QElectroTech 0.100.0-dev
Signals | Public Member Functions | Static Public Member Functions | Protected Member Functions | Properties | Private Member Functions | Private Attributes | List of all members
ElementTextItemGroup Class Reference
The ElementTextItemGroup class This class represent a group of element text Texts in the group can be aligned left / center /right. More...
#include <elementtextitemgroup.h>
Inherits QObject, and QGraphicsItemGroup.
Collaboration diagram for ElementTextItemGroup:
Signals
void rotationChanged (qreal)
void verticalAdjustmentChanged (int)
void alignmentChanged (Qt::Alignment)
void nameChanged (QString)
void holdToBottomPageChanged (bool)
void xChanged ()
void yChanged ()
void frameChanged (bool frame)
 ElementTextItemGroup (const QString &name, Element *parent)
 ElementTextItemGroup::ElementTextItemGroup.
 ~ElementTextItemGroup () override
void addToGroup (QGraphicsItem *item)
 ElementTextItemGroup::addToGroup.
void removeFromGroup (QGraphicsItem *item)
 ElementTextItemGroup::removeFromGroup.
void blockAlignmentUpdate (bool block)
 ElementTextItemGroup::blockAlignmentUpdate If true, the texts in this group are never aligned, moved, rotated etc... the texts stay as it was, until blockAlignmentUpdate is set to false.
void setAlignment (Qt::Alignment alignement)
 ElementTextItemGroup::setAlignement Set the alignement of this group.
Qt::Alignment alignment () const
void updateAlignment ()
 ElementTextItemGroup::setAlignment Update the alignement of the items in this group, according to the current alignement.
int verticalAdjustment () const
void setVerticalAdjustment (int v)
 ElementTextItemGroup::setVerticalAdjustment Set the value of the vertical adjustment to v. The vertical adjutment is use to adjust the space between the texts of this group.
void setName (QString name)
 ElementTextItemGroup::setName.
QString name () const
void setHoldToBottomPage (bool hold)
bool holdToBottomPage () const
void setFrame (const bool frame)
bool frame () const
QList< DynamicElementTextItem * > texts () const
 ElementTextItemGroup::texts.
Diagramdiagram () const
 ElementTextItemGroup::diagram.
ElementparentElement () const
 ElementTextItemGroup::parentElement.
QDomElement toXml (QDomDocument &dom_document) const
 ElementTextItemGroup::toXml Export data of this group to xml.
void fromXml (QDomElement &dom_element)
 ElementTextItemGroup::fromXml Import data of this group from xml.
void paint (QPainter *painter, const QStyleOptionGraphicsItem *option, QWidget *widget) override
 ElementTextItemGroup::paint.
 ElementTextItemGroup::boundingRect.
void setRotation (qreal angle)
void setPos (const QPointF &pos)
void setPos (qreal x, qreal y)
static QString xmlTaggName ()
 ElementTextItemGroup::mousePressEvent.
 ElementTextItemGroup::mouseMoveEvent.
 ElementTextItemGroup::mouseReleaseEvent.
void keyPressEvent (QKeyEvent *event) override
 ElementTextItemGroup::keyPressEvent.
Properties
QPointF pos
qreal rotation
QString name
bool frame
void updateXref ()
void adjustSlaveXrefPos ()
void autoPos ()
Qt::Alignment m_alignment = Qt::AlignJustify
QString m_name
bool m_first_move = true
bool m_hold_to_bottom_of_page = false
bool m_block_alignment_update = false
bool m_frame = false
QPointF m_initial_position
int m_vertical_adjustment = 0
CrossRefItemm_Xref_item = nullptr
Elementm_parent_element = nullptr
QList< QMetaObject::Connection > m_update_slave_Xref_connection
QGraphicsTextItem * m_slave_Xref_item = nullptr
QMetaObject::Connection m_XrefChanged_timer
QMetaObject::Connection m_linked_changed_timer
◆ ElementTextItemGroup()
ElementTextItemGroup::ElementTextItemGroup ( const QString &  name,
Element parent
name:
parent:
◆ ~ElementTextItemGroup()
ElementTextItemGroup::~ElementTextItemGroup ( )
◆ addToGroup()
void ElementTextItemGroup::addToGroup ( QGraphicsItem *  item)
item
◆ adjustSlaveXrefPos()
void ElementTextItemGroup::adjustSlaveXrefPos ( )
◆ alignment()
Qt::Alignment ElementTextItemGroup::alignment ( ) const
◆ alignmentChanged
void ElementTextItemGroup::alignmentChanged ( Qt::Alignment  )
signal
◆ autoPos()
void ElementTextItemGroup::autoPos ( )
◆ blockAlignmentUpdate()
void ElementTextItemGroup::blockAlignmentUpdate ( bool  block)
block
◆ boundingRect()
QRectF ElementTextItemGroup::boundingRect ( ) const
◆ diagram()
Diagram * ElementTextItemGroup::diagram ( ) const
The diagram of this group, or nullptr if this group is not in a diagram
◆ frame()
bool ElementTextItemGroup::frame ( ) const
