The Terminal class This class represents a terminal of an electrical element, i.e. a possible plug point for conductors. This class handles all mouse events for connecting conductors.
More...
#include <terminal.h>
Inherits QGraphicsObject.
| enum | { Type = UserType + 1002
| QPointF | dock_elmt_ |
| | docking point for parent element
| static const qreal | terminalSize = 4.0 |
| static const qreal | Z = 1000 |
| static QColor | neutralColor = QColor(Qt::blue) |
| | default color
| static QColor | allowedColor = QColor(Qt::darkGreen) |
| | color for legal actions
| static QColor | warningColor = QColor("#ff8000") |
| | color for allowed but fuzzy or not recommended actions
| static QColor | forbiddenColor = QColor(Qt::red) |
| | color for forbidden actions
◆ anonymous enum
◆ Terminal() [1/2]
◆ ~Terminal()
◆ Terminal() [2/2]
◆ addConductor()
| bool Terminal::addConductor |
Conductor * |
conductor | ) |
Terminal::addConductor Add a conductor to this terminal.
- Parameters
| conductor | : the conductor to add. |
- Returns
- true if the conductor was successfully added
◆ alignedWithTerminal()
| Terminal * Terminal::alignedWithTerminal |
const |
Terminal::alignedWithTerminal If this terminal is aligned with an other terminal and is orientation is opposed return the other terminal else return nullptr.
- Returns
◆ boundingRect()
| QRectF Terminal::boundingRect |
const |
override |
◆ canBeLinkedTo()
| bool Terminal::canBeLinkedTo |
Terminal * |
other_terminal | ) |
Terminal::canBeLinkedTo Checking if the terminal can be linked to other_terminal or not Reasons for not linable:
other_terminal is this terminal
- this terminal is already connected to
other_terminal - Parameters
- Returns
- true if this terminal can be linked to other_terminal, otherwise false
◆ conductors()
| QList< Conductor * > Terminal::conductors |
const |
◆ conductorsCount()
| int Terminal::conductorsCount |
const |
inline |
◆ conductorWasAdded
| void Terminal::conductorWasAdded |
Conductor * |
conductor | ) |
signal |
◆ conductorWasRemoved
| void Terminal::conductorWasRemoved |
Conductor * |
conductor | ) |
signal |
◆ diagram()
| Diagram * Terminal::diagram |
const |
◆ dockConductor()
| QPointF Terminal::dockConductor |
const |
◆ drawHelpLine()
| void Terminal::drawHelpLine |
bool |
draw = true | ) |
◆ fromXml()
| bool Terminal::fromXml |
QDomElement & |
terminal | ) |
Terminal::fromXml Permet de savoir si un element XML represente cette borne. Attention, l'element XML n'est pas verifie.
- Parameters
| terminal | Le QDomElement a analyser |
- Returns
- true si la borne "se reconnait" (memes coordonnes, meme orientation), false sinon
◆ HelpLine()
| QLineF Terminal::HelpLine |
const |
Terminal::HelpLine.
- Returns
- a line with coordinate P1 the dock point of conductor and P2 the border of diagram, according to the orientation of terminal The line is in scene coordinate;
◆ hoverEnterEvent()
| void Terminal::hoverEnterEvent |
QGraphicsSceneHoverEvent * |
overrideprotected |
◆ hoverLeaveEvent()
| void Terminal::hoverLeaveEvent |
overrideprotected |
◆ hoverMoveEvent()
| void Terminal::hoverMoveEvent |
overrideprotected |
◆ init() [1/2]
Terminal::init Methode privee pour initialiser la borne.
- Parameters
| number | of terminal |
| name | of terminal |
| hiddenName | |
◆ init() [2/2]
◆ isLinkedTo()
| bool Terminal::isLinkedTo |
Terminal * |
Terminal::isLinkedTo.
