27#include <QSystemTrayIcon>
35#define QETAPP_COMMON_TBT_PROTOCOL "commontbt"
36#define QETAPP_COMPANY_TBT_PROTOCOL "companytbt"
37#define QETAPP_CUSTOM_TBT_PROTOCOL "customtbt"
105 static QString
realPath(
const QString &);
112#ifdef QET_ALLOW_OVERRIDE_CED_OPTION
114 static void overrideCommonElementsDir(
const QString &);
120 static QString m_overrided_common_elements_dir;
123#ifdef QET_ALLOW_OVERRIDE_CTBTD_OPTION
125 static void overrideCommonTitleBlockTemplatesDir(
const QString &);
132 static QString common_tbt_dir_;
135#ifdef QET_ALLOW_OVERRIDE_CD_OPTION
137 static void overrideConfigDir(
const QString &);
144 static QString config_dir;
147#ifdef QET_ALLOW_OVERRIDE_DD_OPTION
149 static void overrideDataDir(
const QString &);
156 static QString data_dir;
183 bool eventFilter(QObject *
object, QEvent *)
override;
248 void systray(QSystemTrayIcon::ActivationReason);
293 const QList<QETDiagramEditor *> &,
294 const QList<QETElementEditor *> &,
295 const QList<QETTitleBlockTemplateEditor *> &
Definition elementscollectioncache.h:32
bool every_template_reduced
Definition qetapp.h:212
static TitleBlockTemplatesFilesCollection * customTitleBlockTemplatesCollection()
QETApp::customTitleBlockTemplatesCollection.
Definition qetapp.cpp:488
void configureQET()
QETApp::configureQET Allows the user to configure QET by launching an appropriate dialog.
Definition qetapp.cpp:2041
void newElementEditor()
QETApp::newElementEditor launches a new element editor.
Definition qetapp.cpp:427
static QString customElementsDir()
QETApp::customElementsDir.
Definition qetapp.cpp:656
QAction * reduce_diagrams
Definition qetapp.h:197
static QString m_custom_element_dir
Definition qetapp.h:240
bool every_template_visible
Definition qetapp.h:213
static RecentFiles * elementsRecentFiles()
QETApp::elementsRecentFiles.
Definition qetapp.cpp:1680
void openProjectFiles(const QStringList &)
QETApp::openProjectFiles Opens a list of files. Files are opened in the first visible schematic edito...
Definition qetapp.cpp:1835
void initStyle()
QETApp::initStyle Setup the gui style.
Definition qetapp.cpp:2289
static QString configDir()
QETApp::configDir Return the QET configuration folder, i.e. the path to the folder in which QET will ...
Definition qetapp.cpp:933
QAction * quitter_qet
Definition qetapp.h:194
QMenu * menu_systray
Definition qetapp.h:193
static bool m_company_element_dir_is_set
Definition qetapp.h:238
static QFont diagramTextsFont(qreal=-1.0)
QETApp::diagramTextsFont The font to use By default the font is "Liberation Sans" and size 9.
Definition qetapp.cpp:1358
bool every_element_reduced
Definition qetapp.h:210
void setLanguage(const QString &)
QETApp::setLanguage Change the language used by the application.
Definition qetapp.cpp:208
static RecentFiles * m_projects_recent_files
Definition qetapp.h:230
void openFiles(const QETArguments &)
QETApp::openFiles Open files passed as arguments.
Definition qetapp.cpp:1814
static QString m_user_custom_tbt_dir
Definition qetapp.h:244
void reduceEveryEditor()
QETApp::reduceEveryEditor Minimizes all application windows in the systray.
Definition qetapp.cpp:332
static TitleBlockTemplate * default_titleblock_template_
Definition qetapp.h:232
QTranslator qtTranslator
Definition qetapp.h:189
void invertMainWindowVisibility(QWidget *)
QETApp::invertMainWindowVisibility Display a window (schema editors / element editors) if this is hid...
Definition qetapp.cpp:1723
static RecentFiles * m_elements_recent_files
Definition qetapp.h:231
static QString dataDir()
QETApp::dataDir Return the QET data folder, i.e. the path to the folder in which QET will save log-fi...
Definition qetapp.cpp:960
QAction * new_element
Definition qetapp.h:204
static QString documentDir()
QETApp::documentDir Return the standard-folder where to save users documents This directory is genera...
Definition qetapp.cpp:985
static bool registerProject(QETProject *)
QETApp::registerProject.
Definition qetapp.cpp:2825
void restoreElementEditors()
QETApp::restoreElementEditors Restore all element editors in the systray.
Definition qetapp.cpp:389
void initConfiguration()
QETApp::initConfiguration Reads and takes into account the configuration of the application....
