ floatingToolbarsAndDocksForMainWindow()
QList< QWidget * > QETApp::floatingToolbarsAndDocksForMainWindow ( QMainWindow * window) const
window: window where you have to find the toolbars and floating dock
the window's toolbars and floating dock
◆ handledFileExtensions()
QStringList QETApp::handledFileExtensions ( )
static
the list of file extensions QElectroTech is able to open and supposed to handle. Note they are provided with no leading point.
◆ handledFiles()
QStringList QETApp::handledFiles ( const QList< QUrl > & urls)
static
urls: URLs list
the list of filepaths QElectroTech is able to open.
◆ indiTextsItemFont()
QFont QETApp::indiTextsItemFont ( qreal size = -1.0)
static
size
independent text font with PointSizeF(size)
◆ initConfiguration()
void QETApp::initConfiguration ( )
  • the configuration folder
  • the folder of the personal collection
  • the directory for custom title blocks
◆ initFonts()
void QETApp::initFonts ( )
"Liberation Fonts" Font Software is licensed under the SIL Open Font License, Version 1.1
See the file "fonts/liberation-fonts.LICENSE" for license information.
"osifont" Font Software is licensed under the GNU GENERAL PUBLIC LICENSE, Version 3 As a special exception, if you create a document which uses this font, and embed this font or unaltered portions of this font into the document, this font does not by itself cause the resulting document to be covered by the GNU General Public License. This exception does not however invalidate any other reasons why the document might be covered by the GNU General Public License. If you modify this font, you may extend this exception to your version of the font, but you are not obligated to do so. If you do not wish to do so, delete this exception statement from your version.
See the file "fonts/osifont.LICENSE" for license information.
◆ initLanguage()
void QETApp::initLanguage ( )
◆ initSplashScreen()
void QETApp::initSplashScreen ( )
◆ initStyle()
void QETApp::initStyle ( )
◆ initSystemTray()
void QETApp::initSystemTray ( )
◆ instance()
QETApp * QETApp::instance ( )
static
QETApp::instance.
the instance of the QETApp
◆ invertMainWindowVisibility
void QETApp::invertMainWindowVisibility ( QWidget * window)
slot
window: window to show / hide
◆ langFromSetting()
QString QETApp::langFromSetting ( )
static
the langage found in setting file if nothing was found return the system local.
◆ languagesPath()
QString QETApp::languagesPath ( )
static
The path of the folder containing the language files
◆ newDiagramEditor
void QETApp::newDiagramEditor ( )
slot
◆ newElementEditor
void QETApp::newElementEditor ( )
slot
◆ openElementFiles
void QETApp::openElementFiles ( const QStringList & files_list)
slot
files_list: Files to open
◆ openElementLocations
void QETApp::openElementLocations ( const QList< ElementsLocation > & locations_list)
slot
locations_list: Locations to open
◆ openFiles
void QETApp::openFiles ( const QETArguments & args)
slot
args: Object containing arguments; the files
See also
openProjectFiles openElementFiles
◆ openProjectFiles
void QETApp::openProjectFiles ( const QStringList & files_list)
slot
◆ openTitleBlockTemplate [1/2]
void QETApp::openTitleBlockTemplate ( const QString & filepath)
slot
filepathPath of the .titleblock file to be opened
◆ openTitleBlockTemplate [2/2]
void QETApp::openTitleBlockTemplate ( const TitleBlockTemplateLocation & location,
bool duplicate = false )
slot
locationlocation of the title block template to be edited
duplicateif true, the template is opened for duplication, which means the user will be prompter for a new template name.
See also
QETTitleBlockTemplateEditor::setOpenForDuplication()
◆ openTitleBlockTemplateFiles
void QETApp::openTitleBlockTemplateFiles ( const QStringList & files_list)
slot
files_listFiles to be opened
◆ overrideLangDir()
void QETApp::overrideLangDir ( const QString & new_ld)
static
new_ld: New path of the folder containing the language files
◆ parseArguments()
void QETApp::parseArguments ( )
  • –common-elements-dir=
  • –config-dir
  • –data-dir
  • –help
  • –version
  • -v
  • –license
The other arguments are normally file paths. If they exist, they are just stored in the arguments_files_ attribute. Otherwise, they are stored in the arguments_options_ attribute.
