DiagramEventAddElement Class Reference
The DiagramEventAddElement class This diagram event add a new element, for each left click button at the position of click. Space key rotate current element by 90°, right click button finish this event. More...
#include <diagrameventaddelement.h>
Inheritance diagram for DiagramEventAddElement:
Collaboration diagram for DiagramEventAddElement:
 DiagramEventAddElement (ElementsLocation &location, Diagram *diagram, QPointF pos=QPointF(0, 0))
 DiagramEventAddElement::DiagramEventAddElement Defaut constructor.
 ~DiagramEventAddElement () override
 DiagramEventAddElement::~DiagramEventAddElement Destructor Enable context menu for each view of diagram.
 DiagramEventAddElement::mouseMoveEvent Move the element to new pos of mouse the event is always accepted.
 DiagramEventAddElement::mousePressEvent Do nothing, but return true for not transit the event to other thing in diagram. the event is always accepted.
 DiagramEventAddElement::mouseReleaseEvent Right button finish this event (isRunning = false) and emit finish. Left button add an element to diagram the event is always accepted.
 DiagramEventAddElement::mouseDoubleClickEvent If mouse left double clic, finish this event (isRunning = false) and emit finish the event is always accepted.
void keyPressEvent (QKeyEvent *event) override
 DiagramEventAddElement::keyPressEvent Press space key rotate the element to 90° (return true) else call DiagramEventInterface::keyPressEvent(event), and return the value.
void init () override
 DiagramEventAddElement::init Init this event.
Public Member Functions inherited from DiagramEventInterface
 DiagramEventInterface (Diagram *diagram)
 ~DiagramEventInterface () override=0
virtual void wheelEvent (QGraphicsSceneWheelEvent *event)
virtual void keyReleaseEvent (QKeyEvent *event)
bool buildElement ()
 DiagramEventAddElement::buildElement Build the element, if the element is build successfully, we return true, otherwise false.
void addElement ()
 DiagramEventAddElement::addElement Add an element at the current pos and current rotation, if project autoconductor option is enable, and the element can be wired, we do it.
ElementsLocation m_location
Element * m_element
QString m_integrate_path
QPointer< QStatusBar > m_status_bar
Additional Inherited Members
Signals inherited from DiagramEventInterface
void finish ()
Protected Attributes inherited from DiagramEventInterface
QPointer< Diagram > m_diagram
bool m_running {false}
bool m_abort {false}
◆ DiagramEventAddElement()
DiagramEventAddElement::DiagramEventAddElement ( ElementsLocation & location,
Diagram * diagram,
QPointF pos = QPointF(0,0) )
diagram: diagram owner of this event
pos: first pos of item ( optional, by defaut QPointF(0,0) )
◆ ~DiagramEventAddElement()
DiagramEventAddElement::~DiagramEventAddElement ( )
◆ addElement()
void DiagramEventAddElement::addElement ( )
◆ buildElement()
bool DiagramEventAddElement::buildElement ( )
◆ init()
void DiagramEventAddElement::init ( )
overridevirtual
Reimplemented from DiagramEventInterface.
◆ keyPressEvent()
void DiagramEventAddElement::keyPressEvent ( QKeyEvent * event)
overridevirtual
event
◆ mouseDoubleClickEvent()
void DiagramEventAddElement::mouseDoubleClickEvent ( QGraphicsSceneMouseEvent * event)
overridevirtual
event
◆ mouseMoveEvent()
void DiagramEventAddElement::mouseMoveEvent ( QGraphicsSceneMouseEvent * event)
overridevirtual
event
◆ mousePressEvent()
void DiagramEventAddElement::mousePressEvent ( QGraphicsSceneMouseEvent * event)
overridevirtual
event
◆ mouseReleaseEvent()
void DiagramEventAddElement::mouseReleaseEvent ( QGraphicsSceneMouseEvent * event)
overridevirtual
event
◆ m_element
Element* DiagramEventAddElement::m_element
◆ m_integrate_path
QString DiagramEventAddElement::m_integrate_path
◆ m_location
ElementsLocation DiagramEventAddElement::m_location
◆ m_status_bar
QPointer<QStatusBar> DiagramEventAddElement::m_status_bar