Definition qetapp.cpp:2312
void showDiagnosticsReport()
QETApp::showDiagnosticsReport Discussion #644, step 5: the manual "Help > Diagnostics > Savereport" a...
Definition qetapp.cpp:2673
QAction * reduce_templates
Definition qetapp.h:201
QSplashScreen * m_splash_screen
Definition qetapp.h:192
static QETApp * instance()
QETApp::instance.
Definition qetapp.cpp:195
QList< QWidget * > floatingToolbarsAndDocksForMainWindow(QMainWindow *) const
QETApp::floatingToolbarsAndDocksForMainWindow.
Definition qetapp.cpp:2099
void restoreDiagramEditors()
QETApp::restoreDiagramEditors Restore all schema editors in the systray.
Definition qetapp.cpp:368
void openTitleBlockTemplateFiles(const QStringList &)
QETApp::openTitleBlockTemplateFiles Open provided title block template files. If a title block templa...
Definition qetapp.cpp:2000
static QString realPath(const QString &)
QETApp::realPath Allows you to know the absolute path of the * .elmt file corresponding to a symbolic...
Definition qetapp.cpp:1029
void checkBackupFiles()
QETApp::checkBackupFiles Check for backup files. If backup was found, open a dialog and ask user what...
Definition qetapp.cpp:2556
static TitleBlockTemplatesFilesCollection * companyTitleBlockTemplatesCollection()
QETApp::companyTitleBlockTemplatesCollection.
Definition qetapp.cpp:467
void setMainWindowVisible(QMainWindow *, bool)
QETApp::setMainWindowVisible Show or hide a window (schema editors / element editors).
Definition qetapp.cpp:1695
void reduceTitleBlockTemplateEditors()
QETApp::reduceTitleBlockTemplateEditors Reduce all known template editors.
Definition qetapp.cpp:398
void addWindowsListToMenu(QMenu *, const QList< T * > &)
Definition qetapp.cpp:2436
QSignalMapper signal_map
Definition qetapp.h:214
void useSystemPalette(bool)
QETApp::useSystemPalette Change the application palette.
Definition qetapp.cpp:1737
static bool m_common_element_dir_is_set
Definition qetapp.h:235
static QString companyElementsDirN()
QETApp::companyElementsDirN like QString QETApp::companyElementsDir but without "/" at the end.
Definition qetapp.cpp:742
static QString m_user_company_tbt_dir
Definition qetapp.h:243
bool every_element_visible
Definition qetapp.h:211
static bool m_custom_element_dir_is_set
Definition qetapp.h:241
QAction * restore_templates
Definition qetapp.h:202
static QString commonElementsDir()
QETApp::commonElementsDir.
Definition qetapp.cpp:592
static QStringList handledFiles(const QList< QUrl > &)
QETApp::handledFiles.
Definition qetapp.cpp:1120
static int projectId(const QETProject *)
QETApp::projectId.
Definition qetapp.cpp:2890
QAction * restore_appli
Definition qetapp.h:196
static TitleBlockTemplatesFilesCollection * m_custom_tbt_collection
Definition qetapp.h:226
static QETProject * project(const uint &)
QETApp::project.
Definition qetapp.cpp:2873
~QETApp() override
QETApp::~QETApp.
Definition qetapp.cpp:166
QAction * restore_diagrams
Definition qetapp.h:198
void receiveMessage(int instanceId, QByteArray message)
QETApp::receiveMessage openFiles from message.
Definition qetapp.cpp:1625
bool every_editor_reduced
Definition qetapp.h:207
static TitleBlockTemplatesFilesCollection * m_common_tbt_collection
Definition qetapp.h:224
static TitleBlockTemplate * defaultTitleBlockTemplate()
QETApp::defaultTitleBlockTemplate.
Definition qetapp.cpp:1576
static int projectIdFromString(const QString &)
QETApp::projectIdFromString.
Definition qetapp.cpp:2455
void buildSystemTrayMenu()
QETApp::buildSystemTrayMenu builds the icon menu in the systray.
Definition qetapp.cpp:2499
static QString languagesPath()
QETApp::languagesPath.
Definition qetapp.cpp:1278
static QString companyElementsDir()
QETApp::companyElementsDir.
Definition qetapp.cpp:693
static void printLicense()
QETApp::printLicense Display license on standard output.
Definition qetapp.cpp:2799
static QList< QETTitleBlockTemplateEditor * > titleBlockTemplateEditors()
QETApp::titleBlockTemplateEditors.
Definition qetapp.cpp:1511
void setMainWindowsVisible(bool)
Definition qetapp.cpp:1659
static QETApp * m_qetapp
Definition qetapp.h:188
QHash< QMainWindow *, QByteArray > window_states
Definition qetapp.h:206
static QETDiagramEditor * diagramEditorForFile(const QString &)
QETApp::diagramEditorForFile.