◆ pictureDir()
QString QETApp::pictureDir ( )
static
The path of users picture-folder
◆ printHelp()
void QETApp::printHelp ( )
static
◆ printLicense()
void QETApp::printLicense ( )
static
◆ printVersion()
void QETApp::printVersion ( )
static
◆ project()
QETProject * QETApp::project ( const uint & id)
static
QETApp::project.
id: Id of the desired project
the project corresponds to the id passed in parameter
◆ projectFromString()
QETProject * QETApp::projectFromString ( const QString & url)
staticprivate
urlThe location of a collection item (title block template, element, category, ...).
the project mentionned in the URL, or 0 if none could be found.
◆ projectId()
int QETApp::projectId ( const QETProject * project)
static
QETApp::projectId.
project: Project whose id we want to retrieve
the project id as a parameter if it is saved, -1 otherwise
◆ projectIdFromString()
int QETApp::projectIdFromString ( const QString & url)
staticprivate
the id of the project mentionned in the URL, or -1 if none could be found.
◆ projectsRecentFiles()
RecentFiles * QETApp::projectsRecentFiles ( )
static
The list of recent files for projects
◆ quitQET
void QETApp::quitQET ( )
slot
◆ realPath()
QString QETApp::realPath ( const QString & sym_path)
static
sym_pathCharacter string representing the absolute path of the file
An empty string in case of error or the absolute path of the * .elmt file.
◆ receiveMessage
void QETApp::receiveMessage ( int instanceId,
QByteArray message )
slot
instanceIdQ_UNUSED
message
◆ reduceDiagramEditors
void QETApp::reduceDiagramEditors ( )
slot
◆ reduceElementEditors
void QETApp::reduceElementEditors ( )
slot
◆ reduceEveryEditor
void QETApp::reduceEveryEditor ( )
slot
◆ reduceTitleBlockTemplateEditors
void QETApp::reduceTitleBlockTemplateEditors ( )
slot
◆ registeredProjects()
QMap< uint, QETProject * > QETApp::registeredProjects ( )
static
the list of projects with their associated ids
◆ registerProject()
bool QETApp::registerProject ( QETProject * project)
static
project: Project to register with the application
true if the project could be saved, false otherwise Failure to save a project usually means that it is already saved.
◆ resetCollectionsPath()
void QETApp::resetCollectionsPath ( )
static
◆ restoreDiagramEditors
void QETApp::restoreDiagramEditors ( )
slot
◆ restoreElementEditors
void QETApp::restoreElementEditors ( )
slot
◆ restoreEveryEditor
void QETApp::restoreEveryEditor ( )
slot
◆ restoreTitleBlockTemplateEditors
void QETApp::restoreTitleBlockTemplateEditors ( )
slot
◆ setLanguage()
void QETApp::setLanguage ( const QString & desired_language)
desired_language: wanted language
◆ setMainWindowsVisible()
template<class T>
void QETApp::setMainWindowsVisible ( bool visible)
T a class inheriting QMainWindow
visiblewhether detected main windows should be visible
◆ setMainWindowVisible
void QETApp::setMainWindowVisible ( QMainWindow * window,
bool visible )
slot
visible: true to display the window, false otherwise
◆ setSplashScreenStep()
void QETApp::setSplashScreenStep ( const QString & message = QString())
message: the text of the splash screen
◆ showDiagnosticsReport
void QETApp::showDiagnosticsReport ( )
slot
◆ switchLayout()
void QETApp::switchLayout ( Qt::LayoutDirection direction)
Switches the application to the provided layout.
◆ symbolicPath()
QString QETApp::symbolicPath ( const QString & real_path)
static
real_path: Character string representing the symbolic path of the file
An empty string in case of error or the path symbolic designating the element.
◆ systray
void QETApp::systray ( QSystemTrayIcon::ActivationReason reason)
slot
reason: reason an integer representing the event on the systray
◆ titleBlockTemplateEditors() [1/2]
QList< QETTitleBlockTemplateEditor * > QETApp::titleBlockTemplateEditors ( )
static
the title block template editors
◆ titleBlockTemplateEditors() [2/2]
QList< QETTitleBlockTemplateEditor * > QETApp::titleBlockTemplateEditors ( QETProject * project)
static
projectOpened project object.
the list of title block template editors which are currently editing a template embedded within project.
◆ titleBlockTemplatesCollection()
TitleBlockTemplatesCollection * QETApp::titleBlockTemplatesCollection ( const QString & protocol)
static
protocolProtocol string
the templates collection matching the provided protocol, or 0 if none could be found
◆ unregisterProject()
bool QETApp::unregisterProject ( QETProject * project)
static
project: Project to be unregistered
true if the cancellation was successful, false otherwise The failure of this method usually means that the project was not saved.
