QElectroTech 0.100.0-dev
Enumerations | |
| enum | PropertyFlags { Success = 0 , NotFound = 1 , NoValidConversion = 2 } |
Functions | |
| QString | boolToString (bool value) |
| boolToString | |
| bool | boolFromString (const QString &value, bool default_value, bool *conv_ok) |
boolFromString return value converted to bool | |
| PropertyFlags | debugReadXml (PropertyFlags flag, const QDomElement &e, const QString &attribute_name, const QString &attr, const QString &type) |
| QDomElement | createXmlProperty (const QString &name, const QString value) |
| Use this functions to add properties to the xml document. | |
| QDomElement | createXmlProperty (const QString &name, const char *value) |
| QDomElement | createXmlProperty (const QString &name, const int value) |
| propertyInteger Reads an integer from the XML element. | |
| QDomElement | createXmlProperty (const QString &name, const double value) |
| QDomElement | createXmlProperty (const QString &name, const bool value) |
| QDomElement | createXmlProperty (const QString &name, const QUuid value) |
| QDomElement | createXmlProperty (const QString &name, const QColor value) |
| PropertyFlags | propertyInteger (const QDomElement &e, const QString &attribute_name, int *entier) |
| PropertiesInterface::propertyInteger Reads an integer from the XML element. | |
| PropertyFlags | propertyInteger (const QString &value, int *entier) |
| PropertyFlags | propertyDouble (const QDomElement &e, const QString &attribute_name, double *reel) |
| PropertyFlags | propertyDouble (const QString &value, double *reel) |
| PropertyFlags | propertyBool (const QDomElement &e, const QString &attribute_name, bool *boolean) |
| PropertyFlags | propertyBool (const QString &value, bool *boolean) |
| PropertyFlags | propertyColor (const QDomElement &e, const QString &attribute_name, QColor *color) |
| PropertyFlags | propertyColor (const QString &value, QColor *color) |
| PropertyFlags | propertyUuid (const QDomElement &e, const QString &attribute_name, QUuid *uuid) |
| PropertyFlags | propertyUuid (const QString &value, QUuid *uuid) |
| PropertyFlags | propertyString (const QDomElement &e, const QString &attribute_name, QString *string) |
| QDomElement | property (const QDomElement &e, const QString &name) |
| bool | attribute (const QDomElement &e, const QString &attribute_name, const QString &type, QString *attr) |
PropertiesInterface::attribute Returns the property with the name attribute_name and type type. | |
| bool | validXmlProperty (const QDomElement &e) |
| PropertiesInterface::validXmlProperty Check if the Xml element contains the needed fields. | |
| QDomElement | qGraphicsItemPosToXml (QGraphicsItem *item, QDomDocument &document) |
| qGraphicsItemPosToXml Save the pos of a QGraphicsItem into an xml element. The tag name of the xml element is pos and there is 3 attributes: x, y, z. | |
| bool | qGraphicsItemPosFromXml (QGraphicsItem *item, const QDomElement &xml_elmt) |
| QDomElement | penToXml (QDomDocument &parent_document, const QPen &pen) |
| QETXML::penToXml Write attribute of a QPen in xml element. | |
| QPen | penFromXml (const QDomElement &element) |
| QETXML::penFromXml Build a QPen from a xml description. | |
| QDomElement | brushToXml (QDomDocument &parent_document, const QBrush &brush) |
| QETXML::brushToXml Write attribute of a QBrush in xml element. | |
| QBrush | brushFromXml (const QDomElement &element) |
| QETXML::brushFromXml Build a QBrush from a xml description. | |
| QDomElement | fileSystemDirToXmlCollectionDir (QDomDocument &document, const QDir &dir, const QString &rename=QString()) |
| QDomElement | fileSystemElementToXmlCollectionElement (QDomDocument &document, QFile &file, const QString &rename=QString()) |