◆ frameChanged
void ElementTextItemGroup::frameChanged ( bool  frame)
signal
◆ fromXml()
void ElementTextItemGroup::fromXml ( QDomElement &  dom_element)
dom_element
◆ holdToBottomPage()
bool ElementTextItemGroup::holdToBottomPage ( ) const
inline
◆ holdToBottomPageChanged
void ElementTextItemGroup::holdToBottomPageChanged ( bool  )
signal
◆ hoverEnterEvent()
void ElementTextItemGroup::hoverEnterEvent ( QGraphicsSceneHoverEvent *  event)
overrideprotected
◆ hoverLeaveEvent()
void ElementTextItemGroup::hoverLeaveEvent ( QGraphicsSceneHoverEvent *  event)
overrideprotected
◆ keyPressEvent()
void ElementTextItemGroup::keyPressEvent ( QKeyEvent *  event)
overrideprotected
event
◆ mouseDoubleClickEvent()
void ElementTextItemGroup::mouseDoubleClickEvent ( QGraphicsSceneMouseEvent *  event)
overrideprotected
◆ mouseMoveEvent()
void ElementTextItemGroup::mouseMoveEvent ( QGraphicsSceneMouseEvent *  event)
overrideprotected
event
◆ mousePressEvent()
void ElementTextItemGroup::mousePressEvent ( QGraphicsSceneMouseEvent *  event)
overrideprotected
◆ mouseReleaseEvent()
void ElementTextItemGroup::mouseReleaseEvent ( QGraphicsSceneMouseEvent *  event)
overrideprotected
event
◆ name()
QString ElementTextItemGroup::name ( ) const
inline
◆ nameChanged
void ElementTextItemGroup::nameChanged ( QString  )
signal
◆ paint()
void ElementTextItemGroup::paint ( QPainter *  painter,
const QStyleOptionGraphicsItem *  option,
QWidget *  widget
painter
option
widget
◆ parentElement()
Element * ElementTextItemGroup::parentElement ( ) const
The parent element of this group or nullptr
◆ removeFromGroup()
void ElementTextItemGroup::removeFromGroup ( QGraphicsItem *  item)
item
◆ rotationChanged
void ElementTextItemGroup::rotationChanged ( qreal  )
signal
◆ setAlignment()
void ElementTextItemGroup::setAlignment ( Qt::Alignment  alignement)
alignement
◆ setFrame()
void ElementTextItemGroup::setFrame ( const bool  frame)
◆ setHoldToBottomPage()
void ElementTextItemGroup::setHoldToBottomPage ( bool  hold)
◆ setName()
void ElementTextItemGroup::setName ( QString  name)
nameSet the name of this group
◆ setPos() [1/2]
void ElementTextItemGroup::setPos ( const QPointF &  pos)
◆ setPos() [2/2]
void ElementTextItemGroup::setPos ( qreal  x,
qreal  y
◆ setRotation()
void ElementTextItemGroup::setRotation ( qreal  angle)
◆ setVerticalAdjustment()
void ElementTextItemGroup::setVerticalAdjustment ( int  v)
v
◆ texts()
QList< DynamicElementTextItem * > ElementTextItemGroup::texts ( ) const
Every texts in this group
◆ toXml()
QDomElement ElementTextItemGroup::toXml ( QDomDocument &  dom_document) const
dom_document
◆ updateAlignment()
void ElementTextItemGroup::updateAlignment ( )
alignement
◆ updateXref()
void ElementTextItemGroup::updateXref ( )
◆ verticalAdjustment()
int ElementTextItemGroup::verticalAdjustment ( ) const
inline
◆ verticalAdjustmentChanged
void ElementTextItemGroup::verticalAdjustmentChanged ( int  )
signal
◆ xChanged
void ElementTextItemGroup::xChanged ( )
signal
◆ xmlTaggName()
static QString ElementTextItemGroup::xmlTaggName ( )
inlinestatic
◆ yChanged
void ElementTextItemGroup::yChanged ( )
signal
◆ m_alignment
Qt::Alignment ElementTextItemGroup::m_alignment = Qt::AlignJustify
◆ m_block_alignment_update
bool ElementTextItemGroup::m_block_alignment_update = false
◆ m_first_move
bool ElementTextItemGroup::m_first_move = true
◆ m_frame
bool ElementTextItemGroup::m_frame = false
◆ m_hold_to_bottom_of_page
bool ElementTextItemGroup::m_hold_to_bottom_of_page = false
◆ m_initial_position
QPointF ElementTextItemGroup::m_initial_position
◆ m_linked_changed_timer
QMetaObject::Connection ElementTextItemGroup::m_linked_changed_timer
◆ m_name
QString ElementTextItemGroup::m_name
◆ m_parent_element
Element* ElementTextItemGroup::m_parent_element = nullptr
◆ m_slave_Xref_item
QGraphicsTextItem* ElementTextItemGroup::m_slave_Xref_item = nullptr
◆ m_update_slave_Xref_connection
QList<QMetaObject::Connection> ElementTextItemGroup::m_update_slave_Xref_connection
◆ m_vertical_adjustment
int ElementTextItemGroup::m_vertical_adjustment = 0
◆ m_Xref_item
CrossRefItem* ElementTextItemGroup::m_Xref_item = nullptr
◆ m_XrefChanged_timer
QMetaObject::Connection ElementTextItemGroup::m_XrefChanged_timer
Property Documentation
◆ alignment
readwrite
◆ frame
readwrite
◆ holdToBottomPage
readwrite
◆ name
readwrite
◆ pos
QPointF ElementTextItemGroup::pos
readwrite
◆ rotation
qreal ElementTextItemGroup::rotation
readwrite
readwrite
