The PartDynamicTextField class This class represents an editable dynamic text field which may be used to compose the drawing of an electrical element within the element editor. The field will remain editable once the element is added onto a diagram.
More...
#include <partdynamictextfield.h>
| enum | { Type = UserType + 1110
◆ anonymous enum
◆ PartDynamicTextField()
| PartDynamicTextField::PartDynamicTextField |
QETElementEditor * |
editor, |
QGraphicsItem * |
parent = nullptr |
◆ alignment()
| Qt::Alignment PartDynamicTextField::alignment |
const |
◆ alignmentChanged
| void PartDynamicTextField::alignmentChanged |
Qt::Alignment |
alignment | ) |
signal |
◆ color()
| QColor PartDynamicTextField::color |
const |
◆ colorChanged
| void PartDynamicTextField::colorChanged |
QColor |
color | ) |
signal |
◆ compositeText()
| QString PartDynamicTextField::compositeText |
const |
◆ compositeTextChanged
| void PartDynamicTextField::compositeTextChanged |
QString |
text | ) |
signal |
◆ elementInfoChanged()
| void PartDynamicTextField::elementInfoChanged |
private |
◆ finishAlignment()
| void PartDynamicTextField::finishAlignment |
private |
◆ fontChanged
| void PartDynamicTextField::fontChanged |
QFont |
font | ) |
signal |
◆ frame()
| bool PartDynamicTextField::frame |
const |
◆ frameChanged
| void PartDynamicTextField::frameChanged |
bool |
frame | ) |
signal |
◆ fromTextFieldXml()
| void PartDynamicTextField::fromTextFieldXml |
const QDomElement & |
dom_element | ) |
◆ fromXml()
| void PartDynamicTextField::fromXml |
dom_elmt | ) |
overridevirtual |
◆ handleUserTransformation()
| void PartDynamicTextField::handleUserTransformation |
const QRectF & |
initial_selection_rect, |
const QRectF & |
new_selection_rect |
overridevirtual |
◆ infoName()
| QString PartDynamicTextField::infoName |
const |
◆ infoNameChanged
| void PartDynamicTextField::infoNameChanged |
QString |
info | ) |
signal |
◆ isUseless()
| bool PartDynamicTextField::isUseless |
const |
inlineoverridevirtual |
- Returns
- whether the primitive appears to be useless (e.g. 0-length line) Typically, useless primitives are discarded when saving the element.
Implements CustomElementPart.
◆ itemChange()
| QVariant PartDynamicTextField::itemChange |
GraphicsItemChange |
change, |
const QVariant & |
value |
overrideprotected |
◆ keepVisualRotation()
| bool PartDynamicTextField::keepVisualRotation |
const |
◆ keepVisualRotationChanged
| void PartDynamicTextField::keepVisualRotationChanged |
bool |
keep | ) |
signal |
◆ mouseMoveEvent()
| void PartDynamicTextField::mouseMoveEvent |
QGraphicsSceneMouseEvent * |
event | ) |
overrideprotected |
◆ mousePressEvent()
| void PartDynamicTextField::mousePressEvent |
event | ) |
overrideprotected |
◆ mouseReleaseEvent()
| void PartDynamicTextField::mouseReleaseEvent |
event | ) |
overrideprotected |
◆ name()
| QString PartDynamicTextField::name |
const |
overridevirtual |
◆ paint()
| void PartDynamicTextField::paint |
QPainter * |
painter, |
const QStyleOptionGraphicsItem * |
option, |
QWidget * |
widget |
overrideprotected |
◆ prepareAlignment()
| void PartDynamicTextField::prepareAlignment |
private |
◆ property()
| QVariant PartDynamicTextField::property |
const char * |
name | ) |
const |
◆ sceneGeometricRect()