- Parameters
| other_terminal | Autre borne |
- Returns
- true si cette borne est reliee a other_terminal, false sion
◆ mouseMoveEvent()
| void Terminal::mouseMoveEvent |
QGraphicsSceneMouseEvent * |
e | ) |
overrideprotected |
◆ mousePressEvent()
| void Terminal::mousePressEvent |
e | ) |
overrideprotected |
Terminal::mousePressEvent Gere le fait qu'on enfonce un bouton de la souris sur la Borne.
- Parameters
| e | L'evenement souris correspondant |
◆ mouseReleaseEvent()
| void Terminal::mouseReleaseEvent |
e | ) |
overrideprotected |
◆ name()
| QString Terminal::name |
const |
◆ orientation()
Permet de connaitre l'orientation de la borne. Si le parent de la borne est bien un Element, cette fonction renvoie l'orientation par rapport a la scene de la borne, en tenant compte du fait que l'element ait pu etre pivote. Sinon elle renvoie son sens normal.
- Returns
- L'orientation actuelle de la Terminal.
◆ paint()
| void Terminal::paint |
QPainter * |
painter, |
const QStyleOptionGraphicsItem * |
options, |
QWidget * |
override |
Terminal::paint Fonction de dessin des bornes.
- Parameters
| painter | Le QPainter a utiliser |
| options | Les options de dessin |
◆ parentElement()
| Element * Terminal::parentElement |
const |
◆ removeConductor()
| void Terminal::removeConductor |
Conductor * |
conductor | ) |
◆ toXml()
| QDomElement Terminal::toXml |
QDomDocument & |
doc | ) |
const |
Terminal::toXml Methode d'export en XML.
- Parameters
| doc | Le Document XML a utiliser pour creer l'element XML |
- Returns
- un QDomElement representant cette borne
◆ type()
| int Terminal::type |
const |
inlineoverride |
type Enable the use of qgraphicsitem_cast to safely cast a QGraphicsItem into a Terminal
- Returns
- the QGraphicsItem type
◆ updateConductor()
| void Terminal::updateConductor |
◆ uuid()
| QUuid Terminal::uuid |
const |
◆ valideXml()
| bool Terminal::valideXml |
QDomElement & |
terminal | ) |
static |
Terminal::valideXml Permet de savoir si un element XML represente une borne.
- Parameters
- Returns
- true si le QDomElement passe en parametre est une borne, false sinon
◆ allowedColor
| QColor Terminal::allowedColor = QColor(Qt::darkGreen) |
static |
◆ dock_elmt_
| QPointF Terminal::dock_elmt_ |
◆ forbiddenColor
| QColor Terminal::forbiddenColor = QColor(Qt::red) |
static |
◆ m_br
◆ m_conductors_list
| QList<Conductor *> Terminal::m_conductors_list |
private |
List of conductors attached to the terminal.
◆ m_draw_help_line
| bool Terminal::m_draw_help_line {false} |
private |
◆ m_help_line
| QGraphicsLineItem* Terminal::m_help_line {nullptr} |
private |
◆ m_help_line_a
| QGraphicsLineItem* Terminal::m_help_line_a {nullptr} |
private |
◆ m_hovered
| bool Terminal::m_hovered = false |
private |
Whether the mouse pointer is hovering the terminal.
◆ m_hovered_color
Color used for the hover effect.
◆ m_previous_terminal
| Terminal* Terminal::m_previous_terminal = nullptr |
private |
Last terminal seen through an attached conductor.
◆ neutralColor
| QColor Terminal::neutralColor = QColor(Qt::blue) |
static |
◆ parent_element_
| Element* Terminal::parent_element_ {nullptr} |
private |
Parent electrical element.
◆ terminalSize
| const qreal Terminal::terminalSize = 4.0 |
static |
◆ warningColor
| QColor Terminal::warningColor = QColor("#ff8000") |
static |
| const qreal Terminal::Z = 1000 |
static |