| bool | writeXmlFile (const QDomDocument &xml_document, const QString &file_path, QString *error_message=nullptr) |
| QETXML::writeXmlFile Export an XML document to an UTF-8 text file indented with 4 spaces, with LF end of lines and no BOM. | |
| QDomElement | textToDomElement (QDomDocument &document, const QString &tag_name, const QString &value) |
| QETXML::textToDomElement Return a QDomElement, created from document, with tag name tag_name and text value. | |
| QVector< QDomElement > | directChild (const QDomElement &element, const QString &tag_name) |
| QETXML::directChild. | |
| QVector< QDomElement > | subChild (const QDomElement &element, const QString parent_tag_name, const QString &children_tag_name) |
| QETXML::subChild. | |
| QDomElement | marginsToXml (QDomDocument &parent_document, const QMargins &margins) |
| QETXML::marginsToXml Save a QMargins to xml. the xml tag name is 'margins'. | |
| QMargins | marginsFromXml (const QDomElement &element) |
| QETXML::marginsFromXml. | |
| QDomElement | modelHeaderDataToXml (QDomDocument &parent_document, const QAbstractItemModel *model, QHash< int, QList< int > > horizontal_section_role, QHash< int, QList< int > > vertical_section_role) |
| QETXML::modelHeaderDataToXml Save to xml element all header data specified by horizontal_section_role and vertical_section_role. | |
| void | modelHeaderDataFromXml (const QDomElement &element, QAbstractItemModel *model) |
| QETXML::modelHeaderDataFromXml Restore from xml modele header data. | |
| QVector< QDomElement > | findInDomElement (const QDomElement &dom_elmt, const QString &tag_name) |
| QETXML::findInDomElement. | |
Variables | |
| const QString | integerS = "int" |
| const QString | doubleS = "double" |
| const QString | boolS = "bool" |
| const QString | stringS = "string" |
| const QString | uuidS = "uuid" |
| const QString | colorS = "color" |
This namespace contain some function to use xml with QET.
| bool QETXML::attribute | ( | const QDomElement & | e, |
| const QString & | attribute_name, | ||
| const QString & | type, | ||
| QString * | attr | ||
| e | Xml element which contains the property |
| attribute_name | |
| type | Type of the property |
| attr |
| bool QETXML::boolFromString | ( | const QString & | value, |
| bool | default_value, | ||
| bool * | conv_ok | ||
| value | : value to convert |
| default_value | : default value |
| conv_ok | : true if value is successfully converted |
| QString QETXML::boolToString | ( | bool | value | ) |
boolToString
| value |
value converted to string
| QBrush QETXML::brushFromXml | ( | const QDomElement & | element | ) |
| element | : the QDomElement that describe the pen |
| QDomElement QETXML::brushToXml | ( | QDomDocument & | parent_document, |
| const QBrush & | brush | ||
| parent_document | : parent document for create the QDomElement |
| brush | : the brush to store |
| QDomElement QETXML::createXmlProperty | ( | const QString & | name, |
| const bool | value | ||
| const char * | value | ||
| const double | value | ||
| const int | value | ||
| e | DomElement which contains the property attribute |
| attribute_name | Name of the attribute |
| entier | Return value if success |
entier is not valid and the return value is False | QDomElement QETXML::createXmlProperty | ( | const QString & | name, |
| const QColor | value | ||
| const QString | value | ||
| const QUuid | value | ||
| PropertyFlags QETXML::debugReadXml | ( | PropertyFlags | flag, |
| const QDomElement & | e, | ||
| const QString & | attr, | ||
| const QString & | type | ||
| QVector< QDomElement > QETXML::directChild | ( | const QDomElement & | element, |
| const QString & | tag_name | ||
| element | |
| tag_name |
| QDomElement QETXML::fileSystemDirToXmlCollectionDir | ( | QDomDocument & | document, |
| const QDir & | dir, | ||
