The SearchAndReplaceWorker class This class is the worker use to change properties when use the search and replace function of QET.
More...
#include <searchandreplaceworker.h>
◆ SearchAndReplaceWorker()
| SearchAndReplaceWorker::SearchAndReplaceWorker |
◆ applyChange() [1/2]
SearchAndReplaceWorker::applyChange.
- Parameters
| original | : the original properties |
| change | : the change properties, to be merged with original |
- Returns
- a new conductor properties with the change applyed.
◆ applyChange() [2/2]
| QString SearchAndReplaceWorker::applyChange |
const QString & |
original, |
const QString & |
change |
static |
◆ eraseDate()
| static QDate SearchAndReplaceWorker::eraseDate |
inlinestatic |
◆ eraseText()
| static QString SearchAndReplaceWorker::eraseText |
inlinestatic |
◆ invalidConductorProperties()
◆ replaceAdvanced() [1/4]
◆ replaceAdvanced() [2/4]
◆ replaceAdvanced() [3/4]
◆ replaceAdvanced() [4/4]
SearchAndReplaceWorker::replaceAdvanced Apply the change of text according to the current advancedStruct All items in the 4 list must belong to the same QETProject, if not this function do nothing.
- Parameters
| diagrams | : |
| elements | : |
| texts | : |
| conductors | : |
◆ replaceConductor() [1/2]
| void SearchAndReplaceWorker::replaceConductor |
Conductor * |
conductor | ) |
◆ replaceConductor() [2/2]
QList< Conductor * > |
list | ) |
SearchAndReplaceWorker::replaceConductor Replace all properties of each conductor in list All conductor must belong to the same project, if not this function do nothing. All change are made through a undo command append to undo list of the project.
- Parameters
◆ replaceDiagram() [1/2]
| void SearchAndReplaceWorker::replaceDiagram |
Diagram * |
diagram | ) |
◆ replaceDiagram() [2/2]
QList< Diagram * > |
diagram_list | ) |
SearchAndReplaceWorker::replaceDiagram Replace all properties of each diagram in diagram_list, by the current titleblock properties of this worker.
- Parameters
| diagram_list | : list of diagram to be changed, all diagrams must belong to the same project; |
◆ replaceElement() [1/2]
| void SearchAndReplaceWorker::replaceElement |
Element * |
element | ) |
◆ replaceElement() [2/2]
QList< Element * > |
list | ) |
SearchAndReplaceWorker::replaceElement Replace all properties of each elements in list All element must belong to the same project, if not this function do nothing. All change are made through a undo command append to undo list of the project.
- Parameters
◆ replaceIndiText() [1/2]
◆ replaceIndiText() [2/2]
◆ setupLineEdit()
| void SearchAndReplaceWorker::setupLineEdit |
QLineEdit * |
l, |
QCheckBox * |
cb, |
QString |
str |
static |
SearchAndReplaceWorker::setupLineEdit With search and replace, when the variable to edit is a text, the editor is always the same no matter if it is for a folio, element or conductor. The editor is a QLineEdit to edit the text and checkbox to erase the text if checked. This function fill the editor, from the current string.
- Parameters
◆ SearchAndReplaceWidget
◆ m_advanced_struct
◆ m_conductor_properties
◆ m_element_context
◆ m_indi_text
| QString SearchAndReplaceWorker::m_indi_text |
private |
◆ m_titleblock_properties