◆ userMacrosDir()
QString QETApp::userMacrosDir ( )
static
the path of the directory containing the user macros collection.
◆ useSystemPalette
void QETApp::useSystemPalette ( bool use)
slot
use: true to use the system colors, false to use those of the current theme
◆ collections_cache_
ElementsCollectionCache * QETApp::collections_cache_ = nullptr
staticprivate
◆ default_titleblock_template_
TitleBlockTemplate * QETApp::default_titleblock_template_ = nullptr
staticprivate
◆ every_diagram_reduced
bool QETApp::every_diagram_reduced
◆ every_diagram_visible
bool QETApp::every_diagram_visible
◆ every_editor_reduced
bool QETApp::every_editor_reduced
◆ every_element_reduced
bool QETApp::every_element_reduced
◆ every_element_visible
bool QETApp::every_element_visible
◆ every_template_reduced
bool QETApp::every_template_reduced
◆ every_template_visible
bool QETApp::every_template_visible
◆ initial_palette_
QPalette QETApp::initial_palette_
◆ lang_dir
QString QETApp::lang_dir = QString()
static
◆ m_common_element_dir
QString QETApp::m_common_element_dir = QString()
staticprivate
◆ m_common_element_dir_is_set
bool QETApp::m_common_element_dir_is_set = false
staticprivate
◆ m_common_tbt_collection
TitleBlockTemplatesFilesCollection * QETApp::m_common_tbt_collection
staticprivate
◆ m_company_element_dir
QString QETApp::m_company_element_dir = QString()
staticprivate
◆ m_company_element_dir_is_set
bool QETApp::m_company_element_dir_is_set = false
staticprivate
◆ m_company_tbt_collection
TitleBlockTemplatesFilesCollection * QETApp::m_company_tbt_collection
staticprivate
◆ m_custom_element_dir
QString QETApp::m_custom_element_dir = QString()
staticprivate
◆ m_custom_element_dir_is_set
bool QETApp::m_custom_element_dir_is_set = false
staticprivate
◆ m_custom_tbt_collection
TitleBlockTemplatesFilesCollection * QETApp::m_custom_tbt_collection
staticprivate
◆ m_elements_recent_files
RecentFiles * QETApp::m_elements_recent_files = nullptr
staticprivate
◆ m_projects_recent_files
RecentFiles * QETApp::m_projects_recent_files = nullptr
staticprivate
◆ m_qetapp
QETApp * QETApp::m_qetapp = nullptr
staticprivate
◆ m_qsti
QSystemTrayIcon* QETApp::m_qsti
◆ m_splash_screen
QSplashScreen* QETApp::m_splash_screen
◆ m_user_company_tbt_dir
QString QETApp::m_user_company_tbt_dir = QString()
staticprivate
◆ m_user_custom_tbt_dir
QString QETApp::m_user_custom_tbt_dir = QString()
staticprivate
◆ m_user_macros_dir
QString QETApp::m_user_macros_dir = QString()
staticprivate
◆ menu_systray
QMenu* QETApp::menu_systray
◆ new_diagram
QAction* QETApp::new_diagram
◆ new_element
QAction* QETApp::new_element
◆ next_project_id
uint QETApp::next_project_id = 0
staticprivate
◆ non_interactive_execution_
bool QETApp::non_interactive_execution_
◆ qet_arguments_
QETArguments QETApp::qet_arguments_
◆ qetTranslator
QTranslator QETApp::qetTranslator
◆ qtTranslator
QTranslator QETApp::qtTranslator
◆ quitter_qet
QAction* QETApp::quitter_qet
◆ reduce_appli
QAction* QETApp::reduce_appli
◆ reduce_diagrams
QAction* QETApp::reduce_diagrams
◆ reduce_elements
QAction* QETApp::reduce_elements
◆ reduce_templates
QAction* QETApp::reduce_templates
◆ registered_projects_
QMap< uint, QETProject * > QETApp::registered_projects_ = QMap<uint, QETProject *>()
staticprivate
◆ restore_appli
QAction* QETApp::restore_appli
◆ restore_diagrams
QAction* QETApp::restore_diagrams
◆ restore_elements
QAction* QETApp::restore_elements
◆ restore_templates
QAction* QETApp::restore_templates
◆ signal_map
QSignalMapper QETApp::signal_map
◆ window_geometries
QHash<QMainWindow *, QByteArray> QETApp::window_geometries
◆ window_states
QHash<QMainWindow *, QByteArray> QETApp::window_states