| QRectF PartDynamicTextField::sceneGeometricRect |
const |
◆ setAlignment()
| void PartDynamicTextField::setAlignment |
Qt::Alignment |
alignment | ) |
◆ setColor()
| void PartDynamicTextField::setColor |
const QColor & |
color | ) |
◆ setCompositeText()
| void PartDynamicTextField::setCompositeText |
const QString & |
text | ) |
◆ setFont()
| void PartDynamicTextField::setFont |
const QFont & |
font | ) |
◆ setFrame()
| void PartDynamicTextField::setFrame |
bool |
frame | ) |
◆ setInfoName()
| void PartDynamicTextField::setInfoName |
const QString & |
info_name | ) |
◆ setKeepVisualRotation()
| void PartDynamicTextField::setKeepVisualRotation |
const bool & |
keep | ) |
◆ setPlainText()
| void PartDynamicTextField::setPlainText |
const QString & |
text | ) |
◆ setProperty()
| void PartDynamicTextField::setProperty |
const char * |
name, |
const QVariant & |
value |
◆ setText()
| void PartDynamicTextField::setText |
const QString & |
text | ) |
◆ setTextFrom()
◆ setTextWidth()
| void PartDynamicTextField::setTextWidth |
qreal |
width | ) |
◆ startUserTransformation()
| void PartDynamicTextField::startUserTransformation |
const QRectF & |
initial_selection_rect | ) |
overridevirtual |
◆ taggChanged
| void PartDynamicTextField::taggChanged |
QString |
tagg | ) |
signal |
◆ text()
| QString PartDynamicTextField::text |
const |
◆ textChanged
| void PartDynamicTextField::textChanged |
QString |
text | ) |
signal |
◆ textFrom()
◆ textFromChanged
◆ textWidthChanged
| void PartDynamicTextField::textWidthChanged |
qreal |
width | ) |
signal |
◆ toXml()
| const QDomElement PartDynamicTextField::toXml |
QDomDocument & |
dom_doc | ) |
const |
overridevirtual |
◆ type()
| int PartDynamicTextField::type |
const |
inlineoverride |
◆ xmlName()
| QString PartDynamicTextField::xmlName |
const |
overridevirtual |
- Returns
- the name that will be used as XML tag when exporting the primitive
◆ xmlTaggName()
| static QString PartDynamicTextField::xmlTaggName |
inlinestatic |
◆ m_alignment
| Qt::Alignment PartDynamicTextField::m_alignment = Qt::AlignTop|Qt::AlignLeft |
private |
◆ m_alignment_rect
| QRectF PartDynamicTextField::m_alignment_rect |
private |
◆ m_block_alignment
| bool PartDynamicTextField::m_block_alignment = false |
private |
◆ m_composite_text
| QString PartDynamicTextField::m_composite_text |
private |
◆ m_first_add
| bool PartDynamicTextField::m_first_add = true |
private |
◆ m_frame
| bool PartDynamicTextField::m_frame = false |
private |
◆ m_info_name
| QString PartDynamicTextField::m_info_name |
private |
◆ m_keep_visual_rotation
| bool PartDynamicTextField::m_keep_visual_rotation = false |
private |
◆ m_origine_pos
| QPointF PartDynamicTextField::m_origine_pos |
private |
◆ m_saved_point
| QPointF PartDynamicTextField::m_saved_point |
private |
◆ m_text
| QString PartDynamicTextField::m_text |
private |
◆ m_text_from
◆ m_text_width
| qreal PartDynamicTextField::m_text_width = -1 |
private |
◆ m_uuid
| QUuid PartDynamicTextField::m_uuid |
private |
◆ alignment
readwrite |
◆ color
readwrite |
◆ compositeText
readwrite |
◆ font
| QFont PartDynamicTextField::font |
readwrite |
◆ frame
readwrite |
◆ infoName
readwrite |
readwrite |
◆ text
readwrite |
◆ textFrom
◆ textWidth
| qreal PartDynamicTextField::textWidth |
readwrite |