Definition qetapp.cpp:1146
static QString commonTitleBlockTemplatesDir()
QETApp::commonTitleBlockTemplatesDir.
Definition qetapp.cpp:790
void newDiagramEditor()
QETApp::newDiagramEditor launches a new schema editor.
Definition qetapp.cpp:417
QETApp::systray Manages QSystemTrayIcon related events.
Definition qetapp.cpp:297
bool non_interactive_execution_
non_interactive_execution_ Whether the application will end without any user interaction
Definition qetapp.h:221
void setSplashScreenStep(const QString &=QString())
QETApp::setSplashScreenStep Changes the text of the splash screen and takes events into account....
Definition qetapp.cpp:2222
static QString userMacrosDir()
QETApp::userMacrosDir.
Definition qetapp.cpp:885
static QList< QETElementEditor * > elementEditors()
QETApp::elementEditors.
Definition qetapp.cpp:1502
static QETDiagramEditor * diagramEditorAncestorOf(const QWidget *child)
QETApp::diagramEditorAncestorOf.
Definition qetapp.cpp:1167
static uint next_project_id
Definition qetapp.h:229
void restoreEveryEditor()
QETApp::restoreEveryEditor Restores all application windows in the systray.
Definition qetapp.cpp:345
static QString lang_dir
lang_dir Directory containing localization files.
Definition qetapp.h:165
static QList< TitleBlockTemplatesCollection * > availableTitleBlockTemplatesCollections()
QETApp::availableTitleBlockTemplatesCollections.
Definition qetapp.cpp:508
static TitleBlockTemplatesFilesCollection * m_company_tbt_collection
Definition qetapp.h:225
static QString commonElementsDirN()
QETApp::commonElementsDirN like QString QETApp::commonElementsDir but without "/" at the end.
Definition qetapp.cpp:730
void openTitleBlockTemplate(const TitleBlockTemplateLocation &, bool=false)
QETApp::openTitleBlockTemplate Launch a new title block template editor to edit the given template.
Definition qetapp.cpp:1972
void parseArguments()
QETApp::parseArguments Parse the following arguments:
Definition qetapp.cpp:2142
static QTextOrientationSpinBoxWidget * createTextOrientationSpinBoxWidget()
QETApp::createTextOrientationSpinBoxWidget Instantiates a QTextOrientationSpinBoxWidget and configure...
Definition qetapp.cpp:1553
static QString customTitleBlockTemplatesDir()
QETApp::customTitleBlockTemplatesDir.
Definition qetapp.cpp:853
static QString customElementsDirN()
QETApp::customElementsDirN like QString QETApp::customElementsDir but without "/" at the end.
Definition qetapp.cpp:754
void initLanguage()
QETApp::initLanguage Determine and apply the language to use for the application.
Definition qetapp.cpp:2236
static QFont indiTextsItemFont(qreal=-1.0)
QETApp::indiTextsItemFont The default font to use for independent text item.
Definition qetapp.cpp:1450
static QList< QETDiagramEditor * > diagramEditors()
QETApp::diagramEditors.
Definition qetapp.cpp:1471
QAction * new_diagram
Definition qetapp.h:203
static ElementsCollectionCache * collectionCache()
QETApp::collectionCache.
Definition qetapp.cpp:436
void restoreTitleBlockTemplateEditors()
QETApp::restoreTitleBlockTemplateEditors Restore all known template editors.
Definition qetapp.cpp:407
QHash< QMainWindow *, QByteArray > window_geometries
Definition qetapp.h:205
static QString pictureDir()
QETApp::pictureDir Returns the standard-folder of users pictures This directory is generally C:/Users...
Definition qetapp.cpp:1004
QAction * reduce_elements
Definition qetapp.h:199
void quitQET()
QETApp::quitQET Request the closing of all windows; if the user accepts them, the application quits.
Definition qetapp.cpp:1766
void reduceElementEditors()
QETApp::reduceElementEditors Minimize all element editors in systray.
Definition qetapp.cpp:379
void openElementLocations(const QList< ElementsLocation > &)
QETApp::openElementLocations Open the elements whose location is passed in parameter....
Definition qetapp.cpp:1932
QList< T * > detectWindows() const
Definition qetapp.cpp:1643
static bool unregisterProject(QETProject *)
QETApp::unregisterProject Cancel the recording of the project project.
Definition qetapp.cpp:2852
void aboutQET()
QETApp::aboutQET Open the dialog about qet.
Definition qetapp.cpp:2081
static QString m_user_macros_dir
Definition qetapp.h:245
static QString companyTitleBlockTemplatesDir()
QETApp::companyTitleBlockTemplatesDir.
Definition qetapp.cpp:820
bool every_diagram_visible
Definition qetapp.h:209
void reduceDiagramEditors()
QETApp::reduceDiagramEditors Minimize all schema editors in the systray.