| const QString & | rename = QString() |
| QDomElement QETXML::fileSystemElementToXmlCollectionElement | ( | QDomDocument & | document, |
| QFile & | file, | ||
| QVector< QDomElement > QETXML::findInDomElement | ( | const QDomElement & | dom_elmt, |
| dom_elmt | |
| tag_name |
| QMargins QETXML::marginsFromXml | ( | const QDomElement & | element | ) |
| element |
| QDomElement QETXML::marginsToXml | ( | QDomDocument & | parent_document, |
| const QMargins & | margins | ||
| parent_document | |
| margins |
| void QETXML::modelHeaderDataFromXml | ( | const QDomElement & | element, |
| QAbstractItemModel * | model | ||
| element | |
| model |
| QDomElement QETXML::modelHeaderDataToXml | ( | QDomDocument & | parent_document, |
| const QAbstractItemModel * | model, | ||
| QHash< int, QList< int > > | horizontal_section_role, | ||
| QHash< int, QList< int > > | vertical_section_role | ||
| parent_document | |
| model | |
| horizontal_section_role | : key as header section and value as list of roles to save in xml |
| vertical_section_role | :key as header section and value as list of roles to save in xml |
| QPen QETXML::penFromXml | ( | const QDomElement & | element | ) |
| element | : The QDomElement that describe the pen |
| QDomElement QETXML::penToXml | ( | QDomDocument & | parent_document, |
| const QPen & | pen | ||
| pen | : the pen to store |
| QDomElement QETXML::property | ( | const QDomElement & | e, |
| const QString & | name | ||
| PropertyFlags QETXML::propertyBool | ( | const QDomElement & | e, |
| bool * | boolean | ||
| PropertyFlags QETXML::propertyBool | ( | const QString & | value, |
| PropertyFlags QETXML::propertyColor | ( | const QDomElement & | e, |
| QColor * | color | ||
| PropertyFlags QETXML::propertyColor | ( | const QString & | value, |
| PropertyFlags QETXML::propertyDouble | ( | const QDomElement & | e, |
| double * | reel | ||
| PropertyFlags QETXML::propertyDouble | ( | const QString & | value, |
| PropertyFlags QETXML::propertyInteger | ( | const QDomElement & | e, |
| int * | entier | ||
| PropertyFlags QETXML::propertyInteger | ( | const QString & | value, |
| int * | entier | ||
| PropertyFlags QETXML::propertyString | ( | const QDomElement & | e, |
| QString * | string | ||
| PropertyFlags QETXML::propertyUuid | ( | const QDomElement & | e, |
| QUuid * | uuid | ||
| PropertyFlags QETXML::propertyUuid | ( | const QString & | value, |
| QUuid * | uuid | ||
| bool QETXML::qGraphicsItemPosFromXml | ( | QGraphicsItem * | item, |
| const QDomElement & | xml_elmt | ||
| QDomElement QETXML::qGraphicsItemPosToXml | ( | QGraphicsItem * | item, |
| QDomDocument & | document | ||
| item | |
| document |
| QVector< QDomElement > QETXML::subChild | ( | const QDomElement & | element, |
| const QString | parent_tag_name, | ||
| const QString & | children_tag_name | ||
| element | |
| parent_tag_name | |
| children_tag_name |
| QDomElement QETXML::textToDomElement | ( | QDomDocument & | document, |
| const QString & | tag_name, | ||
| const QString & | value | ||
| document | |
| tag_name | |
| value |
| bool QETXML::validXmlProperty | ( | const QDomElement & | e | ) |
| e | Xml Property |
| bool QETXML::writeXmlFile | ( | const QDomDocument & | xml_document, |
| const QString & | file_path, | ||
| QString * | error_message = nullptr |
| xml_document | : An XML document to be exported |
| file_path | : Path to the file to be written |
| error_message | : If non-zero, will contain an error message explaining what happened when this function returns false. |
| const QString QETXML::boolS = "bool" |
| const QString QETXML::colorS = "color" |
| const QString QETXML::doubleS = "double" |
| const QString QETXML::integerS = "int" |
| const QString QETXML::stringS = "string" |
| const QString QETXML::uuidS = "uuid" |
