QElectroTech 0.100.0-dev
The TerminalEditor class Provide a widget used to edit the properties of a PartTerminal. More...
#include <terminaleditor.h>
Public Member Functions | |
| TerminalEditor (QETElementEditor *editor, QWidget *parent=nullptr) | |
| TerminalEditor::TerminalEditor Default constructor. | |
| ~TerminalEditor () override | |
| TerminalEditor::~TerminalEditor Destructor. | |
| void | updateForm () override |
| TerminalEditor::updateForm Reimplemented from ElementItemEditor Update the content of this widget. | |
| bool | setPart (CustomElementPart *new_part) override |
| TerminalEditor::setPart Set the part to edit. The part must be a PartTerminal, in other case return false. | |
| CustomElementPart * | currentPart () const override |
| TerminalEditor::currentPart. | |
| QList< CustomElementPart * > | currentParts () const override |
Public Member Functions inherited from ElementItemEditor | |
| ElementItemEditor (QETElementEditor *, QWidget *=nullptr) | |
| ~ElementItemEditor () override | |
| virtual QETElementEditor * | elementEditor () const |
| virtual ElementScene * | elementScene () const |
| virtual QUndoStack & | undoStack () const |
| virtual QString | elementTypeName () const |
| virtual void | setElementTypeName (const QString &) |
| virtual void | detach () |
| virtual bool | setParts (QList< CustomElementPart * >) |
Private Member Functions | |
| void | init () |
| TerminalEditor::init Some init about this class. | |
| void | posEdited () |
| TerminalEditor::posEdited. | |
| void | orientationEdited () |
| TerminalEditor::orientationEdited. | |
| void | nameEdited () |
| TerminalEditor::nameEdited. | |
| void | typeEdited () |
| TerminalEditor::typeEdited. | |
| void | activeConnections (bool active) |
| TerminalEditor::activeConnections Active connection between the widgets used in this editor and method of this class. | |
| void | activeChangeConnections (bool active) |
Private Attributes | |
| Ui::TerminalEditor * | ui |
| QVector< QMetaObject::Connection > | m_editor_connections |
| QVector< QMetaObject::Connection > | m_change_connections |
| PartTerminal * | m_part = nullptr |
| bool | m_locked = false |
| TerminalEditor::TerminalEditor | ( | QETElementEditor * | editor, |
| QWidget * | parent = nullptr |
| editor | : element editor of which this terminal editor belong |
| parent | : parent widget |
override |
private |
private |
| active |
overridevirtual |
Implements ElementItemEditor.
inlineoverridevirtual |
private |
private |
private |
private |
overridevirtual |
| new_part | : the part to edit |
private |
overridevirtual |
private |
private |
private |
private |
private |