Definition qetapp.cpp:358
static void printHelp()
QETApp::printHelp Display help and usage on standard output.
Definition qetapp.cpp:2756
static QFont dynamicTextsItemFont(qreal=-1.0)
QETApp::dynamicTextsFont the default font of dynamic element text item.
Definition qetapp.cpp:1426
void checkCrashDump()
QETApp::checkCrashDump Discussion #644, step 5: if the crash handler (step 4) left an unretrieved dum...
Definition qetapp.cpp:2645
static QFont diagramTextsItemFont(qreal=-1.0)
QETApp::diagramTextsItemFont the font to use in independent text items.
Definition qetapp.cpp:1392
void initSplashScreen()
QETApp::initSplashScreen Initializes the splash screen if and only if the execution is interactive....
Definition qetapp.cpp:2203
bool closeEveryEditor()
QETApp::closeEveryEditor Close all editors.
Definition qetapp.cpp:1333
static TitleBlockTemplatesCollection * titleBlockTemplatesCollection(const QString &)
QETApp::titleBlockTemplatesCollection.
Definition qetapp.cpp:529
void checkRemainingWindows()
QETApp::checkRemainingWindows Check if there are any windows (hidden or not) and exit if there are no...
Definition qetapp.cpp:1783
QAction * reduce_appli
Definition qetapp.h:195
QAction * restore_elements
Definition qetapp.h:200
static RecentFiles * projectsRecentFiles()
QETApp::projectsRecentFiles.
Definition qetapp.cpp:1670
QTranslator qetTranslator
Definition qetapp.h:190
void initFonts()
QETApp::initFonts Setup the fonts to use in the application.
Definition qetapp.cpp:2245
static QStringList handledFileExtensions()
QETApp::handledFileExtensions.
Definition qetapp.cpp:1104
bool every_diagram_reduced
Definition qetapp.h:208
void switchLayout(Qt::LayoutDirection)
static QMap< uint, QETProject * > registeredProjects()
QETApp::registeredProjects.
Definition qetapp.cpp:2809
static QString langFromSetting()
QETApp::langFromSetting.
static QETProject * projectFromString(const QString &)
QETApp::projectFromString.
Definition qetapp.cpp:2488
static ElementsCollectionCache * collections_cache_
Definition qetapp.h:227
QSystemTrayIcon * m_qsti
Definition qetapp.h:191
static QETDiagramEditor * diagramEditor(QETProject *project)
QETApp::diagramEditor.
Definition qetapp.cpp:1481
QPalette initial_palette_
System color palette.
Definition qetapp.h:222
void initSystemTray()
QETApp::initSystemTray Build the icon in the systray and its menu.
Definition qetapp.cpp:2366
void fetchWindowStats(const QList< QETDiagramEditor * > &, const QList< QETElementEditor * > &, const QList< QETTitleBlockTemplateEditor * > &)
QETApp::fetchWindowStats Updates the booleans concerning the state of the windows.
Definition qetapp.cpp:2693
QETArguments qet_arguments_
Command-line arguments parser.
Definition qetapp.h:215
static void resetCollectionsPath()
QETApp::resetCollectionsPath Reset the path of the user and common element collection and also the us...
Definition qetapp.cpp:767
void openElementFiles(const QStringList &)
QETApp::openElementFiles Open the elements files passed in parameter. If an element is already open,...
Definition qetapp.cpp:1881
static QMap< uint, QETProject * > registered_projects_
Definition qetapp.h:228
static void overrideLangDir(const QString &)
QETApp::overrideLangDir Redefines the path of the folder containing the language files.
Definition qetapp.cpp:1265
static QString symbolicPath(const QString &)
QETApp::symbolicPath Build the symbolic path (of the type custom: // tools_pervers / sado_maso / cont...
Definition qetapp.cpp:1069
static TitleBlockTemplatesFilesCollection * commonTitleBlockTemplatesCollection()
QETApp::commonTitleBlockTemplatesCollection.
Definition qetapp.cpp:446
static QString m_company_element_dir
Definition qetapp.h:237
QETApp()
QETApp::QETApp.
static void printVersion()
QETApp::printVersion Print version to standard output.
Definition qetapp.cpp:2789
static QString m_common_element_dir
Definition qetapp.h:234
Definition qetarguments.h:26
Definition qetdiagrameditor.h:53
Definition qetelementeditor.h:39
Definition qetproject.h:77
Definition qettemplateeditor.h:38
Definition qtextorientationspinboxwidget.h:27
Definition recentfiles.h:26
The TitleBlockTemplate class This class represents an title block template for an electric diagram....
Definition titleblocktemplate.h:38
Definition templatelocation.h:29
Definition templatescollection.h:35
Definition templatescollection.h:125
