QElectroTech 0.100.0-dev
#include <polygoneditor.h>
Public Member Functions | |
| PolygonEditor (QETElementEditor *editor, PartPolygon *part=nullptr, QWidget *parent=nullptr) | |
| PolygonEditor::PolygonEditor. | |
| ~PolygonEditor () override | |
| PolygonEditor::~PolygonEditor. | |
| bool | setPart (CustomElementPart *part) override |
| PolygonEditor::setPart. | |
| CustomElementPart * | currentPart () const override |
| PolygonEditor::currentPart. | |
| QList< CustomElementPart * > | currentParts () const override |
| void | updateForm () override |
| PolygonEditor::updateForm Update the widget. | |
| QVector< QPointF > | pointsFromTree () |
| PolygonEditor::pointsFromTree. | |
| bool | eventFilter (QObject *watched, QEvent *event) override |
Public Member Functions inherited from ElementItemEditor | |
| ElementItemEditor (QETElementEditor *, QWidget *=nullptr) | |
| ~ElementItemEditor () override | |
| virtual QETElementEditor * | elementEditor () const |
| virtual ElementScene * | elementScene () const |
| virtual QUndoStack & | undoStack () const |
| virtual QString | elementTypeName () const |
| virtual void | setElementTypeName (const QString &) |
| virtual void | detach () |
| virtual bool | setParts (QList< CustomElementPart * >) |
Private Slots | |
| void | on_m_close_polygon_cb_stateChanged (int arg1) |
| PolygonEditor::on_m_close_polygon_cb_stateChanged. | |
| void | on_m_points_list_tree_itemChanged (QTreeWidgetItem *item, int column) |
| PolygonEditor::on_m_points_list_tree_itemChanged Update the polygon according to the current value of the tree editor. | |
| void | on_m_points_list_tree_itemSelectionChanged () |
| PolygonEditor::on_m_points_list_tree_itemSelectionChanged Used to change the color of the current selected point. | |
| void | on_m_add_point_action_triggered () |
| void | on_m_remove_point_action_triggered () |
Private Member Functions | |
| void | setUpChangeConnections () |
| setUpChangeConnections Setup the connection from the line(s) to the widget, to update it when the line(s) are changed (moved ...) | |
| void | disconnectChangeConnections () |
Private Attributes | |
| Ui::PolygonEditor * | ui |
| StyleEditor * | m_style = nullptr |
| PartPolygon * | m_part = nullptr |
| QList< QMetaObject::Connection > | m_change_connections |
explicit |
| editor | |
| part | |
| parent |
override |
overridevirtual |
overridevirtual |
private |
override |
privateslot |
privateslot |
privateslot |
privateslot |
privateslot |
| QVector< QPointF > PolygonEditor::pointsFromTree | ( | ) |
overridevirtual |
private |
overridevirtual |
Implements ElementItemEditor.
private |
private |
private |
private |
