ImagePropertiesWidget Class Reference
The ImagePropertiesWidget class This class provides a widget to edit the properties of a DiagramImageItem. More...
#include <imagepropertieswidget.h>
Inheritance diagram for ImagePropertiesWidget:
Collaboration diagram for ImagePropertiesWidget:
 ImagePropertiesWidget (DiagramImageItem *image=nullptr, QWidget *parent=nullptr)
 ImagePropertiesWidget::ImagePropertiesWidget Constructor.
 ~ImagePropertiesWidget () override
 ImagePropertiesWidget::~ImagePropertiesWidget Destructor.
void setImageItem (DiagramImageItem *image)
 ImagePropertiesWidget::setImageItem Set the image to edit properties.
void apply () override
 ImagePropertiesWidget::apply Apply the change.
void reset () override
 ImagePropertiesWidget::reset Reset the change.
bool setLiveEdit (bool live_edit) override
 ImagePropertiesWidget::setLiveEdit.
QUndoCommand * associatedUndo () const override
 ImagePropertiesWidget::associatedUndo.
Public Member Functions inherited from PropertiesEditorWidget
 PropertiesEditorWidget (QWidget *parent=nullptr)
 PropertiesEditorWidget::PropertiesEditorWidget Constructor.
virtual QString title () const
bool isLiveEdit () const
 PropertiesEditorWidget::isLiveEdit.
Private Slots
void on_m_width_sb_valueChanged (double value)
 ImagePropertiesWidget::on_m_width_sb_valueChanged Applies the new width live, and – if "Conserver les proportions" is checked – scales height by the same ratio this change just applied to width, so the two stay locked together. Guarded by m_updating_ratio: the setValue() call below would otherwise re-trigger on_m_height_sb_valueChanged(), which would then try to scale width again in response, recursing indefinitely.
void on_m_height_sb_valueChanged (double value)
 ImagePropertiesWidget::on_m_height_sb_valueChanged Mirror of on_m_width_sb_valueChanged() – see its comment.
void on_m_angle_sb_valueChanged (double value)
 ImagePropertiesWidget::on_m_angle_sb_valueChanged.
void on_m_skew_x_sb_valueChanged (double value)
 ImagePropertiesWidget::on_m_skew_x_sb_valueChanged.
void on_m_skew_y_sb_valueChanged (double value)
 ImagePropertiesWidget::on_m_skew_y_sb_valueChanged.
void on_m_lock_ratio_tb_toggled (bool checked)
 ImagePropertiesWidget::on_m_lock_ratio_tb_toggled Keeps the button's own icon and tooltip in sync with its checked state – Qt shows the checked/unchecked state visually (a sunken look) regardless, but the lock/unlock glyph makes the meaning obvious at a glance rather than needing that convention noticed.
void on_m_restore_ratio_pb_clicked ()
 ImagePropertiesWidget::on_m_restore_ratio_pb_clicked The same action as the item's own "Restaurer les proportions" context-menu entry, offered here too since this dialog is exactly where someone would notice the proportions are off in the first place. Deliberately bypasses on_m_height_sb_valueChanged()'s own lock-following logic (guarded by m_updating_ratio, then applied directly rather than through the spinbox's own signal) rather than going through it normally: if the lock happened to be engaged, that logic would treat this as an ordinary edit and scale width by the same ratio the height change just applied – compounding into some other, unrelated value instead of the plain "make height match width" this button promises regardless of lock state.
void on_m_lock_pos_cb_clicked ()
 ImagePropertiesWidget::on_m_lock_pos_cb_clicked Set movable or not the image according to corresponding check box.
void updateUi () override
 ImagePropertiesWidget::updateUi Udpdate the ui, notably when the image to edit change.
Ui::ImagePropertiesWidget * ui
DiagramImageItem * m_image
bool m_movable
qreal m_scaleX
qreal m_scaleY
qreal m_rotation
qreal m_skewX
qreal m_skewY
bool m_updating_ratio = false
Additional Inherited Members
Protected Member Functions inherited from PropertiesEditorWidget
virtual void enableLiveEdit ()
virtual void disableLiveEdit ()
Protected Attributes inherited from PropertiesEditorWidget
bool m_live_edit
◆ ImagePropertiesWidget()
ImagePropertiesWidget::ImagePropertiesWidget ( DiagramImageItem * image = nullptr,
QWidget * parent = nullptr )
explicit
image: image to edit properties
parent: parent widget
◆ ~ImagePropertiesWidget()
ImagePropertiesWidget::~ImagePropertiesWidget ( )
◆ apply()
void ImagePropertiesWidget::apply ( )
overridevirtual
◆ associatedUndo()
QUndoCommand * ImagePropertiesWidget::associatedUndo ( ) const
overridevirtual
the change in an undo command. If there is no change return nullptr. Chains scaleFactorX, scaleFactorY, rotationAngle, skewX and skewY as separate QPropertyUndoCommands, matching the established "check each field, chain if changed" pattern used elsewhere – each of these is genuinely independent (the resize/rotate/skew handles can set any of them without touching the others), so a single combined command wouldn't correctly capture "only two of five fields actually changed".
◆ on_m_angle_sb_valueChanged
void ImagePropertiesWidget::on_m_angle_sb_valueChanged ( double value)
privateslot
valuethe new rotation, in degrees
◆ on_m_height_sb_valueChanged
void ImagePropertiesWidget::on_m_height_sb_valueChanged ( double value)
privateslot
valuethe new height, as a percentage
◆ on_m_lock_pos_cb_clicked
void ImagePropertiesWidget::on_m_lock_pos_cb_clicked ( )
privateslot
◆ on_m_lock_ratio_tb_toggled
void ImagePropertiesWidget::on_m_lock_ratio_tb_toggled ( bool checked)
privateslot
checked
◆ on_m_restore_ratio_pb_clicked
void ImagePropertiesWidget::on_m_restore_ratio_pb_clicked ( )
privateslot
◆ on_m_skew_x_sb_valueChanged
void ImagePropertiesWidget::on_m_skew_x_sb_valueChanged ( double value)
privateslot
valuethe new X skew, in degrees
◆ on_m_skew_y_sb_valueChanged
void ImagePropertiesWidget::on_m_skew_y_sb_valueChanged ( double value)
privateslot
valuethe new Y skew, in degrees
◆ on_m_width_sb_valueChanged
void ImagePropertiesWidget::on_m_width_sb_valueChanged ( double value)
privateslot
valuethe new width, as a percentage
◆ reset()
void ImagePropertiesWidget::reset ( )
overridevirtual
◆ setImageItem()
void ImagePropertiesWidget::setImageItem ( DiagramImageItem * image)
◆ setLiveEdit()
bool ImagePropertiesWidget::setLiveEdit ( bool live_edit)
overridevirtual
live_edittrue -> enable live edit false -> disable live edit
always true
◆ updateUi()
void ImagePropertiesWidget::updateUi ( )
overrideprivatevirtual
◆ m_image
DiagramImageItem* ImagePropertiesWidget::m_image
◆ m_movable
bool ImagePropertiesWidget::m_movable
◆ m_rotation
qreal ImagePropertiesWidget::m_rotation
◆ m_scaleX
qreal ImagePropertiesWidget::m_scaleX
◆ m_scaleY
qreal ImagePropertiesWidget::m_scaleY
◆ m_skewX
qreal ImagePropertiesWidget::m_skewX
◆ m_skewY
qreal ImagePropertiesWidget::m_skewY
◆ m_updating_ratio
bool ImagePropertiesWidget::m_updating_ratio = false
◆ ui
Ui::ImagePropertiesWidget* ImagePropertiesWidget::ui
